Error code on Arduino UNO.
Hello:
I'm trying to get this code funcone me. Physically pin 0 and 1 serial port RS232 or physical used.
 arraybytes byte [] = {65,66,67,68};
void setup () {
         Serial.begin (9600);
         Serial.write (arraybytes, 2);
void loop () {}
Verifies well with the Arduino Sketch 1.0.5 and upload it to ONE gives me this error.
Binary sketch size: 1752 bytes (of a maximum of 32,256 bytes)
avrdude: stk500_getsync (): not in sync: resp = 0x00
What is the problem and how can I fix it?
A greeting.
Moderator edit: Spaces removed from tags.
In C, the data type specifier comes before the identifier. Try:
byte arraybytes  [] = {65,66,67,68};
void setup () {
void loop () {
} // code]
You also had the comment at the very end wrong. A single line comment begins with two slashes (//).
Can you explain what you mean by this ? What do you have connected to pins 0 and 1 ?
UKHeliBob:
I think this
Shows you it is a google translate question and it has translated UNO into one.
That error has nothing to do with the code you are trying to upload.
