turgo
May 26, 2013, 5:40am
#1
This line:
allSensors[0].address={0x28, 0x26, 0xAE, 0xEB, 0x03, 0x00, 0x00, 0xB2};
Generates this error:
ThingSpeak:104: error: expected primary-expression before '{' token
ThingSpeak:104: error: expected `;' before '{' token
The context is this code (Note that the first line thirdFloorAddress works. Why?):
DeviceAddress thirdFloorAddress = {
0x28, 0x88, 0xCD, 0xEB, 0x03, 0x00, 0x00, 0xA2}; //
class Sensor_Specification {
public:
DeviceAddress address;
String addressString;
String location;
int updateInterval;//in milliseconds
int pin;
String channel;
int field;
float currentTemp;
float recentTemps[5];
float averageTemp;} ;
Sensor_Specification allSensors[12];
// Local Network Settings
byte mac[] = {
0xD4, 0x28, 0xB2, 0xFF, 0xA0, 0xA1 }; // Must be unique on local network
// Initialize Arduino Ethernet Client
EthernetClient client;
// Start Serial for debugging on the Serial Monitor
//Fill allSensors array
allSensors[0].location="1st Floor";
allSensors[0].channel="House Temperatures";
allSensors[0].field=1;
allSensors[0].addressString="2826AEEB030000B2";
allSensors[0].pin=11;
allSensors[0].updateInterval=600000;
‘address’ can only be assigned that way while initializing during its declaration.
You’d probably be better off using ‘memcpy’ instead.
turgo
May 26, 2013, 6:36am
#3
Thanks again for your reply.
why can 'address' only be assigned that way while initializing during its declaration? Given the complexity of the Sensor_Specifications class, how can I make the assignment during declaration? I'm unsure about syntax.
How can it be assigned later? Do I need to convert the hexidecimal to integers?
Reading about memcpy, it sounds dangerous, that I could overwrite without being aware.
Due to language specification.
#define A_SIZEOF(ARRAY) (sizeof(ARRAY) / sizeof(ARRAY[0]))
struct Sensor_Specification
String location;
unsigned long updateInterval; // NOTE: YOU ATTEMPT TO PLACE A LONG INTEGER INTO A SPACE OF ONTGER
int pin;
String channel;
int field;
float currentTemp;
float averageTemp;
Sensor_Specification allSensors[] =
{ { 0x28, 0x26, 0xAE, 0xEB, 0x03, 0x00, 0x00, 0xB2 }, "2826AEEB030000B2", "1st Floor", 600000UL, 11, "House Temperatures", 1, ... }
turgo
May 26, 2013, 7:18am
#5
Thanks, lloyd! It worked!
I'll read about struct.
Please explain:
To work out the number of elements in an array at run time 2 things must be known.
The total number of bytes used by the array. This is returned by the sizeof() function with the array as the parameter.
The size of each array element. This is returned by the sizeof() function with the first element of the array as the parameter.
Dividing one by the other gives the number of elements in the array.
