Error associated with refresh data
Hi, I have a climax as the data from the sensor temperature and websites that data does not refresh why such an error was made on the show nicely temperature monitor to display
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Ethernet.h>
#include <SPI.h>
#include <Wire.h>
#include <FastIO.h>
#include <I2CIO.h>
#include <LCD.h>
#include <LiquidCrystal.h>
#include <LiquidCrystal_SR.h>
#include <LiquidCrystal_SR2W.h>
#include <LiquidCrystal_SR3W.h>
//termometr
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// lcd
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // lcd adres end pin 0x27
//network NB: Pins 10, 11, 12 and 13 are reserved for Ethernet module.
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip = { 192, 168, 0, 177 };
byte gateway = { 192, 168, 1, 1 };
byte subnet = { 255, 255, 255, 0 };
String readString;
String Led;
int led = {00, 3, 4 , 5 , 6 , 7 , 8, 9 }; //Led pins num 0 in arry is not used
int numofleds = 7; //numofleds
String value = {“on”, “on”, “on”, “on”, “on”, “on”, “on”, “on”}; //startup all led are off
String value1 = {“1”, “1”, “1”, “1”, “1”, “1”, “1”, “1”}; //startup all led are off
EthernetServer server(80);
String data;
lcd.begin(16, 2); // LCD 2x16
lcd.backlight(); // lcd on led
lcd.setCursor(2, 0); // lcd
lcd.print(“Witaj David!”);
lcd.setCursor(1, 0); // lcd
delay(300);
lcd.clear();
lcd.setCursor(0, 0); // lcd
lcd.print(“Temp:”);
lcd.setCursor (6, 0);
// wyświetla temperaturę
lcd.print(sensors.getTempCByIndex(0));
Serial.println(sensors.getTempCByIndex(0));
lcd.setCursor (11, 0);
lcd.print(“C”);
sensors.begin();
// internt
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//set pin mode
for (int j = 1; j < (numofleds + 1); j++) {
pinMode(led[j], OUTPUT);
Serial.println(“Serial READY”);
Serial.println(“Ethernet READY”);
Serial.println(“Server READY”);
sensors.requestTemperatures();
if (client) {
// an http request ends with a blank line
boolean current_line_is_blank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 100) {
readString += c;
if (c == ‘\n’ && current_line_is_blank) {
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println();
client.println("");
client.println(“
Led controller
for (int i = 1; i < (numofleds + 1) ; i++) {
Led = String(“led”) + i;
if (readString.indexOf(Led + “=on”) > 0 || readString.indexOf(“all=on”) > 0) {
Serial.println(Led + “on”);
digitalWrite(led*, HIGH);*
_ value = “off”;_
_ value1 = “0”;
* } else if (readString.indexOf(Led + “=off”) > 0 || readString.indexOf(“all=off”) > 0 ) {
Serial.println(Led + “off”);
digitalWrite(led, LOW);
value = “on”;
value1 = “1”;
client.println("
" + Led + " ");
client.println("
All ");
client.println("
// Print readings from sensors (DS18B20)
client.println(“Temperatura: “);
client.print(sensors.getTempCByIndex(0));
client.println(“C”);
client.println(””);
if (c == ‘\n’) {
// we’re starting a new line*
* current_line_is_blank = true;*
* } else if (c != ‘\r’) {
// we’ve gotten a character on the current line*
* current_line_is_blank = false;*
// give the web browser time to receive the data*
* delay(1);
readString = “”;
client.stop();*_
* // wyświetla status*
* lcd.setCursor (3, 1);*
* lcd.print(value1[1]);*
* lcd.setCursor (5, 1);*
* lcd.print(value1[2]);*
* lcd.setCursor (7, 1);*
* lcd.print(value1[3]);*
* lcd.setCursor (9, 1);*
* lcd.print(value1[4]);*
* lcd.setCursor (11, 1);*
* lcd.print(value1[5]);*
* lcd.setCursor (13, 1);*
* lcd.print(value1[6]);*
* lcd.setCursor (15, 1);*
* lcd.print(value1[7]);*
Which Arduino are you pissing away resources on the String class on?
Why did you not post your code properly?
Why should a website refresh automatically, when you are not telling it to?
