Hello,
I have got this error and I don't know what it means nor can I find any information about it.
Can anyone tell me what the problem is and perhaps a solution?
Code: LoRa cpp
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
#include <LoRa.h>
#include <SPI.h>
// registers
#define REG_FIFO 0x00
#define REG_OP_MODE 0x01
#define REG_FRF_MSB 0x06
#define REG_FRF_MID 0x07
#define REG_FRF_LSB 0x08
#define REG_PA_CONFIG 0x09
#define REG_OCP 0x0b
#define REG_LNA 0x0c
#define REG_FIFO_ADDR_PTR 0x0d
#define REG_FIFO_TX_BASE_ADDR 0x0e
#define REG_FIFO_RX_BASE_ADDR 0x0f
#define REG_FIFO_RX_CURRENT_ADDR 0x10
#define REG_IRQ_FLAGS 0x12
#define REG_RX_NB_BYTES 0x13
#define REG_PKT_SNR_VALUE 0x19
#define REG_PKT_RSSI_VALUE 0x1a
#define REG_MODEM_CONFIG_1 0x1d
#define REG_MODEM_CONFIG_2 0x1e
#define REG_PREAMBLE_MSB 0x20
#define REG_PREAMBLE_LSB 0x21
#define REG_PAYLOAD_LENGTH 0x22
#define REG_MODEM_CONFIG_3 0x26
#define REG_FREQ_ERROR_MSB 0x28
#define REG_FREQ_ERROR_MID 0x29
#define REG_FREQ_ERROR_LSB 0x2a
#define REG_RSSI_WIDEBAND 0x2c
#define REG_DETECTION_OPTIMIZE 0x31
#define REG_INVERTIQ 0x33
#define REG_DETECTION_THRESHOLD 0x37
#define REG_SYNC_WORD 0x39
#define REG_INVERTIQ2 0x3b
#define REG_DIO_MAPPING_1 0x40
#define REG_VERSION 0x42
#define REG_PA_DAC 0x4d
#define LORA_DEFAULT_SPI_FREQUENCY 250000
// modes
#define MODE_LONG_RANGE_MODE 0x80
#define MODE_SLEEP 0x00
#define MODE_STDBY 0x01
#define MODE_TX 0x03
#define MODE_RX_CONTINUOUS 0x05
#define MODE_RX_SINGLE 0x06
// PA config
#define PA_BOOST 0x80
// IRQ masks
#define IRQ_TX_DONE_MASK 0x08
#define IRQ_PAYLOAD_CRC_ERROR_MASK 0x20
#define IRQ_RX_DONE_MASK 0x40
#define MAX_PKT_LENGTH 255
LoRaClass::LoRaClass() :
_spiSettings(LORA_DEFAULT_SPI_FREQUENCY, MSBFIRST, SPI_MODE0),
[b]_spi(&LORA_DEFAULT_SPI),[/b]
_ss(LORA_DEFAULT_SS_PIN),
_reset(LORA_DEFAULT_RESET_PIN), _dio0(LORA_DEFAULT_DIO0_PIN),
_frequency(0),
_packetIndex(0),
_implicitHeaderMode(0),
_onReceive(NULL)
// overide Stream timeout value
setTimeout(0);
int LoRaClass::begin(long frequency)
#ifdef ARDUINO_SAMD_MKRWAN1300
pinMode(LORA_IRQ_DUMB, OUTPUT);
digitalWrite(LORA_IRQ_DUMB, LOW);
// Hardware reset
pinMode(LORA_BOOT0, OUTPUT);
digitalWrite(LORA_BOOT0, LOW);
pinMode(LORA_RESET, OUTPUT);
digitalWrite(LORA_RESET, HIGH);
delay(200);
digitalWrite(LORA_RESET, LOW);
delay(200);
delay(50);
#endif
// setup pins
pinMode(_ss, OUTPUT);
// set SS high
digitalWrite(_ss, HIGH);
if (_reset != -1) {
pinMode(_reset, OUTPUT);
// perform reset
digitalWrite(_reset, LOW);
delay(10);
digitalWrite(_reset, HIGH);
delay(10);
// start SPI
_spi->begin();
// check version
uint8_t version = readRegister(REG_VERSION);
if (version != 0x12) {
return 0;
// put in sleep mode
sleep();
// set frequency
setFrequency(frequency);
// set base addresses
writeRegister(REG_FIFO_TX_BASE_ADDR, 0);
writeRegister(REG_FIFO_RX_BASE_ADDR, 0);
// set LNA boost
writeRegister(REG_LNA, readRegister(REG_LNA) | 0x03);
// set auto AGC
writeRegister(REG_MODEM_CONFIG_3, 0x04);
// set output power to 17 dBm
setTxPower(17);
// put in standby mode
idle();
return 1;
void LoRaClass::end()
sleep();
// stop SPI
_spi->end();
int LoRaClass::beginPacket(int implicitHeader)
if (isTransmitting()) {
return 0;
idle();
if (implicitHeader) {
implicitHeaderMode();
explicitHeaderMode();
// reset FIFO address and paload length
writeRegister(REG_FIFO_ADDR_PTR, 0);
writeRegister(REG_PAYLOAD_LENGTH, 0);
return 1;
int LoRaClass::endPacket(bool async)
// put in TX mode
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_TX);
if (async) {
// grace time is required for the radio
delayMicroseconds(150);
// wait for TX done
while ((readRegister(REG_IRQ_FLAGS) & IRQ_TX_DONE_MASK) == 0) {
yield();
// clear IRQ's
writeRegister(REG_IRQ_FLAGS, IRQ_TX_DONE_MASK);
return 1;
bool LoRaClass::isTransmitting()
if ((readRegister(REG_OP_MODE) & MODE_TX) == MODE_TX) {
return true;
if (readRegister(REG_IRQ_FLAGS) & IRQ_TX_DONE_MASK) {
// clear IRQ's
return false;
int LoRaClass::parsePacket(int size)
int packetLength = 0;
int irqFlags = readRegister(REG_IRQ_FLAGS);
if (size > 0) {
writeRegister(REG_PAYLOAD_LENGTH, size & 0xff);
// clear IRQ's
writeRegister(REG_IRQ_FLAGS, irqFlags);
if ((irqFlags & IRQ_RX_DONE_MASK) && (irqFlags & IRQ_PAYLOAD_CRC_ERROR_MASK) == 0) {
// received a packet
_packetIndex = 0;
// read packet length
if (_implicitHeaderMode) {
packetLength = readRegister(REG_PAYLOAD_LENGTH);
packetLength = readRegister(REG_RX_NB_BYTES);
// set FIFO address to current RX address
writeRegister(REG_FIFO_ADDR_PTR, readRegister(REG_FIFO_RX_CURRENT_ADDR));
idle();
} else if (readRegister(REG_OP_MODE) != (MODE_LONG_RANGE_MODE | MODE_RX_SINGLE)) {
// not currently in RX mode
// put in single RX mode
writeRegister(REG_OP_MODE, MODE_LONG_RANGE_MODE | MODE_RX_SINGLE);
I couldn't add all the code. If it is needed I will post. I already added the LoRa.h library aswell.
