Error Burning bootloader UNO R3 to AT328pAU on custom pcb
The programmer is Genuine Arduino Uno R3.
The target is AT328pAU direct soldered on custom pcb with 16 MHz oscillator, cap ecc.
I try two different type of dupont cable, but there is this error
the connection from programmer to target
D13 to D13
D12 to D12
D11 to D11
D10 to reset
GND to GND
5V to 5V
The error output is this:
Arduino:1.8.12 (Linux), Board:"Arduino Uno"
/home/user/Download/arduino-1.8.12/hardware/tools/avr/bin/avrdude -C/home/user/Download/arduino-1.8.12/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/ttyACM0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "/home/user/Download/arduino-1.8.12/hardware/tools/avr/etc/avrdude.conf"
     User configuration file is "/home/user/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
     Using Port                    : /dev/ttyACM0
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
     AVR Part                      : ATmega328P
     Chip Erase delay              : 9000 us
     PAGEL                         : PD7
     BS2                           : PC2
     RESET disposition             : dedicated
     RETRY pulse                   : SCK
     serial program mode           : yes
     parallel program mode         : yes
     Timeout                       : 200
     StabDelay                     : 100
     CmdexeDelay                   : 25
     SyncLoops                     : 32
     ByteDelay                     : 0
     PollIndex                     : 3
     PollValue                     : 0x53
     Memory Detail                 :
                              Block Poll               Page                       Polled
       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
     Programmer Type : STK500
     Description     : Atmel STK500 Version 1.x firmware
     Hardware Version: 2
     Firmware Version: 1.18
     Topcard         : Unknown
     Vtarget         : 0.0 V
     Varef           : 0.0 V
     Oscillator      : Off
     SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0xffffff (probably .avr8x_mega) (retrying)
Reading error of bootloader
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
My man,
You lack library for running that program or code whatever.
better install a specified library to run it, without error.
Thanks for the answer.
But which type of library ?
I load Example => Arduino as isp,
then Arduino as ISP mode
then write bootloader.
The arduino uno r3 is working, the code is upload fine.
Where i wrong ?
@justinlucky - What are you talking about? Your response in nonsense.
@rel01 the fffffff is usualy down to no clock, or major miswiring. Can you show your schematic, and a close, in focus image of your PCB please.
Also, check the load capacitors are 22pF - this is a common error using wrong value capacitors.
port
Your nCS on the header should go to the reset pin of the 328.
If i connect D10 (of pcb) to reset (of UNO R3)
D13 to D13
D12 to D12
D11 to D11
GND to GND
5V to 5V
This is the error
Arduino:1.8.12 (Linux), Scheda:"Arduino Uno"
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Error bootloader writing.
I find the solution
D10 of UNO R3 to pin2 of H1 connector (reset of chip).
Thanks for the support.
D10 of Uno to Reset of Custom board, as you discovered.
