Hola a todos, estoy probando un sensor bh1750 pero a la hora de compilar el programa me tira un error, saque el código de google, que sería este:
BH1750.cpp
This is a library for the BH1750FVI Digital Light Sensor breakout board.
The BH1750 board uses I2C for communication. Two pins are required to
interface to the device. Configuring the I2C bus is expected to be done
in user code. The BH1750 library doesn't do this automatically.
Written by Christopher Laws, March, 2013.
#include "BH1750.h"
// Define milliseconds delay for ESP8266 platform
#if defined(ESP8266)
#include <pgmspace.h>
#define _delay_ms(ms) delayMicroseconds((ms) * 1000)
// Use _delay_ms from utils for AVR-based platforms
#elif defined(__avr__)
#include <util/delay.h>
// Use Wiring's delay for compability with another platforms
#else
#define _delay_ms(ms) delay(ms)
#endif
// Legacy Wire.write() function fix
#if (ARDUINO >= 100)
#define __wire_write(d) Wire.write(d)
#else
#define __wire_write(d) Wire.send(d)
#endif
// Legacy Wire.read() function fix
#define __wire_read() Wire.read()
#else
#define __wire_read() Wire.receive()
#endif
* Constructor
* @params addr Sensor address (0x76 or 0x72, see datasheet)
* On most sensor boards, it was 0x76
BH1750::BH1750(byte addr) {
BH1750_I2CADDR = addr;
* Configure sensor
* @param mode Measurement mode
bool BH1750::begin(Mode mode) {
// I2C is expected to be initialized outside this library
// Configure sensor in specified mode
return configure(mode);
* Configure BH1750 with specified mode
bool BH1750::configure(Mode mode) {
// default transmission result to a value out of normal range
byte ack = 5;
// Check measurement mode is valid
switch (mode) {
case BH1750::CONTINUOUS_HIGH_RES_MODE:
case BH1750::CONTINUOUS_HIGH_RES_MODE_2:
case BH1750::CONTINUOUS_LOW_RES_MODE:
case BH1750::ONE_TIME_HIGH_RES_MODE:
case BH1750::ONE_TIME_HIGH_RES_MODE_2:
case BH1750::ONE_TIME_LOW_RES_MODE:
// Send mode to sensor
Wire.beginTransmission(BH1750_I2CADDR);
__wire_write((uint8_t)BH1750_MODE);
ack = Wire.endTransmission();
// Wait a few moments to wake up
_delay_ms(10);
default:
// Invalid measurement mode
Serial.println(F("[BH1750] ERROR: Invalid mode"));
// Check result code
switch (ack) {
case 0:
BH1750_MODE = mode;
return true;
case 1: // too long for transmit buffer
Serial.println(F("[BH1750] ERROR: too long for transmit buffer"));
case 2: // received NACK on transmit of address
Serial.println(F("[BH1750] ERROR: received NACK on transmit of address"));
case 3: // received NACK on transmit of data
Serial.println(F("[BH1750] ERROR: received NACK on transmit of data"));
case 4: // other error
Serial.println(F("[BH1750] ERROR: other error"));
default:
Serial.println(F("[BH1750] ERROR: undefined error"));
return false;
* Read light level from sensor
* @return Light level in lux (0 ~ 65535)
uint16_t BH1750::readLightLevel(bool maxWait) {
if (BH1750_MODE == UNCONFIGURED) {
Serial.println(F("[BH1750] Device is not configured!"));
return 0;
// Measurement result will be stored here
uint16_t level(NAN);
// Wait for measurement to be taken.
// Measurements have a maximum measurement time and a typical measurement
// time. The maxWait argument determines which measurement wait time is
// used when a one-time mode is being used. The typical (shorter)
// measurement time is used by default and if maxWait is set to True then
// the maximum measurement time will be used. See data sheet pages 2, 5
// and 7 for more details.
// A continuous mode measurement can be read immediately after re-sending
// the mode command.
switch (BH1750_MODE) {
if (BH1750_MODE == BH1750::ONE_TIME_LOW_RES_MODE) {
maxWait ? _delay_ms(24) : _delay_ms(16);
else {
maxWait ? _delay_ms(180) :_delay_ms(120);
// Read two bytes from the sensor, which are low and high parts of the sensor
// value
Wire.requestFrom(BH1750_I2CADDR, 2);
if (Wire.available() == 2) {
level = __wire_read();
level <<= 8;
level |= __wire_read();
// Print raw value if debug enabled
#ifdef BH1750_DEBUG
Serial.print(F("[BH1750] Raw value: "));
Serial.println(level);
#endif
// Convert raw value to lux
level /= 1.2;
// Print converted value if debug enabled
#ifdef BH1750_DEBUG
Serial.print(F("[BH1750] Converted value: "));
#endif
return level;
BH1750.h
breakout board.
Datasheet: http://rohmfs.rohm.com/en/products/databook/datasheet/ic/sensor/light/bh1750fvi-e.pdf
#ifndef BH1750_h
#define BH1750_h
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#include "Wire.h"
// Uncomment, to enable debug messages
// #define BH1750_DEBUG
// No active state
#define BH1750_POWER_DOWN 0x00
// Wating for measurement command
#define BH1750_POWER_ON 0x01
// Reset data register value - not accepted in POWER_DOWN mode
#define BH1750_RESET 0x07
class BH1750 {
public:
enum Mode
UNCONFIGURED = 0,
// Measurement at 1lx resolution. Measurement time is approx 120ms.
CONTINUOUS_HIGH_RES_MODE = 0x10,
// Measurement at 0.5lx resolution. Measurement time is approx 120ms.
CONTINUOUS_HIGH_RES_MODE_2 = 0x11,
// Measurement at 4lx resolution. Measurement time is approx 16ms.
CONTINUOUS_LOW_RES_MODE = 0x13,
ONE_TIME_HIGH_RES_MODE = 0x20,
ONE_TIME_HIGH_RES_MODE_2 = 0x21,
ONE_TIME_LOW_RES_MODE = 0x23
BH1750(byte addr = 0x23);
bool begin(Mode mode = CONTINUOUS_HIGH_RES_MODE);
bool configure(Mode mode);
uint16_t readLightLevel(bool maxWait = false);
private:
int BH1750_I2CADDR;
Mode BH1750_MODE = UNCONFIGURED;
#endif
Y código arduino
#include <Wire.h>
#include <BH1750.h>
BH1750 Luxometro;
void setup(){
Serial.println("Inicializando sensor...");
Luxometro.begin(BH1750_CONTINUOUS_HIGH_RES_MODE); //inicializamos el sensor
uint16_t lux = Luxometro.readLightLevel();//Realizamos una lectura del sensor
Serial.print("Luz(iluminancia): ");
Serial.print(lux);
Serial.println(" lx");
Me arroja este error:
C:\proyects\bh1750.ino: In function ‘void setup()’:
bh1750:10: error: ‘BH1750_CONTINUOUS_HIGH_RES_MODE’ was not declared in this scope
exit status 1
¿Qué puede ser?
Saludos
