Hi I've been using the IOT for a number of weeks now and suddenly I can no longer connect as I get the error message. no code has changed.
Im using the web editor, i the error seems before it hits my code but unsure. using a nano 33t board.
I tried removing and re installing the board and properties but no change
Be gentle with me i'm new at this!!! useful help is good, superior criticism ... not so!
Thanks
WiFiNINA - Version: Latest
#include <WiFiNINA.h>
// Arduino_ConnectionHandler - Version: Latest
#include "thingProperties.h"
#include "Arduino.h"
#include "Servo.h"
// Pin Definitions
#define SERVO9G_PIN_SIG 2
const int restPos = 100; //Starting position
const int outPos =20;
const int inPos = 180;
// object initialization
Servo servo9g;
while (!Serial) ; // wait for serial port to connect. Needed for native USB
Serial.println("start");
servo9g.write(90);
servo9g.attach(SERVO9G_PIN_SIG);
delay(100);
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(4);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
//Error seems to be at this point???
void onAwningChange() {
static bool out;
static bool firstTime;
static int iCount;
Serial.print("changing");
if (firstTime !=true) {
firstTime = true;
goto firsttimeexit;
switch (out) {
case true:
iCount = inPos;
out=false;
case false:
iCount = outPos;
out=true;
Serial.print(" iCount=" + String(iCount));
servo9g.write(iCount);
delay(2000);
servo9g.write(restPos);
firsttimeexit:
firstTime = true;
Serial.print ("Exit loop3= " + String(firstTime));
start
***** Arduino IoT Cloud - configuration info *****
Device ID: c9b12fa7-5d0c-42d2-8210-XXXXXXXXX
Thing ID: c4b7b8d5-afbf-4d93-874d-XXXXXXXXXX
MQTT Broker: mqtts-sa.iot.arduino.cc:8883
WiFi.status(): 0
Current WiFi Firmware: 1.2.3
Connection to "xxxxxxx failed
Retrying in "500" milliseconds
Connected to "VM8191823"
Arduino IoT Cloud Connection status: CONNECTING
ArduinoCloud.connect(): 0
Please assist
