Error code of RTC
Hi all, I am trying to compiling the below code collected from one site but all time it shows error code. I would request your support.
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:25:21: error: no matching function for call to 'DS3231::DS3231(const uint8_t&, const uint8_t&)'
 DS3231  rtc(SDA, SCL); // Initiate the DS3231 Real Time Clock module using the I2C interface
In file included from C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:11:0:
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:73:3: note: candidate: DS3231::DS3231(TwoWire&)
   DS3231(TwoWire & w);
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:73:3: note:   candidate expects 1 argument, 2 provided
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:72:3: note: candidate: DS3231::DS3231()
   DS3231();
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:72:3: note:   candidate expects 0 arguments, 2 provided
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:68:7: note: candidate: constexpr DS3231::DS3231(const DS3231&)
 class DS3231 {
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:68:7: note:   candidate expects 1 argument, 2 provided
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:68:7: note: candidate: constexpr DS3231::DS3231(DS3231&&)
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:26:1: error: 'Time' does not name a type; did you mean 'time'?
 Time  t; // Init a Time-data structure
 time
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino: In function 'void setup()':
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:73:7: error: 'class DS3231' has no member named 'begin'
   rtc.begin();
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino: In function 'void loop()':
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:130:3: error: 't' was not declared in this scope
   t = rtc.getTime();
C:\Users\hp\Downloads\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:130:11: error: 'class DS3231' has no member named 'getTime'; did you mean 'getA1Time'?
   t = rtc.getTime();
           getA1Time
exit status 1
Compilation error: no matching function for call to 'DS3231::DS3231(const uint8_t&, const uint8_t&)'`
<#include "SoftwareSerial.h"
#include "MHZ19.h"   // https://github.com/WifWaf/MH-Z19
#include "PMS.h"     //https://github.com/fu-hsi/pms
#include "MQ131.h"   // https://github.com/ostaquet/Arduino-MQ131-driver
#include "dht.h"     // https://github.com/RobTillaart/DHTlib
#include "DS3231.h"  // http://www.rinkydinkelectronics.com/library.php?id=73
 * Pleas note that the code can be a bit complex. For each sensor module I'm using libraries which can be found in the links above. So in order to understand how everything works,
 * you must take a look at each library how it works by reading its instructions.
 * For calibrating the sensors also use the libraries documentation
 * Also note that the code is not very well optimized.
#define led 13
#define tvocPin 7  // VOC sensor activation
#define dht22 5 // DHT22 temperature and humidity sensor
dht DHT; // Creats a DHT object
MHZ19 myMHZ19;    // CO2 Sensor
SoftwareSerial co2Serial(2, 3);  // (RX, TX) MH-Z19 serial
SoftwareSerial pmsSerial(8, 9); // Particulate Matter sensor
PMS pms(pmsSerial);
PMS::DATA data;
unsigned long dataTimer = 0;
unsigned long dataTimer3 = 0;
unsigned long dataTimer4 = 0;
int readDHT, temp, hum;
int CO2;
int o3;
int tvoc;
int pm25;
int hours, minutes;
int previousMinutes = 1;
String timeString;
String receivedData = "Z";
// We store the last 24 hours sensor values  in arrays - store value each 15 minutes so for 24 hours we need 96 bytes.
// We must use bytes and can't increse the storing to let's say 5 mins because the Arduino Pro Mini has a limited dynamic memory
uint8_t tempData[96] = {};
uint8_t humData[96] = {};
uint8_t tvocData[96] = {};
uint8_t co2Data[96] = {};
uint8_t pm25Data[96] = {};
uint8_t o3Data[96] = {};
int8_t last24Hours[12] = {};
int yAxisValues[4] = {};
int maxV = 0;
int8_t r = 99;
  // Device to serial monitor feedback
  pinMode(6, OUTPUT);
  pinMode(tvocPin, OUTPUT);
  // Warming up sensors
  digitalWrite(6, HIGH);        // Ozone sensor
  digitalWrite(tvocPin, HIGH);  // TVOC sensor
  delay(20 * 1000); // delay 20 seconds
  digitalWrite(6, LOW);
  digitalWrite(tvocPin, LOW);
  // Initialize all sensors
  rtc.begin();
  co2Serial.begin(9600);
  pmsSerial.begin(9600);
  myMHZ19.begin(co2Serial);
  myMHZ19.autoCalibration(false);  // Turn auto calibration ON (OFF autoCalibration(false))
  MQ131.begin(6, A0, LOW_CONCENTRATION, 1000000); //
  MQ131.setTimeToRead(20); // Set how many seconds we will read from the Ozone sensor. It blocks flow
  MQ131.setR0(9000); // We get this value using the calirabrate() function from the Library calibration example
  // Read temperature and humidity from DHT22 sensor
  readDHT = DHT.read22(dht22); // Reads the data from the sensor
  temp = DHT.temperature; // Gets the values of the temperature
  hum = DHT.humidity; // Gets the values of the humidity
  // Read TVOC for 5 seconds
  delay(5000); // Blocking the programm - It would be best if the sensor heater is active all the time, we would get the most accurate values that way. The thing is that the sensers heats up quaite a lot and messes with the tempereture values. If better air circulation is provided to the case, that's the way to go.
  tvoc = analogRead(A1); // Please note that we are only reading raw data from this sensor, not ppm or ppb values. Just analog values from 0 to 1024. Higher values means there is a presence of VOC
  // Check for incoming data from the display - check whether we have licked a partucular sensor to for reading the last 24 hours
  checkForIncomingData();
  // Read MHZ19 - CO2 sensor for 3 seconds - if we don't use a blocking method with the while loop we won't get values from the sensor.
  co2Serial.listen();
  dataTimer = millis();
  while (millis() - dataTimer <= 3000) {
    CO2 = myMHZ19.getCO2(); // Request CO2 (as ppm)
  // we check for incoming data after each operation, because operation is blocking the program
  // Read Particulate Matter sensor for 2 seconds
  pmsSerial.listen();
  dataTimer3 = millis();
  while (millis() - dataTimer3 <= 1000) {
    pms.readUntil(data);
    pm25 = data.PM_AE_UG_2_5;
  // Read MQ131 Ozone sensor
  MQ131.sample();
  /* This is also a blocking function which is using delay.
     When callibrating the Ozone sensor you will notice that the reading time, in order to get stable readings is usually high, like more then a minute.
     But if we use it here just like that everyting will be freezed for that time. However, you can set the sampling time lower, but the output might not be accurate in such a case.
     Also,you set the ozone sensor heater to be active all the time in order to get more accurate results, but this may cause significant heat from the sensor so you would need a case fan in order to accurate values from the temp sensor.
     I suggest trying the library examples for calibrating and see what will get you test best results. I would also suggest not including this sensor in this project unless you really want it.
  o3 = MQ131.getO3(PPB);
  // Get the time from the DS3231 Real Time Clock module - For setting the time use the library example
  t = rtc.getTime();
  hours = t.hour;
  minutes = t.min;
  // Store current sensors data
  storeData();
  // Send the data to the Nextion display
  dataTimer4 = millis();
  while (millis() - dataTimer4 <= 200) {
    Serial.print("co2V.val=");
    Serial.print(CO2);
    // each command ends with these three unique write commands in order the data to be send to the Nextion display
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.print("pm25V.val=");
    Serial.print(pm25);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.print("o3V.val=");
    Serial.print(o3);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.print("tempV.val=");
    Serial.print(temp);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.print("humV.val=");
    Serial.print(hum);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.print("tvocV.val=");
    Serial.print(tvoc);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
void checkForIncomingData() {
  // Check if data is coming from the Nextion
  if (Serial.available() > 0) {
    receivedData = Serial.readString();
    delay(30);
    if (receivedData == "0") {
      r = 0;
    if (receivedData == "1") {
      r = 1;
    if (receivedData == "2") {
      r = 2;
    if (receivedData == "3") {
      r = 3;
    if (receivedData == "4") {
      r = 4;
  // if we have received any data, send data to the Nextion display to change to page 1, or the waveform
  if (r == 0 || r == 1 || r == 2 || r == 3 || r == 4) {
    delay(200);
    while (millis() - dataTimer3 <= 200) {
      Serial.print("pageSwitch.val="); // Activate page 1, or the waveform on the Nextion display
      Serial.print(1);
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
    delay(100);
    getLast24Hours(); // get the last 24 hours and print them on as X-axis values on the waveform
    getYAxisValues(); // get the Y-axis values according to the sensor, it's range and it's max value. Print the Y-axis values as well as scale the Y-axis of the wavefrom accordingly
    sendDataToWaveform(); // send the stored data of the last 24 hours to the waveform
    r = 99; // reset the "r" to 99(arbitrary number, different than the ones we assign when we receive data depending on which sensor we have pressed)
void storeData() {
  // Storing current sensor values into arrays
  if ((minutes - previousMinutes) >= 15) {  // store the value each 15 minutes
    memmove(tempData, &tempData[1], sizeof(tempData)); // Slide data down one position
    tempData[sizeof(tempData) - 1] = temp; // store newest value to last position
    memmove(humData, &humData[1], sizeof(humData));
    humData[sizeof(humData) - 1] = hum;
    memmove(tvocData, &tvocData[1], sizeof(tvocData));
    // we use bytes for storing the data, as we said the Arduino Pro mini doesn't have enough memory, so we must convert the values from 0 to 1000 to 0 to 255 which is one byte
    tvocData[sizeof(tvocData) - 1] = map(tvoc, 0, 1000, 0, 255);
    memmove(co2Data, &co2Data[1], sizeof(co2Data));
    co2Data[sizeof(co2Data) - 1] = map(CO2, 0, 3000, 0, 255);
    memmove(pm25Data, &pm25Data[1], sizeof(pm25Data));
    pm25Data[sizeof(pm25Data) - 1] = map(pm25, 0, 1000, 0, 255);
    memmove(o3Data, &o3Data[1], sizeof(o3Data));
    o3Data[sizeof(o3Data) - 1] = map(o3, 0, 1000, 0, 255);
    previousMinutes = minutes;
  // So these if statemets check whether have passed 15 mins since the last time we stored a value - you can change this to any minutes you want, but you need to do that on both if statemets, for example "10" in the first if statement, and "-50" in the second if statement
  else if ((minutes - previousMinutes) == -45) { // when minutes start from 0, next hour
void getLast24Hours() {
  for (int i = 11; i >= 0; i--) {
    last24Hours[11] = hours; // get the current hour - according to this hour get 12 more hours, each 2 hours. For example, current hour = 13, so 11, 9, 7...
    last24Hours[i - 1] = last24Hours[i] - 2;
    if (last24Hours[i - 1] < 0) {
      for (int k = -0; k > -11; k--) {
        if (last24Hours[i - 1] == k) {
          last24Hours[i - 1] = 24 + k;
  // send the hours values to the Nextion display
  for (int i = 0; i < 12; i++) {
    String last24 = ("n") + String(i) + String(".val=") + String(last24Hours[i]); // e.g. for i=0 > "n0.val="
    Serial.print(last24);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    delay(20);
  // Another write just to make sure it sends all data
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    delay(20);
// With the following custom function we set the Y axis value for each sensor individually, as each sensor has different maximum value for the Y axis
void getYAxisValues() {
  maxV = 0;
  // PM2.5 Y-axis values
  if (r == 0) {
    // Get the max sensor value from the last 24 hours
    for (int i = 0; i < sizeof(pm25Data); i++) {
      if (maxV < map(pm25Data[i], 0, 255, 0, 1000)) {
        maxV = map(pm25Data[i], 0, 255, 0, 1000);
    // Setting the Y-axis values and scaling the waveform
    if (maxV <= 100) {
      yAxisValues[0] = 25;
      yAxisValues[1] = 50;
      yAxisValues[2] = 75;
      yAxisValues[3] = 100;
      Serial.print("s0.dis="); // this command ".dis" is used for scalign the Y-axis
      Serial.print(78 * 10);  // scale the waveform Y-axis - pm2.5 values are from 0 to 1000 which are represented from 0 to 78% in the Y axis - 78% because the wavefore is 200px which is 78% of 255 which is the default 100% value of the waveform - 78*10 because we show values from 0 to 100, which are 10 times smaller
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
    // if the value is higher than 100, get its max value, and according to it scale the y-axis - For example, if the max value is 235, set the max value of the Y-axis to 300 - 235/100=2+1=3*100=300
    else if (maxV > 100) {
      int l = ((maxV / 100) + 1) * 100;  // get the hundreds value so we can properly scale the Y axis of the waveform
      yAxisValues[0] = l / 4;
      yAxisValues[1] = l / 2;
      yAxisValues[2] = l * 3 / 4;
      yAxisValues[3] = l;
      float ll = 78.0 / (l / 1000.0); // scale value for the Y-axis in % - We multiply by 78 instead of 100 because our waveform is 200px in height, which is 78% of 255 (255 is max value the waveform can accept, 1 byte)
      Serial.print(round(ll));
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
  // TVOC Y-axis values
  if (r == 2) {
    for (int i = 0; i < sizeof(tvocData); i++) {
      if (maxV < map(tvocData[i], 0, 255, 0, 1000)) {
        maxV = map(tvocData[i], 0, 255, 0, 1000);
    if (maxV <= 100) {
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
      yAxisValues[3] = l;
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
  // Ozone Y-axis values
  if (r == 3) {
    for (int i = 0; i < sizeof(o3Data); i++) {
      if (maxV < map(o3Data[i], 0, 255, 0, 1000)) {
        maxV = map(o3Data[i], 0, 255, 0, 1000);
    if (maxV <= 100) {
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
      yAxisValues[3] = l;
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
  // CO2 Y-axis values are fixed from 0 to 3000 so we don't need to look for the max value in the array
  if (r == 1) {
    for (int i = 0; i < sizeof(co2Data); i++) {
      if (maxV < map(co2Data[i], 0, 255, 0, 3000)) {
        maxV = map(co2Data[i], 0, 255, 0, 3000);
    if (maxV <= 2000) {
      yAxisValues[0] = 500;
      yAxisValues[1] = 1000;
      yAxisValues[2] = 1500;
      yAxisValues[3] = 2000;
      Serial.print(117);  // scale the waveform from 0 - 3000 to 0 - 2000 range
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
    if (maxV > 2000) {
      yAxisValues[0] = 750;
      yAxisValues[1] = 1500;
      yAxisValues[2] = 2250;
      yAxisValues[3] = 3000;
      Serial.print(78);
      Serial.write(0xff);
      Serial.write(0xff);
      Serial.write(0xff);
  // Temperature and Humidity Y-axis values - fixed from 0 to 100
  if (r == 4) {
    Serial.print(200); // from 0 to 100 - 255/100 * 78 = ~200
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
  delay(50);
  // Send the  Y-axis values to the Nextion display
  for (int i = 0; i < 4; i++) {
    String yValues = ("y") + String(i) + String(".val=") + String(yAxisValues[i]); // e.g. for i=0 > "y0.val="
    Serial.print(yValues);
    Serial.write(0xff);
    Serial.write(0xff);
    Serial.write(0xff);
    delay(10);
void sendDataToWaveform() {
  int k = 0;
  while (k != 2) {
    String str = String("addt 1,0,") + String(288); // with this command we tell the nextion display that we will send an array of data to the waveform
    Serial.print(str);
    delay(100);
    Serial.write(0xFF);
    Serial.write(0xFF);
    Serial.write(0xFF);
    delay(100);
    // Now depending on the selected sensor we want the values stored in the arrays
    // PM2.5
    if (r == 0) {
      for (int t = 0; t < sizeof(pm25Data); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(pm25Data[t]);
          z++;
    // CO2
    if (r == 1) {
      for (int t = 0; t < sizeof(co2Data); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(co2Data[t]);
          z++;
    // TVOC
    if (r == 2) {
      for (int t = 0; t < sizeof(tvocData); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(tvocData[t]);
          z++;
    // Ozone
    if (r == 3) {
      // Temperature values on channel 0
      for (int t = 0; t < sizeof(o3Data); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(o3Data[t]);
          z++;
    // Temp and hum
    if (r == 4) {
      for (int t = 0; t < sizeof(humData); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(humData[t]);
          z++;
      delay(100);
      Serial.write(0xFF);
      Serial.write(0xFF);
      Serial.write(0xFF);
      delay(100);
      // Humidity values on channel 1
      String str = String("addt 1,1,") + String(288);
      Serial.print(str);
      delay(100);
      Serial.write(0xFF);
      Serial.write(0xFF);
      Serial.write(0xFF);
      delay(100);
      for (int t = 0; t < sizeof(tempData); t++) {
        int z = 0;
        while (z != 3) {
          Serial.write(tempData[t]);
          z++;
      delay(100);
      Serial.write(0xFF);
      Serial.write(0xFF);
      Serial.write(0xFF);
    k++;
It looks like you have a problem with this library.
This library is from 2014. Ref: DS3231 - Rinky-Dink Electronics
In the simulator with this simple code, it also gave an error.
But I compiled it with my IDE 1.8.9 and it didn't give an error.
Assuming you downloaded the proper DS3231 library, you likely have another library using the filename DS3231.h and the IDE is selecting the wrong library.
The DS3231 library pointed to from the Arduino.cc web site has an example of how to use the DS3231. It seems to instantiate the rtc, starts the I2C bus with Wire.begin(), then talks to the device with the rtc instance:
Hello, after installing the DS3231 library, the below error code is observed. Can you please suggest?
In file included from C:\Users\hp\OneDrive\Desktop\DIY_Air_Quality_Monitor\DIY_Air_Quality_Monitor.ino:11:0:
c:\Users\hp\OneDrive\Documents\Arduino\libraries\DS3231/DS3231.h:27:11: fatal error: hardware/avr/HW_AVR_defines.h: No such file or directory
#include "hardware/avr/HW_AVR_defines.h"
compilation terminated.
exit status 1
Compilation error: exit status 1
Make sure that you have downloaded and installed the library properly in proper location.
Yes, it’s worked. Thanks a lot arduino forum👍
