Error Codes
exit status 1
error…expected primary expression before '.'token
code:–
efine BLYNK_PRINT.Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
char auth = “rs4YQsf-udZWXFpmHPbDNBE7VM1S9E_M”; // the auth code that you got on your gmail
char ssid = “Mukhibros”; // username or ssid of your WI-FI
char pass = “Abu9768689536”; // password of your Wi-Fi
// Debug console
pinMode(D1,OUTPUT); //extend these to D8 if you are using a 8 pin relay
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
digitalWrite(D1,HIGH); // Make it low if you want everything to go off
digitalWrite(D2,HIGH); // in case of a power cut
digitalWrite(D3,HIGH);
digitalWrite(D4,HIGH);
Blynk.run();
avibrajesh98:
exit status 1
code:–
// Debug console
pinMode(D2,OUTPUT);
pinMode(D3,OUTPUT);
pinMode(D4,OUTPUT);
Blynk.run();
‘efine BLYNK_PRINT.Serial’ should be ‘define BLYNK_PRINT.Serial’ for starters
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What is the problem?
What model Arduino are you using?
