Hello everybody,
I’ve made a code to send some data to google spreadsheet via temboo. I’m using 2 DHT21 and it works nice, but when adding a DS18B20 thermometer to this code, I get a temboo error report.
I found that the problem begins when this lines are added:
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
It runs, but temboo does not send data to google spreadsheet.
I’m not a experienced programmer, any help is welcome!!
Here is the working code:
// Include required libraries
#include <Bridge.h>
#include <Temboo.h>
#include <Process.h>
#include <Console.h>
#include <Wire.h>
const unsigned long RUN_INTERVAL_MILLIS = 60000*10; // how often to run the Choreo (in milliseconds)
// the last time we ran the Choreo
// (initialized to 60 seconds ago so the
// Choreo is run immediately when we start up)
unsigned long lastRun = (unsigned long)-60000*10;
// Contains Temboo account information
#include “TembooAccount.h”
// Variables
float h_in;
float t_in;
float h_out;
float t_out;
unsigned long time;
float temperature_limit; // IN
// Process to get the measurement time
Process date;
// Your Google Docs data
const String GOOGLE_USERNAME = “xxxxxxxxx@gmail.com”;
const String GOOGLE_PASSWORD = “xxxxxxxxxxxxxxx”;
const String SPREADSHEET_TITLE = “xxxxx”;
const String TO_EMAIL_ADDRESS = “xxxxxxxxx@gmail.com”;
#include “DHT.h”
// DHT11 sensor pins
#define DHT1PIN 2 //IN
#define DHT2PIN 3 // OUT
#define DHT1TYPE DHT21
#define DHT2TYPE DHT21
int Mist_Maker = 11;
DHT dht1(DHT1PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT2TYPE);
// Debug mode ?
boolean debug_mode = false;
// Start Serial
if (debug_mode == true){
Console.begin();
pinMode(Mist_Maker, OUTPUT);
digitalWrite(Mist_Maker, HIGH);
delay(4000);
while(!Serial);
while(!Console);
// Initialize DHT sensor
dht1.begin();
dht2.begin();
// Set temperature limit
temperature_limit = 33.0;
// Start bridge
Bridge.begin();
// Start date process
time = millis();
if (!date.running()) {
date.begin(“date”);
date.addParameter("+%D-%T");
date.run();
Serial.println(“Setup complete. Waiting for sensor input…\n”);
// Measure the humidity & temperature
h_in = dht1.readHumidity();
t_in = dht1.readTemperature();
h_out = dht2.readHumidity();
t_out = dht2.readTemperature();
Console.print(t_in);
Console.print(" C / “);
Console.print(h_in);
Console.println(” %\t");
if(h_in < 50){
digitalWrite(Mist_Maker, LOW);} // liga desumidificador
if (h_in > 70){
digitalWrite(Mist_Maker, HIGH);} // desliga desumidificador
unsigned long now = millis();
Serial.println("\nCalling the /Library/Google/Spreadsheets/AppendRow Choreo…");
if (now - lastRun >= RUN_INTERVAL_MILLIS) {
// remember ‘now’ as the last time we ran the choreo
lastRun = now;
// Append data to Google Docs sheet
runAppendRow(h_in, t_in, h_out, t_out);}
// Send email alert ?
if (t_in > temperature_limit) {
if (debug_mode == true){Serial.println(“Sending alert”);}
sendTempAlert(“Temperature is too High!”);
// Function to add data to Google Docs
void runAppendRow(float h_in, float t_in, float h_out, float t_out) {
TembooChoreo AppendRowChoreo;
// Invoke the Temboo client
AppendRowChoreo.begin();
// Set Temboo account credentials
AppendRowChoreo.setAccountName(TEMBOO_ACCOUNT);
AppendRowChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
AppendRowChoreo.setAppKey(TEMBOO_APP_KEY);
// Identify the Choreo to run
AppendRowChoreo.setChoreo("/Library/Google/Spreadsheets/AppendRow");
// your Google username (usually your email address)
AppendRowChoreo.addInput(“Username”, GOOGLE_USERNAME);
// your Google account password
AppendRowChoreo.addInput(“Password”, GOOGLE_PASSWORD);
// the title of the spreadsheet you want to append to
AppendRowChoreo.addInput(“SpreadsheetTitle”, SPREADSHEET_TITLE);
// Restart the date process:
date.begin(“date”);
date.run();
// Get date
String timeString = date.readString();
// Format data
String data = “”;
data = data + timeString + “,” + String(h_in) + “,” + String(t_in) + “,” + String(h_out) + “,” + String(t_out);
// Set Choreo inputs
AppendRowChoreo.addInput(“RowData”, data);
// Run the Choreo
unsigned int returnCode = AppendRowChoreo.run();
// A return code of zero means everything worked
if (returnCode == 0) {
Serial.println(“Completed execution of the /Library/Google/Spreadsheets/AppendRow Choreo.\n”);
// A non-zero return code means there was an error
// Read and print the error message
while (AppendRowChoreo.available()) {
char c = AppendRowChoreo.read();
if (debug_mode == true){ Serial.print(c); }
if (debug_mode == true){ Serial.println(); }
AppendRowChoreo.close();
// Send email alert
void sendTempAlert(String message) {
if (debug_mode == true){ Serial.println(“Running SendAnEmail…”);}
TembooChoreo SendEmailChoreo;
SendEmailChoreo.begin();
// set Temboo account credentials
SendEmailChoreo.setAccountName(TEMBOO_ACCOUNT);
SendEmailChoreo.setAppKeyName(TEMBOO_APP_KEY_NAME);
SendEmailChoreo.setAppKey(TEMBOO_APP_KEY);
// identify the Temboo Library choreo to run (Google > Gmail > SendEmail)
SendEmailChoreo.setChoreo("/Library/Google/Gmail/SendEmail");
// set the required choreo inputs
// see https://www.temboo.com/library/Library/Google/Gmail/SendEmail/
// for complete details about the inputs for this Choreo
// the first input is your Gmail email address
SendEmailChoreo.addInput(“Username”, GOOGLE_USERNAME);
// next is your Gmail password.
SendEmailChoreo.addInput(“Password”, GOOGLE_PASSWORD);
// who to send the email to
SendEmailChoreo.addInput(“ToAddress”, TO_EMAIL_ADDRESS);
// then a subject line
SendEmailChoreo.addInput(“Subject”, “ALERT: Home Temperature”);
// next comes the message body, the main content of the email
SendEmailChoreo.addInput(“MessageBody”, message);
// tell the Choreo to run and wait for the results. The
// return code (returnCode) will tell us whether the Temboo client
// was able to send our request to the Temboo servers
unsigned int returnCode = SendEmailChoreo.run();
// a return code of zero (0) means everything worked
if (debug_mode == true){Serial.println(“Success! Email sent!”);}
// a non-zero return code means there was an error
// read and print the error message
while (SendEmailChoreo.available()) {
char c = SendEmailChoreo.read();
if (debug_mode == true){Serial.print(c);}
SendEmailChoreo.close();
