İ Write a .wav play code but it shows the error codes.
What i can i do for this problem ?
Error Codes:
C:\Users\GÜNEY\Documents\Arduino\sketch_nov13a\sketch_nov13a.ino: In function 'void setup()':
C:\Users\GÜNEY\Documents\Arduino\sketch_nov13a\sketch_nov13a.ino:20:22: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp: In member function 'byte TMRpcm::metaInfo(boolean, char*, char*, byte)':
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1388:24: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
char* datStr = "LIST";
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1389:36: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
if(infoType == 1){datStr = "ID3 "; datStr[3] = 3;}
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1417:45: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
char* tagNames[] = {"INAM","IART","IPRD"};
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1437:27: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
tagNames[0] = "TPE1"; tagNames[1] ="TIT2"; tagNames[2] ="TALB";
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1437:48: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1437:69: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp: In member function 'void TMRpcm::finalizeWavTemplate(char*)':
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1575:68: warning: narrowing conversion of '(fSize >> 16)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
seek(4); byte data[4] = {lowByte(fSize),highByte(fSize), fSize >> 16,fSize >> 24};
C:\Users\G�NEY\Documents\Arduino\libraries\TMRpcm\TMRpcm.cpp:1575:80: warning: narrowing conversion of '(fSize >> 24)' from 'long unsigned int' to 'byte {aka unsigned char}' inside { } [-Wnarrowing]
Thank you. İ am new sorry. After that i am getting carefully.
My question' s solution is: The C:\Users\G�NEY\Documents\Arduino\libraries\ way there is a different charachter on GÜNEY. İt must be GUNEY, only use English charachter on your root.
