Error Code
Hello,
This is an error that I have just gotten when plugging in a shield that has had no problem in the past! Any assistance?
Arduino: 1.6.1 (Mac OS X), Board: "Arduino Uno"
Sketch uses 8,716 bytes (27%) of program storage space. Maximum is 32,256 bytes. Global variables use 353 bytes (17%) of dynamic memory, leaving 1,695 bytes for local variables. Maximum is 2,048 bytes. avrdude: ser_open(): can't open device "/dev/tty.usbmodem1411": Resource busy ioctl("TIOCMGET"): Inappropriate ioctl for device Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
post your complete sketch
That looks like an issue with the com port and not the arduino code. Are you sure you have the correct port chosen? Is this a linux system? If so are you sure the permissions for that port are set right?
Hello,
So I just re-checked for the 100th time that I had the right port selected. This time Nothing was selected and it uploaded once I chose the correct port.
Any idea why sometimes the port isnt in the menu?
Thanks!
It all depends on the OS and the port and the way things are set up.
