Error compiling board
Hello every body.
I have a problem with my board not getting my program, this been going on for me more then a year now.
what it is doing when i sent a the program in i get this message in the first of the picture i have on the bottom.
The Tools setting looks like the second picture on the bottom.
That is the message i get every time, here are four picture of my arduino connected to both LED and my laptop.
I would be very happy if some one can tell me what did i did wrong, i really wont to build stuff with this.
please help me to move on with this project.
My mission at this time is to program LED to blink when i wont them to.
Very simple basic
i use to do it but something change.
it all started when i try to build my on arduino and program another ATmega328 chip with the help with the same board.
Dont thank that is the problem, i just bolt a new arduino and it still doing the same thing.
Thank you for your time to check this and hope to hear from some one soon.
Arduino: 1.8.13 (Windows Store 1.8.42.0) (Windows 10), Board: "Arduino Uno"
Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB
cc1.exe: error: -fno-fat-lto-objects are supported only with linker plugin.
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
And this is my program i have.
#include <singleLEDLibrary.h>
int LED = 8;
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
delay(2000);
No pictures showing. Is it a compile error or an upload error?
Further remember that we can't easily work with pictures of text (e.g. the error message); just copy (there is a button at the right just above the output pane) and paste.
Your post is lacking details like
1)
operating system and version
2)
ide version
3)
details of the board(s); might be clear from the picture that is missing but posting in text is a lot easier
4)
is board an original or clone
I typed the above while you posted a new message with some details. I suggest that you uninstall the windows store version (it's known to be a little buggy at times). After that you might have to follow additional cleanup instructions.
Next install the normal version and report back.
its a (Error compiling for board Arduino Uno)
some resign i cant put picture on here, it keep saying 9000 word limit
it is a original board.
this site is making me wait for 5 minutes to post something new
The 5 minute wait will persist until you reach 100 posts.
It helps prevent SPAM.
Your errors are showing LINKER issues.
Not 100% sure why you need a library for that sketch either maybe you could also try the BLINK from the IDE's examples ?
That message about the "build.board" not being defined is the symptom of a botched attempt at modifying the included Arduino AVR board package. "Likely by following instructions written for a much older version of Arduino.
In and of itself that is not a problem - however, considering that you have a wacky error message implying some sort of abomination-crawling-in-from-the-depths-of-hell toolchain problem, I an suspicious that this failed attempt at modifying your build environment is the cause of that issue as well.
Uninstall all copies of the Arduino IDE.
Make a back up of C:\Users\YourUserName\AppData\Local\Arduino15, and then delete it. Reinstall the Arduino IDE, use the latest version, 1.8.13 downloaded from the Software link at the top (don't mess with the stupid windows store package; "app stores" are not a viable way to obtain software for real computers)
The sketch should now compile.
DrAzzy:
This warning is for the "breadboard" boards package that accompanies the "Minimal Circuit (Eliminating the External Clock)" of this tutorial:
So that warning is normal and expected and doesn't have anything to do with the real error.
That's not to argue against DrAzzy's advice. But I just want it to be understood that even after doing that you're still going to be getting the "Warning: Board breadboard:avr:atmega328bb doesn't define a 'build.board' preference. Auto-set to: AVR_ATMEGA328BB".
i reinstall it and still get this.
Now try to upload.
upload what again
Your code; looks like you only compiled but did not upload.
i got this now
Go to Tools -> Preferences
  1. Enable verbose output during upload
  2. Disable verbose output during compilation
Upload again; use the button 'copy error message' at the right above the output pane.
Post the result AS TEXT. If it's too big, put it in a text file (not PDF or Word) and attach to a post. To see the attachment option, use the reply button, not the quick reply box.
i got this message now
AS TEXT! :o
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Sketch uses 944 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -V -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Scotty Willimas\AppData\Local\Temp\arduino_build_740670/sketch_feb24asss.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\.\COM3": The system cannot find the file specified.
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
