Error compiling... Am I missing Libraries?
Trying to run a program and getting some errors. Am I missing libraries that are needed?
Arduino: 1.6.8 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\ASUS\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0001 -ide-version=10608 -build-path "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\ASUS\Desktop\MIDIControlMS70CDR_V2_0\MIDIControlMS70CDR_V2_0.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\ASUS\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0001 -ide-version=10608 -build-path "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\ASUS\Desktop\MIDIControlMS70CDR_V2_0\MIDIControlMS70CDR_V2_0.ino"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp\sketch\MIDIControlMS70CDR_V2_0.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\ASUS\Documents\Arduino\libraries\USBHost\src" "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp\sketch\MIDIControlMS70CDR_V2_0.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "-IC:\Users\ASUS\Documents\Arduino\libraries\USBHost\src" "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp\sketch\MIDIControlMS70CDR_V2_0.ino.cpp" -o "C:\Users\ASUS\AppData\Local\Temp\buildb37d56768ad3d44b8ad4e31fa3a858d9.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\ASUS\Desktop\MIDIControlMS70CDR_V2_0\MIDIControlMS70CDR_V2_0.ino:29:20: fatal error: usbhub.h: No such file or directory
 #include
compilation terminated.
Using library USBHost at version 1.0.5 in folder: C:\Users\ASUS\Documents\Arduino\libraries\USBHost
exit status 1
Error compiling for board Arduino/Genuino Uno.
Moderator edit: [code]
[/code] tags added.
Looks like it.
Appears to be the first hit... https://www.google.com/search?q=usbhub.h
I had previously installed that zip file library (after a google search) and it was still a no go. This was my next stop.
EDIT: Just tried it again in Linux and it worked. For whatever reason it didn't work in Windows. I had to rename the zip file since Arduino 1:1.0.5 in Linux didn't like the non ASCII characters in his library's filename.
