Hello,
I am new to Arduino and I am getting this error: Cmd_Read_Act();.
Would you please be so kind to advice on this one please?
I am attaching the file.
Thank you
SoftwareSerialExample_test_1.ino (2.24 KB)
Hello,
Thank you
I found more info in my error:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\owner\Documents\Arduino\SoftwareSerialExample_test_1\SoftwareSerialExample_test_1.ino: In function 'void loop()':
SoftwareSerialExample_test_1:73:18: error: 'Cmd_Read_Act' was not declared in this scope
Cmd_Read_Act();
SoftwareSerialExample_test_1:74:22: error: 'clearBufferArray' was not declared in this scope
clearBufferArray();
exit status 1
Invalid library found in C:\Users\owner\Documents\Arduino\libraries\from_led9_test: no headers files (.h) found in C:\Users\owner\Documents\Arduino\libraries\from_led9_test
Invalid library found in C:\Users\owner\Documents\Arduino\libraries\prectice: no headers files (.h) found in C:\Users\owner\Documents\Arduino\libraries\prectice
Invalid library found in C:\Users\owner\Documents\Arduino\libraries\smsLed9: no headers files (.h) found in C:\Users\owner\Documents\Arduino\libraries\smsLed9
option enabled in File -> Preferences.
The error message told the truth. You are calling functions that were never declared. Where did this code come from?
thank you replaying. this what I am doing, I took a base code from Arduino plus I am inserting another code where I want to turn on an LED via text. If declare it it should work then? the thing is that I am not sure what I should declare.
Techvic22:
Where did you get this "base code"?
Techvic22:
If you declare and define those functions correctly, then yes it will work.
Techvic22:
Me neither, because you haven't provided enough information. You found some code somewhere, but you won't say where. You made some changes to that code, but since I can't see the original code I can't tell what the changes were.
Please post your code in code tags. If unsure what that is please read this as it contains important information on how to post in order to maximize the help you will get here. Read this before posting a programming question ... - Programming Questions - Arduino Forum
