Error Code Help Air Quality Wing
I'm trying to get the Air Quality Wing to work with Adafruit feather boards and I'm using Arduino IDE when they were created for particle boards. They are compatible with the feather boards, but Arduino IDE is not supported. I'm trying to fix the code to work in Arduino. Here are my errors.
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::setup(ccs811_init_t*)':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:35:26: error: 'INPUT' was not declared in this scope
pinMode(this->int_pin, INPUT);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:35:31: error: 'pinMode' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:36:63: error: 'FALLING' was not declared in this scope
attachInterrupt(this->int_pin, & CCS811::int_handler, this, FALLING);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:36:70: error: 'attachInterrupt' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:39:27: error: 'OUTPUT' was not declared in this scope
pinMode(this->wake_pin, OUTPUT);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:40:32: error: 'LOW' was not declared in this scope
digitalWrite(this->wake_pin, LOW); // Has a pullup
/tmp/728363207/AirQualityWingExample/ccs811.cpp:40:35: error: 'digitalWrite' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:45:10: error: 'delay' was not declared in this scope
delay(1);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:55:3: error: 'Wire' was not declared in this scope
Wire.beginTransmission(this->address);
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::set_env(float, float)':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:98:41: error: 'memcpy' was not declared in this scope
memcpy(data,&hum_conv,sizeof(hum_conv));
/tmp/728363207/AirQualityWingExample/ccs811.cpp:102:3: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::enable()':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:116:3: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::save_baseline()':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:144:3: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:154:3: error: 'EEPROM' was not declared in this scope
EEPROM.put(CCS811_BASELINE_ADDR, baseline);
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::restore_baseline()':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:165:3: error: 'EEPROM' was not declared in this scope
EEPROM.get(CCS811_BASELINE_ADDR, baseline);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:173:3: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::read(ccs811_data_t*)':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:193:7: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::get_app_version(ccs811_app_ver_t*)':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:223:3: error: 'Wire' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp: In member function 'uint32_t CCS811::update_app(const ccs811_app_update_t*)':
/tmp/728363207/AirQualityWingExample/ccs811.cpp:283:3: error: 'Serial' was not declared in this scope
Serial.println("start update");
/tmp/728363207/AirQualityWingExample/ccs811.cpp:287:26: error: 'OUTPUT' was not declared in this scope
pinMode(this->rst_pin, OUTPUT);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:287:32: error: 'pinMode' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:288:31: error: 'LOW' was not declared in this scope
digitalWrite(this->rst_pin, LOW);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:288:34: error: 'digitalWrite' was not declared in this scope
/tmp/728363207/AirQualityWingExample/ccs811.cpp:289:10: error: 'delay' was not declared in this scope
delay(1);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:290:26: error: 'INPUT' was not declared in this scope
pinMode(this->rst_pin, INPUT);
/tmp/728363207/AirQualityWingExample/ccs811.cpp:299:3: error: 'Wire' was not declared in this scopeError Code Hel
/tmp/728363207/AirQualityWError Code HelingExample/ccs811.cpp:329:30: error: 'memcpy' was not declared in this scope
memcpy(&payload[1],data,8);
Here is the code I'm having trouble with.
  • Project Particle Squared
  • Description: Particle powered PM2.5 and air quality sensor
  • Author: Jared Wolff
  • Date: 2/26/2019
  • License: GNU GPLv3
#include "ccs811.h"
CCS811::CCS811() {}
void CCS811::int_handler() {
this->data_ready = true;
uint32_t CCS811::setup( ccs811_init_t * p_init ) {
// Return an error if init is NULL
if( p_init == NULL ) {
return CCS811_NULL_ERROR;
// Configures the important stuff
this->int_pin = p_init->int_pin;
this->address = p_init->address;
this->rst_pin = p_init->rst_pin;
this->wake_pin = p_init->wake_pin;
// Configure the pin interrupt
// Wake it up
// Toggle reset pin
delay(1);
delay(30);
#include "stdint.h"
#include "stdio.h"
// Run the app
Wire.write(CCS811_START_APP); // sends register address
Wire.endTransmission(); // stop transaction
delay(30);
Wire.write(CCS811_STATUS_REG);
Wire.requestFrom(this->address,(uint8_t)1);
uint8_t status = Wire.read();
// Checks if the app is running
if( status & CCS811_FW_MODE_RUN ) {
return CCS811_SUCCESS;
return CCS811_RUN_ERROR;
uint32_t CCS811::set_env(float temp, float hum) {
// Shift left b/c this register is shifted left by 1
uint8_t hum_conv[2];
hum_conv[0] = (uint8_t)hum << 1;
hum_conv[1] = 0; // Not bothering with sending fraction
// Serial.printf("temp %.2f", temp);
// Serial.printf("hum %.2f", hum);
// Serial.printf("frac %.2f", frac_part);
// Generate the calculated values
uint8_t temp_conv[2];
temp_conv[0] = (((uint8_t)temp + 25) << 1);
temp_conv[1] = 0; // Not bothering with sending fraction
// Data to send
uint8_t data[4];
// Copy bytes to output
memcpy(data+2,&temp_conv,sizeof(temp_conv));
// Write this
Wire.write(CCS811_ENV_REG);
Wire.write(data,sizeof(data));
uint32_t CCS811::enable(void) {
uint32_t err_code;
// Set mode to 10 sec mode & enable int
Wire.write(CCS811_MEAS_MODE_REG); // sends register address
Wire.write(CCS811_CONSTANT_MODE | CCS811_INT_EN); // enables consant mode with interrupt
err_code = Wire.endTransmission(); // stop transaction
if( err_code != 0 ){
return err_code;
// Clear any interrupts
Wire.write(CCS811_RESULT_REG); // sends register address
err_code = Wire.endTransmission(false); // stop transaction
return err_code;
// Flush bytes
Wire.requestFrom(this->address, (uint8_t)4); // Read the bytes
while(Wire.available()) {
Wire.read();
uint32_t CCS811::save_baseline() {
Wire.write(CCS811_BASELINE_REG); // sends register address
Wire.requestFrom(this->address, (uint8_t)2); // request the bytes
uint8_t baseline[2];
baseline[0] = Wire.read();
baseline[1] = Wire.read();
// Write to the address
uint32_t CCS811::restore_baseline() {
uint32_t err_code;
// Get the baseline to the address
// If it's uninitialized, return invalid data
if ( baseline[0] == 0xff && baseline[1] == 0xff) {
return CCS811_DAT_INVALID;
// Write to the chip
Wire.write(baseline[0]);
Wire.write(baseline[1]);
return err_code;
uint32_t CCS811::read(ccs811_data_t * p_data) {
// If the data is ready, read
if( this->data_ready ) {
  // Disable flag
  this->data_ready = false;
  Wire.requestFrom(this->address, (uint8_t)4); // request the bytes
  // Convert data to something useful
  p_data->c02 = Wire.read();
  p_data->c02 = (p_data->c02<<8) + Wire.read();
  p_data->tvoc = Wire.read();
  p_data->tvoc = (p_data->tvoc<<8) + Wire.read();
  // Serial.printf("c02: %dppm tvoc: %dppb\n",p_data->c02,p_data->tvoc);
  // If this value is < 400 not ready yet
  if ( p_data->c02 < CCS811_MIN_C02_LEVEL ) {
return CCS811_NO_DAT_AVAIL;
uint32_t CCS811::get_app_version(ccs811_app_ver_t * p_app_ver) {
uint32_t err_code;
Wire.write(CCS811_APP_VER_REG); // sends register address
if( err_code != 0) {
return CCS811_COMM_ERR;
uint8_t num_bytes = Wire.requestFrom(this->address, (uint8_t)2); // request the bytes
// If not enough bytes were read, error!
if( num_bytes != 2) {
uint8_t majorminor = Wire.read();
// MSB is split into two. First nibble major, second is the minor
p_app_ver->major = (majorminor >> 4) & 0x0f;
p_app_ver->minor = majorminor & 0x0f;
p_app_ver->trivial = Wire.read();
// Serial.printf("%x %x",majorminor,p_app_ver->trivial );
uint32_t CCS811::update_app(const ccs811_app_update_t * p_app_update) {
if( p_app_update == NULL ) {
ccs811_app_ver_t current_ver;
// Check the version
uint32_t err_code = this->get_app_version(&current_ver);
// Return if not success
if( err_code != 0 ) {
return err_code;
bool start_update = false;
// If any of the version information is not equal, update
if( p_app_update->ver.major > current_ver.major ||
p_app_update->ver.minor > current_ver.minor ) {
// start
start_update = true;
// Return if there's no update
if( !start_update ) {
return CCS811_NO_UPDATE_NEEDED;
// Otherwise there is an update
// Toggle reset pin
delay(1);
delay(30);
// Erase codee
uint8_t cmd[] = CCS811_ERASE_CODE;
Serial.println("erase");
// Begin the process
Wire.write(CCS811_ERASE_REG); // sends register address
Wire.write(cmd, sizeof(cmd));
// Set up for ops
uint32_t length = p_app_update->size;
uint8_t *data = p_app_update->data;
// Payload to be sent over I2C
uint8_t payload[9];
// Set first byte to the command
payload[0] = CCS811_WRITE_APP_REG;
// Calculate the iterations to run
uint32_t iterations = length/8;
Serial.printf("iterations %d", iterations);
for( uint32_t i = 0; i < iterations; i++ ) {
Serial.printf("%d\n",i);
// Copy 8 bytes
// Write said 8 bytes
Wire.write(payload, sizeof(payload)); // sends register address
// Delay
delay(50);
// Increment the pointer
data+=8;
// Verify
Wire.write(CCS811_VERIFY_REG); // sends register address
// Check the status
if ((status & 0x30) == 0x30){
// program code valid
Serial.println("Code is valid!");
else{
// program code invalid
return CCS811_UPDATE_VERIFY_FAIL;
