The code compiling got error need help please.
Thanks.
Adam
#include <LiquidCrystal.h> // include Arduino LCD library
// LCD module connections (RS, E, D4, D5, D6, D7)
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);
#include "ACDC.h"
void setup(void)
lcd.begin(16, 2); // set up the LCD's number of columns and rows
lcd.setCursor(1, 0);
lcd.print("Voltage:");
// analog comparator ISR
ISR (ANALOG_COMP_vect)
byte count = 0;
for (byte i = 0; i < 50; i++) {
if ( ACSR & 0x20 )
count++;
if (count > 48)
per++;
// main loop
ACDC.ACDCLoop();
void ch_select(byte n) {
switch (n) {
case 0:
digitalWrite(CH0, HIGH);
digitalWrite(CH1, LOW);
digitalWrite(CH2, LOW);
digitalWrite(CH3, LOW);
case 1:
digitalWrite(CH0, LOW);
digitalWrite(CH1, HIGH);
case 2:
digitalWrite(CH2, HIGH);
case 3:
digitalWrite(CH3, HIGH);
current_res = res_table[n];
SUB:
class ACDCMeter {
//// private:
// define autoranging channel pins
#define CH0 2
#define CH1 3
#define CH2 4
#define CH3 5
const uint16_t Time_Out = 50000, // time out in microseconds
Periods = 10; // number of periods of measurement (for AC voltage only)
// variables
byte ch_number;
const uint16_t res_table[4] = {2444, 244, 94, 47}, // voltage divider resistances in tenths kOhms
total_res = 22444; // total resistance in tenths kOhms
uint16_t current_res;
volatile byte per;
//// public:
void ACDCSetup(void)
pinMode(CH0, OUTPUT);
pinMode(CH1, OUTPUT);
pinMode(CH2, OUTPUT);
pinMode(CH3, OUTPUT);
ch_number = 0;
ch_select(ch_number);
// ADC and analog comparator configuration
ADMUX = 0x03;
ADCSRA = 0x87;
ADCSRB = (0 << ACME); // select AIN1 as comparator negative input
ACSR = 0x13; // turn on analog comparator
// main loop
void ACDCLoop()
bool dc_flag = 0; // DC voltage flag bit
int32_t sum = 0; // sum of all readings
uint16_t n = 0; // number of readings (samples)
ACSR = (1 << ACI); // clear analog comparator interrupt flag
ACSR = (1 << ACIE); // enable analog comparator interrupt
uint32_t current_m = micros(); // save current millis
byte current_per = per; // save current period number
while ( (current_per == per) && (micros() - current_m < Time_Out) ) ;
if( micros() - current_m >= Time_Out ) { // if there's time out event ==> voltage signal is DC
dc_flag = 1;
for (byte i = 0; i < 200; i++) {
ADCSRA |= 1 << ADSC; // start conversion
while(ADCSRA & 0x40); // wait for conversion complete
int16_t an = (int16_t)(ADCL | (uint16_t)ADCH << 8) - 511;
sum += an;
n++; // increment number of readings
delay(1);
else { // here, voltage signal is AC
current_m = micros(); // save current millis()
per = 0;
while ( (per < Periods) && (micros() - current_m < (uint32_t)Time_Out * Periods) ) {
int32_t an = (int16_t)(ADCL | (uint16_t)ADCH << 8) - 511;
sum += sq(an); // sq: square
ACSR = (0 << ACIE); // disable analog comparator interrupt
uint32_t total_time = micros() - current_m; // used to claculate frequency
// voltage calculation
float v;
if(dc_flag) // if voltage signal is DC
v = (4 * sum)/n; // calculate Arduino analog channel DC voltage in milli-Volts
else // here voltage signal is AC
v = 4 * sqrt(sum/n); // calculate Arduino analog channel RMS voltage in milli-Volts
// claculate actual (input) voltage in milli-Volts (apply voltage divider equation)
v = v * (float)total_res/current_res;
v /= 1000; // get voltage in Volts
uint16_t v_abs = abs(int16_t(v));
if( (v_abs >= 10 && ch_number == 0) || (v_abs >= 100 && ch_number == 1) || (v_abs >= 250 && ch_number == 2) ) {
ch_number++;
delay(10);
return;
if( (v_abs < 220 && ch_number == 3) || (v_abs < 80 && ch_number == 2) || (v_abs < 8 && ch_number == 1) ) {
ch_number--;
delay(10);
return;
char _buffer[8];
lcd.setCursor(0, 1);
if( v < 0)
lcd.print('-');
lcd.print(' ');
if(v_abs < 10)
sprintf( _buffer, "%01u.%02u", v_abs, abs((int16_t)(v * 100)) % 100 );
else if( v_abs < 100)
sprintf( _buffer, "%02u.%01u", v_abs, abs((int16_t)(v * 10)) % 10 );
sprintf( _buffer, "%03u ", v_abs );
lcd.print(_buffer);
if(dc_flag)
lcd.print("VDC ");
else {
lcd.print("VAC ");
// calculate signal frequency in Hz
uint32_t period_time = total_time/Periods;
float freq = 1000000.0/period_time;
sprintf( _buffer, "%02u.%02uHz", (uint16_t)freq % 100, (uint16_t)(freq * 100) % 100 );
lcd.print(_buffer);
delay(500); // wait half a second
ACDCMeter ACDC;
ERROR:
Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_421210 -warnings=none -build-cache C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_cache_812812 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\HUA.DELLV-PC\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries -fqbn=arduino:avr:uno -ide-version=10813 -build-path C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_421210 -warnings=none -build-cache C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_cache_812812 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\sketch\\0_Auto_Range_Vmeter_M2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for LiquidCrystal.h: [LiquidCrystal-1.0.7@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal-1.0.7@1.0.7]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\sketch\\0_Auto_Range_Vmeter_M2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\LiquidCrystal-1.0.7\src\LiquidCrystal.cpp
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\sketch\\0_Auto_Range_Vmeter_M2.ino.cpp" -o "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Users\\HUA.DELLV-PC\\Documents\\Arduino\\libraries\\LiquidCrystal-1.0.7\\src" "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\sketch\\0_Auto_Range_Vmeter_M2.ino.cpp" -o "C:\\Users\\HUA~1.DEL\\AppData\\Local\\Temp\\arduino_build_421210\\sketch\\0_Auto_Range_Vmeter_M2.ino.cpp.o"
In file included from E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino:14:0:
C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_421210\sketch\ACDC.h: In member function 'void ACDCMeter::ACDCSetup()':
ACDC.h:40:3: error: 'ch_select' was not declared in this scope
C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_421210\sketch\ACDC.h: In member function 'void ACDCMeter::ACDCLoop()':
ACDC.h:108:5: error: 'ch_select' was not declared in this scope
ACDC.h:115:5: error: 'ch_select' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino: In function 'void __vector_23()':
0_Auto_Range_Vmeter_M2:74:5: error: 'per' was not declared in this scope
per++;
E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino: In function 'void loop()':
0_Auto_Range_Vmeter_M2:81:18: error: 'void ACDCMeter::ACDCLoop()' is private within this context
ACDC.ACDCLoop();
C:\Users\HUA~1.DEL\AppData\Local\Temp\arduino_build_421210\sketch\ACDC.h:52:6: note: declared private here
void ACDCLoop()
E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino: In function 'void ch_select(byte)':
0_Auto_Range_Vmeter_M2:112:3: error: 'current_res' was not declared in this scope
0_Auto_Range_Vmeter_M2:112:17: error: 'res_table' was not declared in this scope
E:\ENGINEERING\DIY\Electronic\meter\Arduino Multimeter\03_Arduino Based Autoranging AC-DC Voltmeter with TRMS\0_Auto_Range_Vmeter_M2\0_Auto_Range_Vmeter_M2.ino:112:17: note: suggested alternative: 'Printable'
Printable
Using library LiquidCrystal-1.0.7 at version 1.0.7 in folder: C:\Users\HUA.DELLV-PC\Documents\Arduino\libraries\LiquidCrystal-1.0.7
exit status 1
