Error compiling arduino editor but not IDE
I am trying to move my sketches to the arduino editor, but I am getting some errors compiling that I don't understand. I assume the libraries that are eligible to download in the IDE desktop version are already included in the editor? Because I can't find a way to download them into IDE. I can add libraries that are not included within arduino interface to the editor, and I have for the code below.... But I am still getting errors compiling that appear to me to involve not having the libraries installed correctly within the arduino editor, but I am not sure.
Here is the code I am currently using:
#include <ESP_Mail_Client.h>
#include <ESP_Mail_FS.h>
#include <SDK_Version_Common.h>
#include <Arduino.h>
#if defined(ESP32)
  #include <WiFi.h>
#elif defined(ESP8266)
  #include <ESP8266WiFi.h>
#endif
#define SMTP_HOST "smtp.gmail.com"
#define SMTP_PORT 465
#define AUTHOR_EMAIL "emailchange"
#define AUTHOR_PASSWORD "wrongpassword"
#define RECIPIENT_EMAIL "addemail"
#define RECIPIENT_EMAIL2 "addemail2"
#include <Adafruit_Sensor.h>
#include <DHT.h>
#include <DHT_U.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <ArduinoOTA.h>
// Data wire is plugged into digital pin 2 on the Arduino
#define ONE_WIRE_BUS D3 // pin 8 on uno
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
// Set DHT pin:
#define DHTPIN 5 // pin 3 on uno
// Set DHT type, uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302)
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Initialize DHT sensor for normal 16mhz Arduino:
DHT dht = DHT(DHTPIN, DHTTYPE);
const char* ssid = "SpectrumSetup-98";
const char* password = "wrongpassord";
String header;
String output5State = "off";
String output4State = "off";
WiFiServer server(80);
IPAddress ip(192, 168, 1, 166); // where xx is the desired IP Address
IPAddress gateway(192, 168, 1, 1); // set gateway to match your network
unsigned long currentMillis;
unsigned long previousMillis;
int checkNumber = 0;
unsigned long dehumidiferOnMillis;
unsigned long resetMillis = 0;
unsigned long checkMillis;
unsigned long startRunTime;
unsigned long runTime;
unsigned long totalRunTime = 0;
unsigned long checkDutyCycle = 3600000;// should return as 1 hour more than currentMillis each hour check function is called
unsigned long checkOneDayDuty = 0;
unsigned long fanOnlyMillis = 0;
unsigned long serialNow = 5000;
unsigned long previousTime = 0;
const long timeoutTime = 2000;
int minimumRunTime = 120000;// 2 min
int numberOfCyclesThisHour = 0;
int numberOfCyclesTotal = 0;
const unsigned long maxDutyCycle = 3600000;// 1 hour
const unsigned long delayPeriod = 300000;// 5 min delay period for fan to run after compressor cuts off also 3 min delay at start up and 5 minute delay between cycling compressor
const unsigned long serialDelay = 5000;
const int setH = 60;
const int setHighH = 63;
const int compressorRelay = D4;// pin 13 on uno
const int fanRelay = D5;//maybe pin 5 on uno
volatile boolean Running = false;
volatile boolean fanOnlyRunning = false;
volatile boolean Reset = false;
volatile boolean emailSent = false;
volatile boolean emailSent2 = false;
volatile boolean emailSent3 = false;
volatile boolean emailSent4 = false;
volatile boolean TestEmail = false;
volatile boolean SensorNotReadingB = false;
float halfDayRun;
/* The SMTP Session object used for Email sending */
SMTPSession smtp;
/* Callback function to get the Email sending status */
void smtpCallback(SMTP_Status status);
  sensors.begin();  // Start up the library for ds18b20 thermometer
  dht.begin();
  delay(10);
  dehumidiferOnMillis = 0;
  fanOnlyMillis = 0;
  pinMode(fanRelay, OUTPUT);
  pinMode(compressorRelay, OUTPUT);
  digitalWrite(compressorRelay, HIGH); // OFF
  digitalWrite(fanRelay, HIGH); // OFF
  Serial.println("Starting, 5 minute wait before compressor will come on");
  Serial.print(F("Setting static ip to : "));
  Serial.println(ip);
  // Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  IPAddress subnet(255, 255, 255, 0); // set subnet mask to match your network
  //WiFi.config(ip, gateway, subnet);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
 server.begin();
 Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL : ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
   WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  // attempt to connect to WiFi network
  Serial.print("Connecting to WiFi...");
    Serial.print(".");
  // show WiFi status in serial monitor
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.print("IP address: ");
  ArduinoOTA.begin();
  ArduinoOTA.handle();
  currentMillis = millis();
  float h = dht.readHumidity();
  float f = dht.readTemperature(true);
  if (isnan(h) || isnan(f)) {
    sensorNotReading();// if sensor is not reading the compressor is turned off
    return;
sensors.requestTemperatures();   //Getting Temperature of Compressor
float compressorTemp = ((sensors.getTempCByIndex(0) * 9.0) / 5.0 + 32.0);
 if (currentMillis - serialDelay > serialNow){
  serialNow = currentMillis + serialDelay;
    WiFiClient client = server.available();   // Listen for incoming clients
  if (client) {                             // If a new client connects,
    Serial.println("New Client.");          // print a message out in the serial port
    String currentLine = "";                // make a String to hold incoming data from the client
    previousTime = currentMillis;
    while (client.connected() && currentMillis - previousTime <= timeoutTime) { // loop while the client's connected
      if (client.available()) {             // if there's bytes to read from the client,
        char c = client.read();             // read a byte, then
        Serial.write(c);                    // print it out the serial monitor
        header += c;
        if (c == '\n') {                    // if the byte is a newline character
          // if the current line is blank, you got two newline characters in a row.
          // that's the end of the client HTTP request, so send a response:
          if (currentLine.length() == 0) {
            // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
            // and a content-type so the client knows what's coming, then a blank line:
            client.println("Content-type:text/html");
            client.println("Connection: close");
            client.println();
            // turns the GPIOs on and off
            if (header.indexOf("GET /5/on") >= 0) {
              Serial.println("GPIO 5 on");
              output5State = "on";
            //  digitalWrite(output5, HIGH);
            } else if (header.indexOf("GET /5/off") >= 0) {
              Serial.println("GPIO 5 off");
              //digitalWrite(output5, LOW);
            } else if (header.indexOf("GET /4/on") >= 0) {
              Serial.println("GPIO 4 on");
              output4State = "on";
             // digitalWrite(output4, HIGH);
            } else if (header.indexOf("GET /4/off") >= 0) {
              Serial.println("GPIO 4 off");
              //digitalWrite(output4, LOW);
            // Display the HTML web page
            client.println("<!DOCTYPE html><html>");
            client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
            client.println("<link rel=\"icon\" href=\"data:,\">");
            // CSS to style the on/off buttons
            // Feel free to change the background-color and font-size attributes to fit your preferences
            client.println("<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}");
            client.println(".button { background-color: #195B6A; border: none; color: white; padding: 16px 40px;");
            client.println("text-decoration: none; font-size: 30px; margin: 2px; cursor: pointer;}");
            client.println(".button2 {background-color: #77878A;}</style></head>");
            // Web Page Heading
            client.println("<body><h1>ESP8266 Web Server</h1>");
            // Display current state, and ON/OFF buttons for GPIO 5
            if (Running == true){
              check();
            client.println("<p>Dehumidifier is on " );
            client.print("<p>humidity is:  ");
            client.println(h);
            client.print("<p>compressor temperature is ");
            client.println(compressorTemp);
            client.print("<p>In the last hour, the compressor has been on ");
            client.println(totalRunTime / 60000);
            client.println("minutes out of the last ");
            client.println((previousMillis - resetMillis) / 60000);
            client.println("minutes.");
            client.println("<p>In the last  ");
            client.println(checkNumber);
            client.println("hour(s), the compressor has been on ");
            client.println(halfDayRun / 3600000);
            client.println("hours");
            client.println("<p>The number of times the compressor has turned on this hours is ");
            client.println(numberOfCyclesThisHour);
            client.println("hour(s), the compressor has cycled on ");
             client.println(numberOfCyclesTotal);
            client.println("<p>The dehumidifier is set to come on when the humidity is above ");
            client.println(setHighH);
            client.println("<p>The dehumidifier is set to go off when the humidity gets below  ");
            client.println(setH);
            else{
             check();
            client.println("<p>Dehumidifier is off " );
            client.print("<P>humidity is:  ");
            client.println(h);
            client.println((previousMillis - resetMillis ) / 60000);
            if (fanOnlyRunning == true){
              client.print("<p>Compressor is off: Fan is on");
            // If the output5State is off, it displays the ON button
            //if (output5State=="off") {
              //client.println("<p><a href=\"/5/on\"><button class=\"button\">ON</button></a></p>");
            //} else {
              //client.println("<p><a href=\"/5/off\"><button class=\"button button2\">OFF</button></a></p>");
            // Display current state, and ON/OFF buttons for GPIO 4
            //client.println("<p>GPIO 4 - State " + output4State + "</p>");
            // If the output4State is off, it displays the ON button
            //if (output4State=="off") {
              //client.println("<p><a href=\"/4/on\"><button class=\"button\">ON</button></a></p>");
            //} else {
              //client.println("<p><a href=\"/4/off\"><button class=\"button button2\">OFF</button></a></p>");
            //client.println("</body></html>");
            // The HTTP response ends with another blank line
            client.println();
            // Break out of the while loop
          } else { // if you got a newline, then clear currentLine
            currentLine = "";
        } else if (c != '\r') {  // if you got anything else but a carriage return character,
          currentLine += c;      // add it to the end of the currentLine
    // Clear the header variable
    header = "";
    // Close the connection
    client.stop();
    Serial.println("Client disconnected.");
    Serial.println("");
  if (halfDayRun >= 3600000 * 12 and emailSent4 == false){
    email4();
  //if (currentMillis >= 38000 and TestEmail == false){
   // Testemail1();
  if (h > setHighH + 3 and emailSent3 == false) {
    email3();
  if (numberOfCyclesThisHour > 3 and emailSent2 == false){
    email2();
  if (compressorTemp >= 130 and emailSent == false) {
    email();
  if (compressorTemp >= 150) {
    shutDown();
  if (h > setHighH and currentMillis > delayPeriod and Running == false and Reset == false) {
    dehumidifierOn();
  if (h < setH and fanOnlyRunning == false and Running == true and currentMillis >= minimumRunTime + dehumidiferOnMillis) {
    fanOnly();
  if (currentMillis - delayPeriod / 2 > fanOnlyMillis and Running == false and fanOnlyRunning == true) {
    dehumidifierOff();
  if (currentMillis >= (checkDutyCycle)) {
    reset();
  if (currentMillis >= (checkOneDayDuty)){
    resetHalfDay();
void dehumidifierOn()
  if (currentMillis - delayPeriod > fanOnlyMillis) {
    digitalWrite(compressorRelay, LOW); // Compressor ON
    digitalWrite(fanRelay, LOW); // Compressor ON
    dehumidiferOnMillis = currentMillis;
    startRunTime = currentMillis;
    Running = true;
    numberOfCyclesThisHour = numberOfCyclesThisHour + 1;
void fanOnly()
    digitalWrite(compressorRelay, HIGH); // Compressor OFF
    fanOnlyMillis = currentMillis;
    Running = false;
    fanOnlyRunning = true;
    runTime = currentMillis;
    totalRunTime = runTime - startRunTime + totalRunTime;
void dehumidifierOff()
  digitalWrite(fanRelay, HIGH);// fan OFF
  Reset = false;
void sensorNotReading()
    secondAttempt();
  else {
    loop();
void secondAttempt()
    thirdAttempt();
  else {
    loop();
void thirdAttempt()
    sensorNotReadingEmail();
    dehumidifierOff();
  else {
    loop();
void reset()
  numberOfCyclesTotal = numberOfCyclesTotal + numberOfCyclesThisHour;
  runTime = 0;
  halfDayRun = totalRunTime + halfDayRun;
  totalRunTime = 0;
  checkDutyCycle = (currentMillis + maxDutyCycle);
  resetMillis = currentMillis;
  checkNumber = checkNumber + 1 ;
  emailSent = false;
  emailSent2 = false;
  emailSent3 = false;
    numberOfCyclesThisHour = 1;
void check()
  else{
    totalRunTime = totalRunTime;
void shutDown()
  emailShutDown();
  while (1) {
    delay(10000);
void resetHalfDay()
  checkOneDayDuty = currentMillis + 86400000; // 86400000 is 1 day in milliseconds should reset each day
  halfDayRun = 0;
  checkNumber = 0;
  emailSent4 = false;
void smtpCallback(SMTP_Status status){
  /* Print the current status */
  Serial.println(status.info());
  /* Print the sending result */
  if (status.success()){
    Serial.println("----------------");
    ESP_MAIL_PRINTF("Message sent success: %d\n", status.completedCount());
    ESP_MAIL_PRINTF("Message sent failled: %d\n", status.failedCount());
    Serial.println("----------------\n");
    struct tm dt;
    for (size_t i = 0; i < smtp.sendingResult.size(); i++){
      /* Get the result item */
      SMTP_Result result = smtp.sendingResult.getItem(i);
      time_t ts = (time_t)result.timestamp;
      localtime_r(&ts, &dt);
      ESP_MAIL_PRINTF("Message No: %d\n", i + 1);
      ESP_MAIL_PRINTF("Status: %s\n", result.completed ? "success" : "failed");
      ESP_MAIL_PRINTF("Date/Time: %d/%d/%d %d:%d:%d\n", dt.tm_year + 1900, dt.tm_mon + 1, dt.tm_mday, dt.tm_hour, dt.tm_min, dt.tm_sec);
      ESP_MAIL_PRINTF("Recipient: %s\n", result.recipients);
      ESP_MAIL_PRINTF("Subject: %s\n", result.subject);
void email ()
 /** Enable the debug via Serial port
   * none debug or 0
   * basic debug or 1
  smtp.debug(1);
  /* Set the callback function to get the sending results */
  smtp.callback(smtpCallback);
  /* Declare the session config data */
  ESP_Mail_Session session;
  /* Set the session config */
  session.server.host_name = SMTP_HOST;
  session.server.port = SMTP_PORT;
  session.login.email = AUTHOR_EMAIL;
  session.login.password = AUTHOR_PASSWORD;
  session.login.user_domain = "";
  /* Declare the message class */
  SMTP_Message message;
  /* Set the message headers */
  message.sender.name = "Dehumidifier Message";
  message.sender.email = AUTHOR_EMAIL;
  message.subject = "Compresser temp warning";
  message.addRecipient("Nick", RECIPIENT_EMAIL);
  message.addRecipient("Daddy", RECIPIENT_EMAIL2);
  /*Send HTML message*/
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Compressor temperature Is above 130 degrees</h1><p>- Sent from ESP board</p></div>";
  message.html.content = htmlMsg.c_str();
  message.text.charSet = "us-ascii";
  message.html.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
  /* Set the custom message header */
  //message.addHeader("Message-ID: <abcde.fghij@gmail.com>");
  /* Connect to server with the session config */
  if (!smtp.connect(&session))
    return;
  /* Start sending Email and close the session */
  if (!MailClient.sendMail(&smtp, &message))
    Serial.println("Error sending Email, " + smtp.errorReason());
    emailSent = true;
void email2 ()
  smtp.debug(1);
  message.subject = "Compresser cycle warning";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Compressor has cycled on more than 3 times this hour </h1><p>- Sent from ESP board</p></div>";
    return;
    emailSent2 = true;
void email3()
  smtp.debug(1);
  message.subject = "Humidity too high";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Dehumidifier is not keeping the humidity below the desired amount</h1><p>- Sent from ESP board</p></div>";
    return;
    emailSent3 = true;
void email4()
  smtp.debug(1);
  message.subject = "Dehumidifier Run Time";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>The compressor has been running more than 12 hours in a 24 hour period.</h1><p>- Sent from ESP board</p></div>";
    return;
    emailSent4 = true;
void emailShutDown()
  smtp.debug(1);
  message.subject = "Dehumidifier ShutDown!";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Compresser Temp is above 150.  It has shut down.  Need to check.</h1><p>- Sent from ESP board</p></div>";
    return;
void Testemail1()
  smtp.debug(1);
  message.subject = "Email Test";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>Did you get this email?</h1><p>- Sent from ESP board</p></div>";
    return;
    TestEmail = true;
void sensorNotReadingEmail()
  smtp.debug(1);
  message.subject = "Humidity Sensor Not Reading";
  String htmlMsg = "<div style=\"color:#2f4468;\"><h1>The humidity sensor has not been read in the last three tries. Needs checking:</h1><p>- Sent from ESP board</p></div>";
    return;
    SensorNotReadingB = true;
It will compile fine with the desktop version of the arduino ide.... just not the online editor.
Here is the error:
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:d1_mini:baud=921600,dbg=Disabled,eesz=4M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/374190154/build --build-path /tmp/arduino-build-100602E7E8C267C0DABCEB7CB1BEC584 --library /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client --library /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/RTClib /tmp/374190154/10_12_current_code
Using library ArduinoOTA at version 1.0 in folder: /home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/ArduinoOTA
Using library ESP8266mDNS at version 1.2 in folder: /home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/ESP8266mDNS
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp: In member function 'bool ESP_Mail_Client::openFileRead(SMTPSession*, SMTP_Message*, SMTP_Attachment*, File&, std::string&, std::string&, const string&, bool)':
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:2995:12: error: no match for 'operator=' (operand types are 'File' and 'fs::File')
file = ESP_MAIL_FLASH_FS.open(filepath.c_str(), "r");
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:2995:12: note: candidates are:
In file included from /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.h:59:0,
from /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:43:
/home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SD/src/SD.h:26:7: note: File& File::operator=(const File&)
class File : public Stream {
/home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SD/src/SD.h:26:7: note: no known conversion for argument 1 from 'fs::File' to 'const File&'
/home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SD/src/SD.h:26:7: note: File& File::operator=(File&&)
/home/builder/.arduino15/packages/esp8266/hardware/esp8266/2.5.0/libraries/SD/src/SD.h:26:7: note: no known conversion for argument 1 from 'fs::File' to 'File&&'
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp: In member function 'bool ESP_Mail_Client::openFileRead2(SMTPSession*, SMTP_Message*, File&, const char*, esp_mail_file_storage_type)':
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:3065:12: error: no match for 'operator=' (operand types are 'File' and 'fs::File')
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:3065:12: note: candidates are:
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp: In member function 'void ESP_Mail_Client::saveHeader(IMAPSession*)':
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:6308:12: error: no match for 'operator=' (operand types are 'File' and 'fs::File')
file = ESP_MAIL_FLASH_FS.open(headerFilePath.c_str(), "w");
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:6308:12: note: candidates are:
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp: In member function 'bool ESP_Mail_Client::handleAttachment(IMAPSession*, char*, int, int&, File&, std::string&, bool&, int&, int&, int&, int&, int&)':
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:6638:14: error: no match for 'operator=' (operand types are 'File' and 'fs::File')
file = ESP_MAIL_FLASH_FS.open(filePath.c_str(), "w");
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:6638:14: note: candidates are:
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp: In member function 'void ESP_Mail_Client::decodeText(IMAPSession*, char*, int, int&, File&, std::string&, bool&, int&, int&, int&)':
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:7046:22: error: no match for 'operator=' (operand types are 'File' and 'fs::File')
/mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client/src/ESP_Mail_Client.cpp:7046:22: note: candidates are:
Error during build: exit status 1
Thanks for any help!
That is a lot of code. Why not try to find the error by only compiling parts of the code at a time?
The IDE does some magic behind the scene. Can you get hold of the preprocessed C++ files?
The libraries seem to use different incompatible classes etc.
Don't mix libraries from Arduino and other frameworks.
Rewrite your code to conform to the actually used libraries.
Thanks for the help!
I don't understand what you mean preprocessed c++ files?
Thanks!
AFAIK the IDE transforms .ino files into .cpp files, includes main() etc.
Search for such files in your folders after compiling in the IDE.
Here is a code that is much more trimmed down, but I still get basically the same error...I think
Code:
#if defined(ESP32)
#include <WiFi.h>
#endif
#define AUTHOR_EMAIL ""
#define AUTHOR_PASSWORD "apxzjzlq"
#define RECIPIENT_EMAIL ""
const char* ssid = "";
const char* password = "";
String header;
IPAddress ip(192, 168, 1, 131); // where xx is the desired IP Address
volatile boolean Running = true;
SMTPSession smtp;
  Serial.println(ip);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  WiFi.disconnect();
  delay(100);
    Serial.print(".");
  Serial.println("");
  ArduinoOTA.begin();
Here is the error:
/usr/local/bin/arduino-cli compile --fqbn esp8266:esp8266:d1_mini:baud=921600,dbg=Disabled,eesz=4M,exception=disabled,ip=lm2f,lvl=None____,vt=flash,wipe=none,xtal=80 --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/496596365/build --build-path /tmp/arduino-build-5B1550D0BB86DCFECBD0862D865FD98D --library /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/ESP Mail Client --library /mnt/create-efs/webide/78/b6/78b6874e2766049830514ce3b420c195:neketege88/libraries_v2/RTClib /tmp/496596365/sketch_oct22a
I will look and see what I can find.
Thanks!
