In my program I try to return two values after performing operations in the "Durchfluss" method. These values should then be displayed in the loop. but when I display them I get 0 for f_ml1 and 170 for f_ml. why do I get 0 for the variable f_ml1? where is the error?
class Sensor {
float _flowRateTrinkwasser;
unsigned int _f_ml;
unsigned long _wasserMengeTrinkwasser;
float _flowRateReinwasser;
unsigned int _f_ml1;
unsigned long _wasserMengeReinwasser;
public:
Sensor( float flowRateTrinkwasser, unsigned int f_ml, unsigned long wasserMengeTrinkwasser, float flowRateReinwasser, unsigned int f_ml1, unsigned long wasserMengeReinwasser) { // Konstruktor
_flowRateTrinkwasser = flowRateTrinkwasser;
_f_ml = f_ml;
_wasserMengeTrinkwasser = wasserMengeTrinkwasser;
_flowRateReinwasser = flowRateReinwasser;
_f_ml1 = f_ml1;
_wasserMengeReinwasser = wasserMengeReinwasser;
Durchfluss() {
_flowRateTrinkwasser = 120; // Formel zur Berechnung von Flow Rate
_wasserMengeTrinkwasser = 50;
_f_ml = _flowRateTrinkwasser + _wasserMengeTrinkwasser ;
_flowRateReinwasser = 70;
_wasserMengeReinwasser = 40;
_f_ml1 = _flowRateReinwasser + _wasserMengeReinwasser;
return (_f_ml1, _f_ml);
#include "test.h"
//Durchflussmessung Variable Trinkwasser//
float flowRateTrinkwasser;
unsigned int f_ml;
unsigned long wasserMengeTrinkwasser;
//Durchflussmessung Variable Reinwasser//
float flowRateReinwasser;
unsigned int f_ml1;
unsigned long wasserMengeReinwasser;
Sensor sensorOne( flowRateTrinkwasser, f_ml, wasserMengeTrinkwasser, flowRateReinwasser, f_ml1, wasserMengeReinwasser ); // Objekt vom Konstruktor Sensor1
(f_ml1, f_ml) = sensorOne.Durchfluss();
Serial.println(f_ml1);
Serial.println(f_ml);
