Error: Arduino not working from external power source.
Hello.
I want to make maze robot with pladge algorithm. I wrote just simple test program for it. It works fine if I am connected to computer, but if I want to power arduino from 9v battery then it does some kind of madness. I have modified servos so I control motors like servos. I use two sonars HC SR-04. Code is here:
//maze robot code by: Mikk Kruusalu
#include <Servo.h>
Servo rightServo;
Servo leftServo;
#define echoPinF 13 // Echo Pin
#define trigPinF 12 // Trigger Pin
#define echoPinR 5
#define trigPinR 6
int maximumRange = 200; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
const int sensorfVCC = 11;
const int sensorrVCC = 4;
const int servoVCC = 8;
int counter = 0;
  Serial.begin (9600);
  pinMode(sensorfVCC, OUTPUT);
  pinMode(servoVCC, OUTPUT);
  pinMode(sensorrVCC, OUTPUT);
  digitalWrite(sensorrVCC, HIGH);
  digitalWrite(servoVCC, HIGH);
  digitalWrite(sensorfVCC, HIGH);
  pinMode(3, HIGH);
  pinMode(trigPinR, OUTPUT);
  pinMode(echoPinR, INPUT);
  pinMode(trigPinF, OUTPUT);
  pinMode(echoPinF, INPUT);
  rightServo.attach(9);
  leftServo.attach(10);
int sensorReading(int trigPin, int echoPin)
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  //Calculate the distance (in cm) based on the speed of sound.
  distance = duration/58.2;
  if (distance >= maximumRange || distance <= minimumRange){
  /* Send a negative number to computer and Turn LED ON
  to indicate "out of range" */
    Serial.println("-1");
    return -1;
  else {
  /* Send the distance to the computer using Serial protocol, and
  turn LED OFF to indicate successful reading. */
    Serial.println(distance);
    return distance;
  while(true)
    leftServo.write(180);
    rightServo.write(70);
    if(sensorReading(trigPinF, echoPinF) <= 7 && sensorReading(trigPinF, echoPinF) != -1)
      leftServo.write(0);
      delay(610);
  digitalWrite(3, HIGH);
Please help!
Best regards,
Mikk
Contact: kruusalu.mikk@gmail.com
Because a 9V battery is pathetic. You need a REAL battery, not some wimpy-ass low-current smoke detector battery. Unless you have a smoke detector, that is.
Thanks! I don't know why I didn't figured it out myself :). Everything is working now.
