Error: collect2.exe: error: ld returned 5 exit status
Hi Arduino users out there in the Big World!
I need your help. I'm currently trying to make a DFPlayer to work, for that I started a very simple sketch I want to expand as I go along collecting more experience with this circuit.
Now this sketch returns with an error message I did not see before:
I managed to figure out that if I remove the following line from the sketch, the complilation does not give me trouble any more:
attachInterrupt(0, ISR_MainSwitchPressed, FALLING); // int.0 is the pin2 on the Nano board
The thing I do not understand it: I copied this line from a working, more complex sketch. So I do not know why it triggers the error.
Please kindly advice, I would really like to have this ISR in my code...
#include <stdlib.h>
//#include "DFPlayer_Mini_Mp3.h"
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8); // RX, TX
// Arduino Wire library is required if I2Cdev I2CDEV_ARDUINO_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV_IMPLEMENTATION == I2CDEV_ARDUINO_WIRE
    #include "Wire.h"
#endif
const int momSwitch =2;
volatile int SwitchedOn=0; // state of the saber blade: True - on; False - off
volatile int PressMainSwitch; // ISR volatile variable to flag is main switch has been pushed
char buffer[4];
int received;
void ISR_MainSwitchPressed() {
  // ISR to sense when the main switch has been pressed (so far press duration is not considered)
  PressMainSwitch  =1;
  //if (SwitchedOn==0) {SwitchedOn=1} ;
  //else if  (SwitchedOn==1) {SwitchedOn=0};
// Collection of DFPlayer funcions from the DFPlayer_Mini_Mp3 library
extern uint8_t send_buf[10];
extern uint8_t recv_buf[10];
//calc checksum (1~6 byte)
uint16_t mp3_get_checksum (uint8_t *thebuf) {
	uint16_t sum = 0;
	for (int i=1; i<7; i++) {
		sum += thebuf[i];
	return -sum;
   // join I2C bus (I2Cdev library doesn't do this automatically)
        Wire.begin();
    #elif I2CDEV_IMPLEMENTATION == I2CDEV_BUILTIN_FASTWIRE
        Fastwire::setup(400, true);
    #endif
   // define momentary switch
   pinMode(momSwitch, INPUT_PULLUP); // set a digital pin as an input with pull-up used as a switch input
    // initialize serial communication
    // (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
    // it's really up to you depending on your project)
    received = 0;
    buffer[received] = '\0';
    // configure pins and set the data rate for the SoftwareSerial port
  // these 2 pins will be used to communicate with the DFPlayer
  pinMode(7,INPUT); //SS_RX
  pinMode(8,OUTPUT); //SS_TX
  mySerial.begin(9600);
  SwitchedOn=0; // initialize saber state variable
    // define Interrupt Service for main switch
 if (SwitchedOn==0 and PressMainSwitch==1) {
    //IgniteSaber(true);
    SwitchedOn = 1;
    PressMainSwitch=0;
  else if (SwitchedOn==1 and PressMainSwitch==1){
    //RetractSaber();
    SwitchedOn = 0;
    PressMainSwitch=0;
    //RandomFlicker(DriveStrengthHum,10,100);
    //Flicker(DriveStrengthHum, 10, 5, 10);
Update: I moved the suspicious line to the beginning of the setup function, and now I do not have the compilation error... but I would still like to understand why it happens. Googling the internet I find this error happens quite often, not only for Arduino, is there a good way to find out which piece of code causes the system to throw up?
Sorry, I was too quick. I'm really ashamed, I had multiple sketches open, and I made the code move in another one which does not have the compilation error...
So the problem still persists, moving the line does not change anything...
The sketch compiles fine for me. Are there any messages above the "collect2.exe: error: ld returned 5 exit status"?
Thanks a lot johnwasser for helping me out. Sorry for the late answer, my first answer went into Nirvana, somehow on WIN7 the "remember my password" in IE sends the arduino forum into a pocket dimension.
Since there is a recent thread about the same problem and it seems to be the WIN XP OS, I moved to that thread.
What's the link to the Win XP thread? I have the same headache on XP.
Nobody I've found so far identifies the root problem or a real non-bandaid solution.
Doug Robson cdrobsonjr@att.net
ld.exe is broken.
Replace it by an avr_ld.exe from an older Toolchain
