Error Code
#include <Adafruit_TiCoServo.h>
#include <RtcDS3231.h>
#include <SoftwareSerial.h>
#include "SSD1306AsciiWire.h"
#include <WiFiEsp.h>
#include <Wire.h>
const byte neoPixels = 24;
const byte neoPin = 10;
char ssid[] = "Kjellnet";
char pass[] = "mentalotusinbingowebb";
const char server[] = "thingseak.com";
const char thingspeakAPIKey[] = "G9G9G9G9G9G9G9G9";
const int postingInterval = 30;
SSD1306AsciiWire oled;
Adafruit_NeoPixel ring = Adafruit_NeoPixel(neoPixels, neoPin, NEO_GRB);
//RtcDS3231 rtcModule;
RtcDS3231 Rtc(Wire);
WiFiEspClient client;
Adafruit_TiCoServo Servo;
SoftwareSerial Serial1(6, 7);
int status = WL_IDLE_STATUS;
int hours;
int minutes;
int seconds;
float temp;
int oldMinute;
char lastSent[20];
Wire.begin();
oled.begin(&Adafruit128x64, 0x3C);
oled.setFont(utf8font10x16);
oled.clear();
oled.print("starting");
Servo.attach(9);
Rtc.Begin();
ring.begin();
ring.setBrightness(100);
ring.show();
oled.print(".");
Serial1.begin(9600);
WiFi.init(&Serial1);
oled.print(".");
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while(true);
while(status !=WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
oled.print(".");
WiFi.status();
printOled();
updateTemp();
updateTime();
updateNeoRing();
if(seconds%postingInterval == 0){
// updateTemp();
sendThingspeak(temp);
client.flush();
client.stop();
void sendThingspeak(float value) {
if (client.connectSSL(server, 443)){
Serial.println("Connected to server.");
client.println("GET /update?api_key=" + String(thingspeakAPIKey) +
"&field1=" + String(value) + " HTTP/1.1");
client.println("Host: api.thingspeak.com");
client.println("Connection: close");
client.println();
Serial.println("Sent to server.");
sprintf(lastSent, "Sent: %02e:%02d:%02d" , hours, minutes, seconds);
printOled();
delay(100);
void updateTime() {
oldMinute = minutes;
RtcDateTime now = Rtc.GetDateTime();
hours = now.Hour();
minutes = now.Minute();
seconds = now.Second();
if(minutes != oldMinute) {
printOled();
updateNeoRing();
void printOled() {
oled.clear();
oled.setFont(lcdnums14x24);
oled.setCol(20);
char timeString[6];
sprintf(timeString, "%02:%02d", hours,minutes);
oled.println(timeString);
oled.setRow(6);
oled.setCol(100);
oled.print(int(temp));
oled.write(176);
oled.setCol(0);
oled.print(lastSent);
void updateNeoRing() {
int neoMin = round(minutes/2.5-1);
int neoHour = hours%12*2-1;
int blue;
int red;
for(int i = 0; i <= neoPixels; i++){
if (i <= neoMin= {
}blue = 255;
}else{
blue = 0;
if (i <= neoHour) {
red = 255;
red = 0;
ring.setPixelColor(i, ring.Color(red, 0, blue));
ring.show();
void updateTemp(){
RtcTemperature rtcTemp = rtcModule.GetTemperature();
temp = rtcTemp.AsFloat();
int tempPointer = map(temp, 18, 28, 30, 140);
servo.write(tempPointer);
void printWiFiStatus() {
Serial.print("SSID: ");
Serial.printIn(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.printIn(ip);
Error Code = Arduino:1.8.8 (Windows 10), Kort:"Arduino/Genuino Uno"
C:\Users\01sian70\OneDrive - Kungsbacka kommun\arduino1\klocktermometer\klocktermometer.ino: In function 'void setup()':
klocktermometer:81:12: error: 'updateTemp' was not declared in this scope
updateTemp();
C:\Users\01sian70\OneDrive - Kungsbacka kommun\arduino1\klocktermometer\klocktermometer.ino: In function 'void updateNeoRing()':
klocktermometer:159:16: error: lvalue required as left operand of assignment
if (i <= neoMin= {
klocktermometer:160:2: error: expected ')' before 'blue'
}blue = 255;
klocktermometer:161:2: error: 'else' without a previous 'if'
}else{
klocktermometer:164:5: error: 'i' was not declared in this scope
if (i <= neoHour) {
klocktermometer:170:20: error: 'i' was not declared in this scope
C:\Users\01sian70\OneDrive - Kungsbacka kommun\arduino1\klocktermometer\klocktermometer.ino: At global scope:
klocktermometer:173:1: error: 'ring' does not name a type
ring.show();
klocktermometer:175:1: error: expected declaration before '}' token
exit status 1
Inga filer har lagts till i skissen
option enabled in File -> Preferences.
Auto Format your code in the IDE. It will help you see that you have mismatched pars of { and }
For instance, where does the updateNeoRing() function end ?
}  //does it end here ?
ring.show();
}  //or does it end here ?
Also since i have resolved my issue with the ESPwifi and a WS281xx signal sending sketch, i decided to advise everybody that
-If you want to use the wifi capabilities of ESP units, then do not try and use bit-banged WS281xx signal sending libraries ! this means, no Adafruit Neopixel and no FastLed. Instead go for using Makuna - NeoPixelBus which has both a DMA and a UART mode (as it does a bit-banged mode but that is not recommended in combination with WIFI) on older IDE versions you may get SPI.h not found, although only the dotstar uses the SPI, it is still in the library and to make code compile adding #include <SPI.h> will do the trick.
