Error burning bootloader
Hello,
I am trying to burn the bootloader of a cnc xpro controller board (ATmega328pb) using an arduino due. I keep getting this error:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "ATmega328, Yes (UART1 328PB only), 328PB, BOD 2.7V, LTO disabled, 16 MHz external"
Using Port : COM16
Using Programmer : arduino
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x43
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x43
avrdude done. Thank you.
Error while burning bootloader.
Do you know how to fix this?
Did you upload the File > Examples > 11.ArduinoISP > ArduinoISP to the Due?
How do you have the Due connected to the ATmega328PB?
Yes. It worked perfectly.
I attached a photo of how I have it connected
I don't see the photo.
Here it is
You need to connect pin 10 on the Due to the reset pin on the ATmega328PB.
I did this but it doesn't work. Do you have any other ideas as to what else could be the problem?
I would use the SPI header
