I'm trying to read out a conductivity sensor through a MKR-Board with the RS485 shield attached.
I'm using RTU-Modbus and the ArduinoModbus library.
The function "lastError()" returns "Connection timed out" error.
What does this mean? How can I fix it?
Thanks for the help!
#include <ArduinoModbus.h>
float temperature;
float humidity;
while (!Serial);
Serial.println("Modbus conductivity Sensor");
// start the Modbus RTU client
if (!ModbusRTUClient.begin(38400))
Serial.println("Failed to start Modbus RTU Client!");
while (1);
// send a Holding registers read request to (slave) id 247, for 2 registers
if (!ModbusRTUClient.requestFrom(247, HOLDING_REGISTERS, 0x00, 45))
Serial.print("failed to read registers! ");
Serial.println(ModbusRTUClient.lastError());
// If the request succeeds, the sensor sends the readings, that are
// stored in the holding registers. The read() method can be used to
// get the raw temperature and the humidity values.
short conductivity = ModbusRTUClient.read();
// To get the temperature in Celsius and the humidity reading as
// a percentage, divide the raw value by 10.0.
Serial.println(conductivity);
delay(5000);
It sounds like the other device has not responded in time. Did you have a look at the code for ArduinoModbus to see under what circumstances this error is raised?
That usually means there's no connection to the slave device. That can have multiple reasons, some of them in hardware (we have no clue about your wiring or the about the slave device) or in software (did you check the serial parameters? Parity is a good candidate, official Modbus standard has a parity bit).
I checked the documentation for the library here: ArduinoModbus - Arduino Reference
There's no documentation where it explains which error is returned under which circumstances.
Here's the wiring diagram I'm using. The sensor is a conductivity sensor.
mbe4ever:
