Buenas tardes, tengo el siguiente código, lo estoy compilando pero me manda el este error:
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master\Adafruit_MonoOLED.h:30:10: fatal error: Adafruit_I2CDevice.h: No such file or directory #include <Adafruit_I2CDevice.h>
compilation terminated.
exit status 1
Error compilando para la tarjeta Arduino Nano.
Usos el SO Windows 8 Enterprise.
Me han dicho que depende mucho del SO.
Alguien lo puede correr en Wundows 7 por favor y que me avise si le funcionó.
este es el codigo:
#include <SoftwareSerial.h>
#include "Arduino.h"
#include <Wire.h>//Include libraries: SoftwareSerial & Wire
SoftwareSerial ESP_BT(0,1); //Define PIN11 & PIN12 as RX and TX pins
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <EEPROM.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
#define PIN 5
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
// NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
// Position of the FIRST LED in the matrix; pick two, e.g.
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
// NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
// rows or in vertical columns, respectively; pick one or the other.
// NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
// in the same order, or alternate lines reverse direction; pick one.
// See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_GRBW Pixels are wired for GRBW bitstream (RGB+W NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// Example for NeoPixel Shield. In this application we'd like to use it
// as a 5x8 tall matrix, with the USB port positioned at the top of the
// Arduino. When held that way, the first pixel is at the top right, and
// lines are arranged in columns, progressive order. The shield uses
// 800 KHz (v2) pixels that expect GRB color data.
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(
32, //Select LEDs of each row (15 in my case)
8, //Select amount of rows (7 in my case)
PIN,
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT + //Define first data pin (right bottom corner is my first pin)
NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG, //Define the type of connection (in a zig zag connections and divided by rows not columns)
NEO_RGB + NEO_KHZ800);
int Red=255,Green=0,Blue=0;
String text="Easy Tech";
String RGB;
int pixelPerChar = 5,RGB_Completed=0;
int Delay, Brightness;
const uint16_t colors[] = {matrix.Color(Green,Red,Blue)};
// matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };//matrix.Color(Red, Green, Blue),
ESP_BT.begin(9600);
EEPROM.begin();
initdata();
// Serial.println("Start");
matrix.begin();
matrix.setTextWrap(false);
matrix.setBrightness(Brightness);
matrix.setTextColor(colors[0]);
//matrix.setTextColor(matrix.Color(Green,Red,Blue));
int x = matrix.width();
int pass = 0;
while(ESP_BT.available()){
char ReadChar = (char)ESP_BT.read();
Serial.println(ReadChar);
// Right parentheses ) indicates complet of the string
if(ReadChar == ')' ||ReadChar == '}' || ReadChar == ']'){
if(ReadChar == ')' ){
RGB_Completed = 1;
if(ReadChar == '}'){
RGB_Completed = 2;
if(ReadChar == ']'){
RGB_Completed = 3;
else{
RGB += ReadChar;
if(RGB_Completed!=0){
if(RGB_Completed==1){
Light_RGB_LED();
RGB_Completed=0;
if (RGB_Completed==2){
text=RGB;
int _size = text.length();
int i;
for(i=0;i<_size;i++)
EEPROM.write(50+i,text.charAt(i));
Serial.println(text.charAt(i));
EEPROM.write(50+_size,'\0'); //Add termination null character for String Data
RGB_Completed=0;
RGB="";
if (RGB_Completed==3){
int val=RGB.toInt();
if(val>0 && val<=100){
if(val==0){
val=1;
Delay=(100-val)*2.5;
//scroll(Delay);
EEPROM.write(0,Delay);
else{
val=val-100;
matrix.setBrightness(val);
EEPROM.write(5,val);
RGB="";
RGB_Completed=0;
if(RGB_Completed==0){
//. Serial.println(RGB_Completed);
scroll();
void scroll(){
//Serial.println(text);
int maxDisplacement = text.length() * pixelPerChar + matrix.width();
matrix.fillScreen(0);
matrix.setCursor(x, 0);
matrix.print(text);
if(--x < -maxDisplacement) {
x = matrix.width();
if(++pass >= 1){ pass = 0;
// matrix.setTextColor(colors[pass]);
// matrix.setTextColor(matrix.Color(Red,Green,Blue));
matrix.show();
delay(Delay);
void Light_RGB_LED(){
int SP1 = RGB.indexOf('.');
int SP2 = RGB.indexOf('.', SP1+1);
int SP3 = RGB.indexOf('.', SP2+1);
String R = RGB.substring(0, SP1);
String G = RGB.substring(SP1+1, SP2);
String B = RGB.substring(SP2+1, SP3);
Red=R.toInt();Green=G.toInt();Blue=B.toInt();
// Serial.println(R);
EEPROM.write(10,Red);EEPROM.write(15,Green);EEPROM.write(20,Blue);
RGB="";
Function:
void initdata(){
int Speed=EEPROM.read(0);
if(Speed==NULL || Speed==0){
Delay=100;
else{
Delay=Speed;
int bright= EEPROM.read(5);
if(bright==NULL || bright==0){
Brightness=40;
else{
Brightness=bright;
int r= EEPROM.read(10);
if(r==NULL){
Red=0;
else{
Red=r;
int g= EEPROM.read(15);
if(g==NULL){
Green=255;
else{
Green=g;
int b= EEPROM.read(20);
if(b==NULL){
Blue=0;
else{
Blue=b;
char data[100]; //Max 100 Bytes
int len=0;
char k;
String Text= "";
k=EEPROM.read(50);
while(k != '\0' && len<500) //Read until null character
k=EEPROM.read(50+len);
data[len]=k;
Text+=k;
len++;
data[len]='\0';
if(Text==NULL){
text="EASY TECH";
else{
text=Text;
Serial.println(Speed);
Serial.println(Brightness);
Serial.println(Red);
Serial.println(Green);
Serial.println(Blue);
De antemano gracias, por los que me puedan ayudar
