This has been bugging me for a few days and I keep coming back to it and having little sessions trying to work it out but frustratingly (considering how simple I know this will turn out to be) none of my attempts to guess how to fix it have prevailed.
Here is the piece of code that I keep getting the error message: "expected primary-expression before 'if'" on my 'if else' statement
#include <NewPing.h>
#define TRIGGER_PIN 21
#define ECHO_PIN 22
#define TRIGGER_PIN2 23
#define ECHO_PIN2 24
#define TRIGGER_PIN3 25
#define ECHO_PIN3 26
#define MAX_DISTANCE 300
NewPing Front(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
NewPing Left(TRIGGER_PIN2, ECHO_PIN2, MAX_DISTANCE);
NewPing Right(TRIGGER_PIN3,ECHO_PIN3, MAX_DISTANCE);
int motorpin1 = 2;
Serial.begin(115200); //(115200)
pinMode(pin1,OUTPUT);
delay(50);
int uS = Front.ping();
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM);
Serial.println("Front cm");
delay(50)
(if (Front.ping < 50));
int qT = Left.ping();
Serial.print(qT / US_ROUNDTRIP_CM);
Serial.println("Left cm");
delay(50);
int gU = Right.ping();
Serial.print(gU / US_ROUNDTRIP_CM);
Serial.println("Right cm");
delay(50);
analogWrite(pin1, 100);
I have tried adding and taking away various types of peculiar brackets eg (, { and [ but none of these have fixed it.
Looking at the Arduino reference pages for 'if' and 'else' I haven't been able to find any thing that should be before the 'if' statment.
I haven't been able to find a list of primary expressions to try before 'if' so if someone could give me a few of those or help look over this code for me (I expect i'm just ignorant when it comes to Arduino) then that would be greatly appreciated.
This is wrong.:-
(if (Front.ping < 50));{
Should be:-
if (uS < 50)
or
if (Front.ping() < 50)
But even that won't do what you want, since I assume you're checking that the distance is less than 50cm, not 50us.
I could write it for you, but it's better practice if you re-write the code to do what you're aiming for.
It better beif (Front.ping() < 50) {
or, because the value is already thereif (uS < 50) {
Oops, missed it - you also left the semicolon off the end of first of these:-
delay(50)
Thanks alot guys, I'll have another crack at writing it to make sure it's checking the distance in the correct units
Having made the changes you suggested it still doesn't seem to identify the 'if' part of the statment and I know get the error: 'else' without a previous 'if'.
Does anybody have any ideas as to what might be causing this?
I just caught that missed semicolon as I made the changes you suggested, the code is now:
#define ECHO_PIN 22
//#define MAX_DISTANCE 200
int motorpin1 = 2;
int motorpin2 = 3;
pinMode(motorpin1,OUTPUT);
pinMode(motorpin2,OUTPUT);
delay(50);
delay(50);
if (uS < 50) ; //change 50 to 10cm more than the distance required by the chassis to carry out a 90 degree turn with the servo set at 30 degrees
delay(50);
delay(50);
analogWrite(motorpin1, 100); // Test whether it needs to be motorpin 1 or 2 and the best value
Anybody have any ideas as to why it won't recognise the 'if'?
324632985738274:
Because you still have a semicolon at the end of the 'if' statement.:-if (uS < 50) ;
Lose that semicolon.
And you can make things easier for yourself by using the library's 'ping_cm()' method. No need to do a separate conversion.:-
int cm = Front.ping_cm();
Edit: Just one other small point, although you're doing nothing wrong - it's better to identify the analogue pins with an "A" prefix to avoid confusion.
Forget this. God only knows what I was thinking.
OldSteve:
ie
int motorpin1 = A2;
int motorpin2 = A3;
Nope.
The sketch does not use analog inputs, so this is totally wrong.
oqibidipo:
Nope.
Oh @#$%, I don't know what I was thinking. You are correct.
Quite embarrassed, I don't know how I made such a stupid mistake.
(Hanging my head in shame.)
Sorry @324632985738274
