Arduino: 1.6.8 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5:16: error: 'TKD2' was not declared in this scope
int RECV_PIN = TKD2; // the pin the IR receiver is connected to
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
This is the code im using
#include <IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, NEC);
irrecv.resume(); // Receive the next value
delay(100);
Your compiler is picking up the built-in RobotIRremote library rather than the third-party library you should have installed. The built-in library used the Robot pin names which are different from the UNO pin names/numbers. Did you install the IRremote library? Unless you have a (now obsolete) Arduino Robot Control Board you can safely delete the Robot libraries from C:\Program Files (x86)\Arduino\libraries\
What libraries should i install?
And what should i delete? I deleted all the robot libraries and i got another error
Cuirithir:
The IRremote library since that is the library you are trying to use. Google can help you find it.
Cuirithir:
I'm going to guess that the 'other error' has something to do with the IRremote library. Perhaps it says "IRremote.h, file not found" or words to that effect.
