Estoy creando un codigo que sube informacion a firebase real time database, pero tambien quiro subir imagenes al storage del mismo firebase, pero al momento de verificarlo me marca errores que se me hacen raros, debido a que estoy siguiendo un tutorial, no se si puedan ayudarme a corregirlo
#include <WiFi.h>
#include "esp_camera.h"
#include "Arduino.h"
#include "soc/soc.h" // Disable brownout problems
#include "soc/rtc_cntl_reg.h" // Disable brownout problems
#include "driver/rtc_io.h"
#include <SPIFFS.h>
#include <FS.h>
#include <Firebase_ESP_Client.h>
#include <FirebaseESP32.h>
// Provide the token generation process info.
#include <addons/TokenHelper.h>
// Provide the SD card interfaces setting and mounting
#include <addons/SDHelper.h>
// Provide the RTDB payload printing info and other helper functions.
#include <addons/RTDBHelper.h>
#define WIFI_SSID "FrikiLap"
#define WIFI_PASSWORD "123456789"
#define API_KEY "AIzaSyAr5P2YasdxUsXNLYAB3OFG05NU2BFNkJs"
int SensorFlama = 2;
int SensorHumo = 14;
//ULTRASONICO----------
int pinTrig = 13;
int pinEcho = 15;
unsigned long tiempo, distancia;
#define DATABASE_URL "https://esp32-cam-3f64c-default-rtdb.firebaseio.com/" //<databaseName>.firebaseio.com or <databaseName>.<region>.firebasedatabase.app
// Insert Authorized Email and Corresponding Password
#define USER_EMAIL "ninjamexica@gmail.com"
#define USER_PASSWORD "Hakainoh4nt40"
// Insert Firebase storage bucket ID e.g bucket-name.appspot.com
#define STORAGE_BUCKET_ID "AIzaSyAr5P2YasdxUsXNLYAB3OFG05NU2BFNkJs"
#define FILE_PHOTO "/data/photo.jpg"
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
boolean takeNewPhoto = true;
FirebaseData fbdo;
FirebaseAuth auth;
FirebaseConfig configF;
bool taskCompleted = false;
//Checar si la foto se tomo
bool checkPhoto( fs::FS &fs ) {
File f_pic = fs.open( FILE_PHOTO );
unsigned int pic_sz = f_pic.size();
return ( pic_sz > 100 );
// Capture Photo and Save it to SPIFFS
void capturePhotoSaveSpiffs(void){
camera_fb_t * fb = NULL; // pointer
bool ok = 0; // Boolean indicating if the picture has been taken correctly
do {
// Take a photo with the camera
Serial.println("Taking a photo...");
fb = esp_camera_fb_get();
if (!fb) {
Serial.println("Camera capture failed");
return;
// Photo file name
Serial.printf("Picture file name: %s\n", FILE_PHOTO);
File file = SPIFFS.open(FILE_PHOTO, FILE_WRITE);
// Insert the data in the photo file
if (!file) {
Serial.println("Failed to open file in writing mode");
else {
file.write(fb->buf, fb->len); // payload (image), payload length
Serial.print("The picture has been saved in ");
Serial.print(FILE_PHOTO);
Serial.print(" - Size: ");
Serial.print(file.size());
Serial.println(" bytes");
// Close the file
file.close();
esp_camera_fb_return(fb);
// check if file has been correctly saved in SPIFFS
ok = checkPhoto(SPIFFS);
} while ( !ok );
void initSPIFFS() {
if (!SPIFFS.begin(true)) {
Serial.println("An Error has occurred while mounting SPIFFS");
ESP.restart();
else {
Serial.println("SPIFFS mounted successfully");
void initCamera() {
// OV2640 camera module
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// Camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
ESP.restart();
String nodo = "/Sensores";
bool iterar = true;
pinMode(pinEcho, INPUT);
pinMode(pinTrig, OUTPUT);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.print("Conectado al Wifi");
Serial.print(".");
delay(300);
initSPIFFS();
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
initCamera();
//Firebase
// Assign the api key
configF.api_key = API_KEY;
//Assign the user sign in credentials
auth.user.email = USER_EMAIL;
auth.user.password = USER_PASSWORD;
configF.database_url = DATABASE_URL;
//Assign the callback function for the long running token generation task
configF.token_status_callback = tokenStatusCallback; //see addons/TokenHelper.h
Serial.println("");
Firebase.begin(&configF, &auth);
Firebase.reconnectWiFi(true);
//while(iterar){
if (digitalRead(SensorFlama) == LOW) {
Serial.println("Se detecta FLAMA");
Firebase.setBool(fbdo, nodo + "/sensorFlama", true);
Serial.println("NO se detecta FLAMA");
Firebase.setBool(fbdo, nodo + "/sensorFlama", false);
if (digitalRead(SensorHumo) == LOW) {
Serial.println("Se detecto HUMO");
Firebase.setBool(fbdo, nodo + "/sensorHumo", true);
Serial.println("NO se detecto HUMO");
Firebase.setBool(fbdo, nodo + "/sensorHumo", false);
digitalWrite(pinTrig, LOW);
delayMicroseconds(2);
digitalWrite(pinTrig, HIGH);
delayMicroseconds(10);
tiempo = pulseIn(pinEcho, HIGH);
distancia = tiempo / 58;
// imprimir la distancia medida al monitor serial
Serial.print(F("Distancia: "));
Serial.print(distancia);
Serial.println(F(" cm"));
// esperar un segundo antes de realizar otra medición
if (distancia > 40 ) {
Serial.println("La caja esta abierta");
Firebase.setBool(fbdo, nodo + "/sensorUS", false);
if (takeNewPhoto) {
capturePhotoSaveSpiffs();
takeNewPhoto = false;
delay(1);
if (Firebase.ready() && !taskCompleted) {
taskCompleted = true;
Serial.print("Uploading picture... ");
//MIME type should be valid to avoid the download problem.
//The file systems for flash and SD/SDMMC can be changed in FirebaseFS.h.
if (Firebase.Storage.upload(&fbdo, STORAGE_BUCKET_ID /* Firebase Storage bucket id */, FILE_PHOTO /* path to local file */, mem_storage_type_flash /* memory storage type, mem_storage_type_flash and mem_storage_type_sd */, FILE_PHOTO /* path of remote file stored in the bucket */, "image/jpeg" /* mime type */)) {
Serial.printf("\nDownload URL: %s\n", fbdo.downloadURL().c_str());
else {
Serial.println(fbdo.errorReason());
Serial.println("La caja NO esta abierta");
Firebase.setBool(fbdo, nodo + "/sensorUS", true);
Serial.println("_____________________________________");
y me envia el siguiente error
C:/Users/ballk/OneDrive/Documentos/PlatformIO/Projects/220814-215422-esp32cam/src/Sensores-firebase.ino:281:14: error: 'class Firebase_ESP_Client' has no member named 'setBool'
