Hi all, I am trying to connect a SW-240 vibration sensor to Arduino UNO and send its data to ThingSpeak via ESP8266-01 for analysis. I took reference from 2 codes, one is sending fixed variable continuously from ESP8266 to ThingSpeak, while another one is Arduino receiving sensor measurement variables and displaying on Serial Monitor.
However, when I combine and amend the 2 codes, errors appear. Below are the errors.
Arduino_Thingspeak_Vibration_Sensor:28: error: variable or field 'SentOnCloud' declared void
void SentOnCloud(measurement)
Arduino_Thingspeak_Vibration_Sensor:28: error: 'measurement' was not declared in this scope
exit status 1
I think its something related to wrong use of function declaration. But I am really basic in programming and hence cant really figure out the problem of ‘void function ( string () )’ and ‘void function ( “long variable” )’.
Can anyone please help to solve the bugs? Really really appreciated!
Here are my codes.
#include <SoftwareSerial.h>
#define _baudrate 9600
#define _rxpin 4
#define _txpin 5
SoftwareSerial debug( _rxpin, _txpin ); // RX, TX
//*-- IoT Information
#define SSID "gloriachu"
#define PASS "0001984085235"
#define IP "184.106.153.149" // ThingSpeak IP Address: 184.106.153.149
// 使用 GET 傳送資料的格式
// GET /update?key=[THINGSPEAK_KEY]&field1=[data 1]&filed2=[data 2]...;
String GET = "GET /update?key=S0ZOGPHMTLG31SVM";
int ledPin = 13;
int EP =9;
long TP_init(){
delay(10);
long measurement=pulseIn (EP, HIGH); //wait for the pin to get HIGH and returns measurement
return measurement;
boolean connectWiFi()
debug.println("AT+CWMODE=1");
Wifi_connect();
// 設定 ESP8266 作為 Client 端
String cmd = "AT+CIPSTART=\"TCP\",\"";
cmd += IP;
cmd += "\",80";
sendDebug(cmd);
if( debug.find( "Error" ) )
Serial.print( "RECEIVED: Error\nExit1" );
return;
cmd = GET + "&field1=" + T + "&field2=" + H +"\r\n";
debug.print( "AT+CIPSEND=" );
debug.println( cmd.length() );
if(debug.find( ">" ) )
Serial.print(">");
Serial.print(cmd);
debug.print(cmd);
debug.print( "AT+CIPCLOSE" );
if( debug.find("OK") )
Serial.println( "RECEIVED: OK" );
Serial.println( "RECEIVED: Error\nExit2" );
void Wifi_connect()
String cmd="AT+CWJAP=\"";
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
sendDebug(cmd);
Loding("Wifi_connect");
void Loding(String state){
for (int timeout=0 ; timeout<10 ; timeout++)
if(debug.find("OK"))
Serial.println("RECEIVED: OK");
else if(timeout==9){
Serial.print( state );
Serial.println(" fail...\nExit2");
Serial.print("Wifi Loading...");
void sendDebug(String cmd)
Serial.print("SEND: ");
Serial.println(cmd);
debug.println(cmd);
pinMode(ledPin, OUTPUT);
pinMode(EP, INPUT); //set EP input for measurment
Serial.begin( _baudrate );
debug.begin( _baudrate );
sendDebug("AT");
Loding("sent AT");
connectWiFi();
Serial.println("----------------------Vibration data collection begin------------------------");
long measurement =TP_init();
delay(100); // 60 second
Serial.print("measurment = ");
Serial.println(measurement);
SentOnCloud(measurement);
if (measurement > 1000){
digitalWrite(ledPin, HIGH);
else{
digitalWrite(ledPin, LOW);
These are the 2 reference codes. They both work fine individually.
ESP8266 ThingSpeak
#define _rxpin 4
#define _txpin 5
// 使用 GET 傳送資料的格式
sendDebug("AT");
Loding("sent AT");
connectWiFi();
delay(5000); // 60 second
SentOnCloud( String(5), String(9) );
Wifi_connect();
void SentOnCloud( String T, String H )
cmd += IP;
cmd += "\",80";
sendDebug(cmd);
return;
Serial.print(">");
Serial.print(cmd);
debug.print(cmd);
void Wifi_connect()
cmd+=SSID;
cmd+="\",\"";
cmd+=PASS;
cmd+="\"";
sendDebug(cmd);
debug.println(cmd);
Vibration Sensor
int ledPin = 13;
int EP =9;
void setup(){
Serial.begin(9600); //init serial 9600
Serial.println("----------------------Vibration demo------------------------");
void loop(){
delay(50);
else{
long TP_init(){
delay(10);
return measurement;
