Error beim Laden von Parametern aus FS (Wifimanager)
Hallo an alle,
also ich habe ein Problem wenn ich mein ESP8266 resete und die custom Parameter welche ich zuvor beim Captive Portal eingegeben habe, zu laden.
Hier der Code:
#include <FS.h>                   //this needs to be first, or it all crashes and burns...
#include <ESP8266WiFi.h>          //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>          //https://github.com/tzapu/WiFiManager
#include <ArduinoJson.h>          //https://github.com/bblanchon/ArduinoJson
#include <PubSubClient.h>
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#define S0 16   //D0                             /* Assign Multiplexer pin S0 connect to pin D0 of NodeMCU */
#define S1 5    //D1                             /* Assign Multiplexer pin S1 connect to pin D1 of NodeMCU */
#define S2 4    //D2                             /* Assign Multiplexer pin S2 connect to pin D2 of NodeMCU */
#define S3 0    //D3                            /* Assign Multiplexer pin S3 connect to pin D3 of NodeMCU */
#define SIG A0                            /* Assign SIG pin as Analog output for all 16 channels of Multiplexer to pin A0 of NodeMCU */
int decimal = 2;                          // Decimal places of the sensor value outputs
int sensor0;                            /* Assign the name "sensor0" as analog output value from Channel C0 */
int sensor1;                            /* Assign the name "sensor1" as analog output value from Channel C1 */
int sensor2;                            /* Assign the name "sensor2" as analog output value from Channel C2 */
int sensor3;                            /* Assign the name "sensor3" as analog output value from Channel C3 */
int sensor4;                            /* Assign the name "sensor4" as analog output value from Channel C4 */
int sensor5;                            /* Assign the name "sensor5" as analog output value from Channel C5 */
int sensor6;                            /* Assign the name "sensor6" as analog output value from Channel C6 */
int sensor7;                            /* Assign the name "sensor7" as analog output value from Channel C7 */
int sensor8;                            /* Assign the name "sensor8" as analog output value from Channel C8 */
int sensor9;                            /* Assign the name "sensor9" as analog output value from Channel C9 */
int sensor10;                           /* Assign the name "sensor10" as analog output value from Channel C10 */
int sensor11;                           /* Assign the name "sensor11" as analog output value from Channel C11 */
int sensor12;                           /* Assign the name "sensor12" as analog output value from Channel C12 */
int sensor13;                           /* Assign the name "sensor13" as analog output value from Channel C13 */
int sensor14;                           /* Assign the name "sensor14" as analog output value from Channel C14 */
int sensor15;                           /* Assign the name "sensor15" as analog output value from Channel C15 */
#define DHTPIN 12 //D6    // Digital pin connected to the DHT sensor
#define MoisturePin sensor0  // used for Arduino and ESP8266
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
#define rainAnalog sensor1
#define rainDigital 13 //D7
#define ONE_WIRE_BUS 2    //D4
// Uncomment the type of sensor in use:
#define DHTTYPE    DHT11     // DHT 11
//#define DHTTYPE    DHT22     // DHT 22 (AM2302)
//#define DHTTYPE    DHT21     // DHT 21 (AM2301)
//define your default values here, if there are different values in config.json, they are overwritten.
//char mqtt_server[40];
#define mqtt_server       "xxx.cloudmqtt.com"
#define mqtt_port         "12345"
#define mqtt_user         "mqtt_user"
#define mqtt_pass         "mqtt_pass"
#define mqtt_topic         "mqtt_topic"
#define humidity_topic    "sensor/humidity"
unsigned long lastMsg = 0;
#define MSG_BUFFER_SIZE  (50)
char msg[MSG_BUFFER_SIZE];
int value = 0;
float wet = 905;
float dry = 420;
float MoistureDeconnect = 18;
int percentageHumididy = 0;
uint32_t delayMS;
//flag for saving data
bool shouldSaveConfig = false;
DHT_Unified dht(DHTPIN, DHTTYPE);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
WiFiClient espClient;
PubSubClient client(espClient);
WiFiManager wifiManager;
//callback notifying us of the need to save config
void saveConfigCallback () {
  Serial.println("Should save config");
  shouldSaveConfig = true;
void reset_setting() {
  // Reset Wifi settings for testing
  wifiManager.resetSettings();
  //clean FS for testing
  SPIFFS.format();
  //read configuration from FS json
  Serial.println("mounting FS...");
  if (SPIFFS.begin()) {
    Serial.println("mounted file system");
    if (SPIFFS.exists("/config.json")) {
      //file exists, reading and loading
      Serial.println("reading config file");
      File configFile = SPIFFS.open("/config.json", "r");
      if (configFile) {
        Serial.println("opened config file");
        size_t size = configFile.size();
        // Allocate a buffer to store contents of the file.
        std::unique_ptr<char[]> buf(new char[size]);
        configFile.readBytes(buf.get(), size);
#ifdef ARDUINOJSON_VERSION_MAJOR >= 6
        DynamicJsonDocument json(1024);
        auto deserializeError = deserializeJson(json, buf.get());
        serializeJson(json, Serial);
        if ( ! deserializeError ) {
#else
        DynamicJsonBuffer jsonBuffer;
        JsonObject& json = jsonBuffer.parseObject(buf.get());
        json.printTo(Serial);
        if (json.success()) {
#endif
          Serial.println("\nparsed json");
          strcpy(mqtt_server, json["mqtt_server"]);
          strcpy(mqtt_port, json["mqtt_port"]);
          strcpy(mqtt_user, json["mqtt_user"]);
          strcpy(mqtt_pass, json["mqtt_pass"]);
          strcpy(mqtt_topic, json["mqtt_topic"]);
          Serial.println("failed to load json config");
        configFile.close();
    Serial.println("failed to mount FS");
  //end read
  // The extra parameters to be configured (can be either global or just in the setup)
  // After connecting, parameter.getValue() will get you the configured value
  // id/name placeholder/prompt default length
  WiFiManagerParameter custom_mqtt_server("server", "mqtt server", mqtt_server, 40);
  WiFiManagerParameter custom_mqtt_port("port", "mqtt port", mqtt_port, 6);
  WiFiManagerParameter custom_mqtt_user("user", "mqtt user", mqtt_user, 20);
  WiFiManagerParameter custom_mqtt_pass("pass", "mqtt pass", mqtt_pass, 20);
  WiFiManagerParameter custom_mqtt_topic("topic", "mqtt topic", mqtt_topic, 20);
  //set config save notify callback
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  //set static ip
  //  wifiManager.setSTAStaticIPConfig(IPAddress(10,0,1,99), IPAddress(10,0,1,1), IPAddress(255,255,255,0));
  //add all your parameters here
  wifiManager.addParameter(&custom_mqtt_server);
  wifiManager.addParameter(&custom_mqtt_port);
  wifiManager.addParameter(&custom_mqtt_user);
  wifiManager.addParameter(&custom_mqtt_pass);
  wifiManager.addParameter(&custom_mqtt_topic);
  // Reset settings for testing
  //reset_setting();
  //set minimum quality of signal so it ignores AP's under that quality
  //defaults to 8%
  //wifiManager.setMinimumSignalQuality();
  //sets timeout until configuration portal gets turned off
  //useful to make it all retry or go to sleep
  //in seconds
  //wifiManager.setTimeout(120);
  //fetches ssid and pass and tries to connect
  //if it does not connect it starts an access point with the specified name
  //here  "AutoConnectAP"
  //and goes into a blocking loop awaiting configuration
  if (!wifiManager.autoConnect("AutoConnectAP", "password")) {
    Serial.println("failed to connect and hit timeout");
    delay(3000);
    //reset and try again, or maybe put it to deep sleep
    ESP.reset();
    delay(5000);
  //if you get here you have connected to the WiFi
  Serial.println("connected to: )");
  String ssid = WiFi.SSID();
  String password = WiFi.psk();
  Serial.print(ssid);
  Serial.println(" ; ");
  Serial.println(password);
  //read updated parameters
  strcpy(mqtt_server, custom_mqtt_server.getValue());
  strcpy(mqtt_port, custom_mqtt_port.getValue());
  strcpy(mqtt_user, custom_mqtt_user.getValue());
  strcpy(mqtt_pass, custom_mqtt_pass.getValue());
  strcpy(mqtt_topic, custom_mqtt_topic.getValue());
  // strcpy(blynk_token, custom_blynk_token.getValue());
  //save the custom parameters to FS
  if (shouldSaveConfig) {
    Serial.println("saving config");
#else
    JsonObject& json = jsonBuffer.createObject();
#endif
    json["mqtt_server"] = mqtt_server;
    json["mqtt_port"] = mqtt_port;
    json["mqtt_user"] = mqtt_user;
    json["mqtt_pass"] = mqtt_pass;
    json["mqtt_topic"] = mqtt_topic;
    File configFile = SPIFFS.open("/config.json", "w");
    if (!configFile) {
      Serial.println("failed to open config file for writing");
    serializeJson(json, configFile);
#else
    json.printTo(configFile);
#endif
    configFile.close();
    //end save
  Serial.println("local ip");
  //  client.setServer(mqtt_server, 12025);
  String mqtt_prt_x_s(mqtt_port);
  const uint16_t mqtt_port_x = strtol(mqtt_prt_x_s.c_str(), NULL, 10);
  const char* mqtt_server_conn = mqtt_server;
  client.setServer(mqtt_server_conn, mqtt_port_x);
  Serial.println("MQTT Server startet with: ");
  Serial.print(mqtt_server_conn);
  Serial.print(" ; ");
  Serial.println(mqtt_port_x);
  client.setCallback(callback);
  pinMode(S0, OUTPUT);                      /* Define digital signal pin as output to the Multiplexer pin SO */
  pinMode(S1, OUTPUT);                      /* Define digital signal pin as output to the Multiplexer pin S1 */
  pinMode(S2, OUTPUT);                      /* Define digital signal pin as output to the Multiplexer pin S2 */
  pinMode(S3, OUTPUT);                      /* Define digital signal pin as output to the Multiplexer pin S3 */
  pinMode(SIG, INPUT);                      /* Define analog signal pin as input or receiver from the Multiplexer pin SIG */
  pinMode(rainDigital, INPUT);
  dht.begin();
  Serial.println(F("DHTxx Unified Sensor Example"));
  // Print temperature sensor details.
  sensor_t sensor;
  dht.temperature().getSensor(&sensor);
  Serial.println(F("------------------------------------"));
  Serial.println(F("Temperature Sensor"));
  Serial.print  (F("Sensor Type: ")); Serial.println(sensor.name);
  Serial.print  (F("Driver Ver:  ")); Serial.println(sensor.version);
  Serial.print  (F("Unique ID:   ")); Serial.println(sensor.sensor_id);
  Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("°C"));
  Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("°C"));
  Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("°C"));
  // Print humidity sensor details.
  dht.humidity().getSensor(&sensor);
  Serial.println(F("Humidity Sensor"));
  Serial.print  (F("Max Value:   ")); Serial.print(sensor.max_value); Serial.println(F("%"));
  Serial.print  (F("Min Value:   ")); Serial.print(sensor.min_value); Serial.println(F("%"));
  Serial.print  (F("Resolution:  ")); Serial.print(sensor.resolution); Serial.println(F("%"));
  // Set delay between sensor readings based on sensor details.
  delayMS = sensor.min_delay / 1000;
  Serial.println("Dallas Temperature IC Control Library Demo");
  sensors.begin();
void reconnect() {
  // Loop until we're reconnected
  while (!client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a random client ID
    String clientId = "ESP8266Client-";
    clientId += String(random(0xffff), HEX);
    // Attempt to connect
    if (client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      //client.publish("test1", "hello world");
      // ... and resubscribe
      //client.subscribe("Moisture_in");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
void callback(char* topic, byte * payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    String message = message + (char) payload[i];  // convert *byte to string
    Serial.print(message);
String topic_string(mqtt_topic);
String t_DTH11_out_s = topic_string + "/t_DTH11_out";
String m_DTH11_out_s = topic_string + "/m_DTH11_out";
String m_val_out_s = topic_string + "/m_val_out";
String m_perc_out_s = topic_string + "/m_perc_out";
String rain_dig_out_s = topic_string + "/rain_dig_out";
String rain_analog_out_s = topic_string + "/rain_analog_out";
String t_plant_out_s = topic_string + "/t_plant_out";
const char *t_DTH11_out = t_DTH11_out_s.c_str();
const char *m_DTH11_out = m_DTH11_out_s.c_str();
const char *m_val_out = m_val_out_s.c_str();
const char *m_perc_out = m_perc_out_s.c_str();
const char *rain_dig_out = rain_dig_out_s.c_str();
const char *rain_analog_out = rain_analog_out_s.c_str();
const char *t_plant_out = t_plant_out_s.c_str();
  if (!client.connected()) {
    reconnect();
  client.loop();
  // Delay between measurements.
  delay(delayMS);
  // Get temperature event and print its value.
  sensors_event_t event;
  dht.temperature().getEvent(&event);
  if (isnan(event.temperature)) {
    Serial.println(F("Error reading temperature!"));
    client.publish(t_DTH11_out, "Error reading temperature!");
  else {
    Serial.print(F("Temperature: "));
    Serial.print(event.temperature);
    float Temp_DHT11_f = event.temperature;
    char Temp_DHT11[10];
    dtostrf(Temp_DHT11_f, 9, 2, Temp_DHT11);
    client.publish(t_DTH11_out, Temp_DHT11);
  // Get humidity event and print its value.
  dht.humidity().getEvent(&event);
  if (isnan(event.relative_humidity)) {
    Serial.println(F("Error reading humidity!"));
    client.publish(m_DTH11_out, "Error reading humidity!");
  else {
    Serial.print(F("Humidity: "));
    Serial.print(event.relative_humidity);
    float Mois_DHT11_f = event.relative_humidity;
    char Mois_DHT11[10];
    dtostrf(Mois_DHT11_f, 9, 2, Mois_DHT11);
    client.publish(m_DTH11_out, Mois_DHT11);
  digitalWrite(S0, LOW);
  digitalWrite(S1, LOW);
  digitalWrite(S2, LOW);
  digitalWrite(S3, LOW);
  float MoistureVal = analogRead(MoisturePin);
  Serial.print("Moisture Sensor Raw Value = ");
  Serial.println(MoistureVal);
  percentageHumididy = (MoistureVal - wet) * (100 - 0) / (dry - wet) + 0;
  Serial.print("Humidity Moisture Sensor = ");
  Serial.print(percentageHumididy);
  Serial.println("%");
  char Moisture[10];
  dtostrf(MoistureVal, 9, 2, Moisture);
  client.publish(m_val_out, Moisture);
  char Moisture_percent[10];
  dtostrf(percentageHumididy, 9, 2, Moisture_percent);
  client.publish(m_perc_out, Moisture_percent);
  int rainDigitalVal = digitalRead(rainDigital);
  Serial.print(F("Rain digital: "));
  Serial.println(rainDigitalVal);
  char RAIN_DIG[10];
  dtostrf(rainDigitalVal, 9, 2, RAIN_DIG);
  client.publish(rain_dig_out, RAIN_DIG);
  digitalWrite(S0, HIGH);
  int rainAnalogVal = analogRead(rainAnalog);
  Serial.print(F("Rain analog: "));
  Serial.println(rainAnalogVal);
  char RAIN_ANALOG[10];
  dtostrf(rainAnalogVal, 9, 2, RAIN_ANALOG);
  client.publish(rain_analog_out, RAIN_ANALOG);
  sensors.requestTemperatures();
  float tempC = sensors.getTempCByIndex(0);
  // Check if reading was successful
  if (tempC != DEVICE_DISCONNECTED_C)
    Serial.print("Temperature for the device 1 (index 0) is: ");
    Serial.println(tempC);
    char Temp_Plant[10];
    dtostrf(tempC, 9, 2, Temp_Plant);
    client.publish(t_plant_out, Temp_Plant);
    Serial.println("Error: Could not read temperature data");
    client.publish(t_plant_out, "Error: Could not read temperature data");
Hier die Fehlermeldung:
--------------- CUT HERE FOR EXCEPTION DECODER ---------------
⸮!⸮⸮1⸮⸮⸮10⸮⸮mounting FS...
mounted file system
reading config file
opened config file
{"mqtt_server":"10.0.0.43","mqtt_port":"1883","mqtt_user":"mqtt_user","mqtt_pass":"mqtt_pass","Test1":"Test1"}
parsed json
Exception (28):
epc1=0x40222b70 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
stack>>>
ctx: cont
sp: 3ffffc90 end: 3fffffc0 offset: 0190
3ffffe20: 3ffef56c 3ffffea0 3ffef56c 40201aa4
3ffffe30: 0000006e 3ffffea0 3ffef56c 40202e14
3ffffe40: 3fff106d 3fff1067 feefef01 3fff1082
3ffffe50: feef007d 3ffffea8 feefeffe feefeffe
3ffffe60: feefeffe feefeffe feefeffe feefeffe
3ffffe70: feefeffe feefeffe feefeffe feefeffe
3ffffe80: feefeffe feefeffe feefeffe feefeffe
3ffffe90: feefeffe feefeffe 00000000 feefeffe
3ffffea0: feefeffe feefeffe 3fff108c 3fff108c
3ffffeb0: 3fff143c 3fff148c feefef00 feefeffe
3ffffec0: 3fff147c 3fff143c feefef20 feefeffe
3ffffed0: 4021d818 00000000 000003e8 4020f284
3ffffee0: 00000000 3fff0fd0 3fff0fc4 40212838
3ffffef0: 00000000 00000000 3ffef734 feefeffe
3fffff00: feefeffe feefeffe feefeffe feefeffe
3fffff10: feefeffe feefeffe feefeffe feefeffe
3fffff20: feefeffe feefeffe feefeffe feefeffe
3fffff30: feefeffe feefeffe feefeffe feefeffe
3fffff40: feefeffe feefeffe feefeffe feefeffe
3fffff50: feefeffe feefeffe feefeffe feefeffe
3fffff60: feefeffe feefeffe feefeffe feefeffe
3fffff70: feefeffe feefeffe feefeffe feefeffe
3fffff80: 3fff1014 3ffe89ee feefeffe feefeffe
3fffff90: feefeffe feefeffe feefeffe 3ffef6b0
3fffffa0: 3fffdad0 00000000 3ffef69c 40211654
3fffffb0: feefeffe feefeffe 3ffe85e4 40100d0d
<<<stack<<<
Könnte es an der Flashe Size liegen?
Meine einstellung jetzt ist: Flash Szie: 1MB (FS:64kB OTA: 470kB)
Das gibt mir die Konsole beim raufladen des Scatches aus:
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: c4:5b:be:54:d9:82
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0340
Compressed 402144 bytes to 284578...
Danke für jede Hilfe!
mfg
Edit:
mir ist noch aufgefallen, das bei laden der datei:
Und statt
Test1:Test1
sollte doch
mqtt_topic:Test1
stehen oder?
Woran liegt das bzw was mache ich falsch?
mfg
Edit:
Link zu internationalem Thread
Stell mal um
Unbenannt
Was zeigt denn deine IDE dazu an ?
Und du kannst den Exception Decoder installieren und damit den Fehler analysieren.
Hey,
danke mal für die Antwort!
Wenn ich umstellen kommt das raus:
H!⸮⸮1⸮⸮⸮1⸮⸮⸮mounting FS...
mounted file system
reading config file
opened config file
{"10.0.0.43":"10.0.0.43","1883":"1883","test1":"test1","id1":"id1","mqtt_user":"mqtt_user","mqtt_pass":"mqtt_pass"}
parsed json
Exception (28):
epc1=0x40222bae epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
stack>>>
ctx: cont
sp: 3ffffc70 end: 3fffffc0 offset: 0190
3ffffe00: 3ffef55c 3fff1004 3ffef55c 40201aa4
3ffffe10: 3ffe89ac 3fff1004 3ffef55c 40202daf
3ffffe20: 3fff105e 3fff1054 feefef01 3fff1077
3ffffe30: feef007d 3ffffe88 feefeffe feefeffe
3ffffe40: feefeffe feefeffe feefeffe feefeffe
3ffffe50: feefeffe feefeffe feefeffe feefeffe
3ffffe70: feefeffe feefeffe 00000000 feefeffe
3ffffe80: feefeffe feefeffe 3fff107c 3fff107c
3ffffe90: 3fff141c 3fff147c feefef00 feefeffe
3ffffea0: 3fff146c 3fff141c feefef20 feefeffe
3ffffeb0: 4021d884 00000000 000003e8 4020f2f0
3ffffec0: 00000000 3fff0fc0 3fff0fb4 402128a4
3ffffed0: 00000000 00000000 3ffef724 feefeffe
3ffffee0: feefeffe feefeffe feefeffe feefeffe
3ffffef0: feefeffe feefeffe feefeffe feefeffe
3fffff80: feefeffe feefeffe feefeffe feefeffe
3fffff90: feefeffe feefeffe feefeffe 3ffef6a0
3fffffa0: 3fffdad0 00000000 3ffef68c 402116c0
<<<stack<<<
warum ändern sich die Parameternamen zu den Inputs?
Wie hängt das mit dem Flash speicher zusammen?
Bin noch am anfang mit FS und json...
mfg
Hy,
danke fpr die Antwort..
Esception Decoder?
Hör ich zum ersten mal, bin aber auch noch nicht so lange am programmieren..
Ich versuch mal den zu downloaden und ob ich da was rausbekomme.
Und was meinst du was die IDE dazu anzeigt?
Danke
kann man den Exception Decoder mit der deutschen IDE intsallieren?
Ich bekomm den nicht angezeigt, vlt liegt es an der deutschen IDE version..
Jemand eine Idee?
danke
Kein Problem. Ich benutze die portable Version der IDE Version 1.8.19
Exceptiondecoder-Verzeichnis in Sketchbook/tools neben libraries und Deinen Sketchen.
Gruß Tommy
hab ich gemacht, wird mir aber trotzdem nicht angezeigt
Noch eine andere Idee?
IDE danach neu gestartet? IDE von der Originalquelle?
Gruß Tommy
Ja sicher neu gestartet und von arduino seite direkt...
Hab auf google ähnliche probleme gefunden aber keine lösung...
Ohne den Exceptiondecoder ist da nichts zu machen in meinem Code?
mfg
Dann muss ich passen. Bei mir funktioniert er halt.
Gruß Tommy
und zu meiner grundsätzlichen frage im code?
Hast du eine Idee?
Oder geht ohne Exceptiondecoder nichts?
mfg
Danke mal für alle antworten, falls jemand noch eine idee hat, wäre für jeden vorschlag offen!
Werd sonst nochmal im internationalen forum nachfragen vlt. hat dort jemand eine Idee.
Trotzdem danke mal soweit
Dann verlinke bitte beide Threads miteinander.
Gruß Tommy
wie gehts das?
bitte um Hilfe danke
Link setzen mit den beiden Kettengliedern und aus dem Browser die URL des anderen Threads kopieren.
Gruß Tommy
mein Internationaler Thread dazu
So wie ich es unten gemacht habe?
Nur damit ich nächstes mal bescheid weis
Danke
Wo unten?
Und dort auch noch nach hier zum Anfangsbeitrag.
Gruß Tommy
Gemacht, danke
