error; avrdude: stk500_recv(): programmer is not responding avrdude: stk500_gets
I am totally new at this. I get on upload this error avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
I am running macbook pro with High Sierra, and uno . My Uno does not have a green led but one red always on and one red blinking quickly.
This is my first try at anything with this. I uploaded Blink
any help?
Any responds ,I have a same problem with a leonardo board.
The target is not reachable (not responding at all) for many reasons: cable, port, drivers, bootloader... It is like not connected. It is not the first time with the same problem. Try to start here: https://www.arduino.cc/en/Guide/Troubleshooting#toc1
hi i am using the arduino uno i am trying to upload a program but the program was not uploading and it show the error of
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM13 Using Programmer : arduino Overriding Baud Rate : 115200 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x47 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x47
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
please help me to solve this problom
intento configurar la placa bluetooth desde la placa arduino uno compilo sin problemas cuando intento subir el boceto a la placa me da este error.....help me...
how can i solve this problem help... me...
Read post #2. Try this troubleshooting page first.
The response 0x47 (nonzero and not 0xFF) could be caused by incorrect setting in the IDE: programmer, board, baud rate (even this is 115200 as default problem can be in different bootloader). Post details about your board: genuine/clone, on-board LEDs behaviour. Does the problem start after some test/use or it is from the beginning?
