Error ATtiny85 Error loading or parsing hex file
I'm having issue uploading on ATtiny85.
Here is the error logs. Can someone help me? I saw previous post way back 2022 about the filename with spaces but I already simplified the filename to "a.ino" but still I'm getting this error.
FQBN: ATTinyCore:avr:attinyx5micr
Using board 'attinyx5micr' from platform in folder: C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Using core 'tiny' from platform in folder: C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2
Detecting libraries used...
C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16500000L -DCLOCK_SOURCE=6 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB -DHASUSB -DBOOTTUNED165 -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5 C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\sketch\a.ino.cpp -o nul
Alternatives for Adafruit_NeoPixel.h: [Adafruit NeoPixel@1.12.0]
ResolveLibrary(Adafruit_NeoPixel.h)
  -> candidates: [Adafruit NeoPixel@1.12.0]
C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16500000L -DCLOCK_SOURCE=6 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB -DHASUSB -DBOOTTUNED165 -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5 -Ic:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\sketch\a.ino.cpp -o nul
Using cached library dependencies for file: c:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp
Using cached library dependencies for file: c:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel\esp.c
Using cached library dependencies for file: c:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel\esp8266.c
Using cached library dependencies for file: c:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel\kendyte_k210.c
Generating function prototypes...
C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=attiny85 -DF_CPU=16500000L -DCLOCK_SOURCE=6 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB -DHASUSB -DBOOTTUNED165 -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\cores\tiny -IC:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\hardware\avr\1.5.2\variants\tinyX5 -Ic:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\sketch\a.ino.cpp -o C:\Users\Jay r and Fiona\AppData\Local\Temp\2557018170\sketch_merged.cpp
C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Jay r and Fiona\AppData\Local\Temp\2557018170\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=attiny85 -DF_CPU=16500000L -DCLOCK_SOURCE=6 -DARDUINO=10607 -DARDUINO_AVR_ATTINYX5 -DARDUINO_ARCH_AVR -DNEOPIXELPORT=PORTB -DHASUSB -DBOOTTUNED165 "-IC:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\cores\\tiny" "-IC:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\ATTinyCore\\hardware\\avr\\1.5.2\\variants\\tinyX5" "-Ic:\\Users\\Jay r and Fiona\\Documents\\Arduino\\libraries\\Adafruit_NeoPixel" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\sketch\\a.ino.cpp" -o "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\sketch\\a.ino.cpp.o"
Compiling libraries...
Compiling library "Adafruit NeoPixel"
Using previously compiled file: C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\libraries\Adafruit_NeoPixel\kendyte_k210.c.o
Using previously compiled file: C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\libraries\Adafruit_NeoPixel\esp8266.c.o
Using previously compiled file: C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\libraries\Adafruit_NeoPixel\esp.c.o
Using previously compiled file: C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7\libraries\Adafruit_NeoPixel\Adafruit_NeoPixel.cpp.o
Compiling core...
Using precompiled core: C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\cores\01ac19cd3952a895838b3efe7e2acb37\core.a
Linking everything together...
"C:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=attiny85 -o "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.elf" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\sketch\\a.ino.cpp.o" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\libraries\\Adafruit_NeoPixel\\Adafruit_NeoPixel.cpp.o" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\libraries\\Adafruit_NeoPixel\\esp.c.o" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\libraries\\Adafruit_NeoPixel\\esp8266.c.o" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7\\libraries\\Adafruit_NeoPixel\\kendyte_k210.c.o" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/..\\..\\cores\\01ac19cd3952a895838b3efe7e2acb37\\core.a" "-LC:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7" -lm
"C:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.elf" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.eep"
"C:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.elf" "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.hex"
Using library Adafruit NeoPixel at version 1.12.0 in folder: C:\Users\Jay r and Fiona\Documents\Arduino\libraries\Adafruit_NeoPixel
"C:\\Users\\Jay r and Fiona\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-size" -A "C:\\Users\\Jay r and Fiona\\AppData\\Local\\Temp\\arduino\\sketches\\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.elf"
Sketch uses 2144 bytes (32%) of program storage space. Maximum is 6586 bytes.
Global variables use 37 bytes (7%) of dynamic memory, leaving 475 bytes for local variables. Maximum is 512 bytes.
"C:\Users\Jay r and Fiona\AppData\Local\Arduino15\packages\ATTinyCore\tools\micronucleus\2.5-azd1b/micronucleus" --no-ansi --run --timeout 60 C:\Users\Jay r and Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.hex
> Please plug in the device (will time out in 60 seconds) ...
> Device is found!
connecting: 16% complete
connecting: 22% complete
connecting: 28% complete
connecting: 33% complete
> Device has firmware version 1.6
> Available space for user applications: 6012 bytes
> Suggested sleep time between sending pages: 8ms
> Whole page count: 94  page size: 64
> Erase function sleep duration: 752ms
> Error opening Fiona\AppData\Local\Temp\arduino\sketches\9B6CAD26DA2BEC9D23A24C32D15B11C7/a.ino.hex: No such file or directory
> Error loading or parsing hex file.
Failed uploading: uploading error: exit status 1
You have spaces in your path as well.
Got it. let me try it. Thank you for your response.
