error at if else statement
I tried to code for the analog sensor output, to perform addition. How to solve the error?
i try to assign name, in1 for first output, in2 for second output and so on.
#include <stdio.h>
int i;
int in1, in2, in3;
int total;
int val;
   for (int i = 0; i < 10; i++)
    { val = analogRead(A0);
        if (i==0) {
      val= analogRead(i);
      in1=val;
      Serial.println(in1,DEC);
      delay(1000);}
        else if (i==1) {
      val= analogRead(i);
      in2=val;
      Serial.println(in2,DEC);
      delay(1000);}
        else  (i==3) {
      val1= analogRead(i);
      int3=val;
      Serial.println(in3,DEC);
      delay(1000);}
return 0;}
total = in1 + in2 + in3;
 Serial.println(total,DEC);
      delay(1000);}
This is the error message i got:
assig1:29:21: error: expected ';' before '{' token
         else  (i=3) {
assig1:34:8: error: return-statement with a value, in function returning 'void' [-fpermissive]
 return 0;}
exit status 1
Look at the subtle difference between these two:
else if (i==1)
else  (i==3)
Not:
        else  (i==3) {
But:
        else  if (i==3) {
re the 2nd error: loop() returns void but you're using "return 0;".
Thank you all for the helpful comment,
now I manage to run the code as what I expected.
however, the reading isn't correct, where it is not the exact output from A0 after several testing.
Do you all have any idea about this? is there something wrong in my code, that causes the output does not come from pin A0?
#include <stdio.h>
int i;
int in1, in2, in3, in4, in5, in6, in7, in8, in9, in10;
int total;
int val;
{  val = analogRead(0);
   delay(100);
if (i==0) {
      val= analogRead(i);
      in1=val;
      printf("value0 :  %d \n",in1);}
else if (i==1) {
      val= analogRead(i);
      in2=val;
      printf("value1 :  %d \n",in2);}
else if (i==2) {
      val= analogRead(i);
      in3=val;
      printf("value2 :  %d \n",in3);}
else if (i==3) {
      val= analogRead(i);
      in4=val;
      printf("value3 :  %d \n",in4);}
else if (i==4) {
      val= analogRead(i);
      in5=val;
      printf("value4 :  %d \n",in5);}
else if (i==5) {
      val= analogRead(i);
      in6=val;
      printf("value5 :  %d \n",in6);}
else if (i==6) {
      val= analogRead(i);
      in7=val;
      printf("value6 :  %d \n",in7);}
else if (i==7) {
      val= analogRead(i);
      in8=val;
      printf("value7 :  %d \n",in8);}
else if (i==8) {
      val= analogRead(i);
      in9=val;
      printf("value8 :  %d \n",in9);}
else if (i==9) {
      val= analogRead(i);
      in10=val;
      printf("value9 :  %d \n",in10);}
total = in1 + in2 + in3 + in4 + in5 + in6 + in7 + in8+ in9 + in10;
printf("total :  %d \n",total);
      delay(1000);}
Why so much code?
If you need to keep all the in values after the for loop, use an array.
If not, just sum them.
sorry, but i have to stick to this, as i still need to proceed the in1, in2, in3, .. so on later by adding more mathematical algorithm. By introducing an array, i have no clue in assigning each element in there for individual function
(uncompiled, untested)
#include <stdio.h>
const int N_READINGS = 10;
int readings [N_READINGS];
  val = analogRead(0); // not sure what this is here for
  delay(100);
  unsigned long total = 0;
  for (int i = 0; i < N_READINGS; i++) {
    in [i] = analogRead(i);
    printf("value %d :  %d \n",i, in [i]);
    total += in [i];
  printf("total :  %d \n", total);
You're running this on a Mega?
thank you, i am running in uno,
terW3_:
Then avoid using FOR loop, it have no purpose in your code if use anyway IF statements. Just simply sequentially read value one by one without it.
Anyway, using array in this case is indeed logical solution, if you need to preserve and use all results later.
terW3_:
So why are you trying to read from analogue pins you don't have?
Just one of many examples
else if (i==9) {
      val= analogRead(i);
i = 9. analogRead(9) does not read a value from A0.
Steve
