error code PLEASE HELP
I have gotten this error code several times and I am not sure what it means. Please help me.
code:
int ledpin = 12
int sensor = 0
void setup () {
  pinMode(ledpin, OUTPUT);
  pinMode(sensor, INPUT);
  val = analogRead(sensor);       // self-explanitory
  if val <= 12 {                  // if the area is dark enough,
    digitalWrite(ledpin, HIGH);   // Led will come on
  } else {                        // or,
    digitalWrite(ledpin, LOW);    // it won't do anything
the error message at the bottom says:
error: expected unqualified-id before numeric constant In function ‘void loop()’:
Bad error line: -2
thank you for any help.
Add semi-colons to these two lines...
int ledpin = 12 [glow];[/glow]
int sensor = 0 [glow];[/glow]
Thank You so much
I had to do a little more and ended up with this.
A program to turn on a light when it is too dark.
int ledpin = 12;
int sensor = 2;
int val = 0;
void setup () {
  if (val <= 12) {                // if the area is dark enough,
  } else {                        // or,
