Error compiling Bootloader?
I have a second ATmega328 chip on breadboard using TinyUSBISP to burn the bootloader.
I seem to be having an error in Main when checking the script before I load it to the chip
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=101 -IC:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\arduino\cores\arduino -IC:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\arduino\variants\standard C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\sketch_oct07a.cpp -o C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\sketch_oct07a.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WInterrupts.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_analog.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_digital.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_pulse.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_shift.c.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\CDC.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\HardwareSerial.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\HID.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\IPAddress.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\main.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\new.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Print.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Stream.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Tone.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\USBCore.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WMath.cpp.o
Using previously compiled: C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WString.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WInterrupts.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_analog.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_digital.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_pulse.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\wiring_shift.c.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\CDC.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\HardwareSerial.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\HID.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\IPAddress.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\main.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\new.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Print.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Stream.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\Tone.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\USBCore.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WMath.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-ar rcs C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\WString.cpp.o
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\tools\avr\bin\avr-gcc -Os -Wl,–gc-sections -mmcu=atmega328p -o C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\sketch_oct07a.cpp.elf C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\sketch_oct07a.cpp.o C:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp\core.a -LC:\Users\pcfr33k\AppData\Local\Temp\build6502781173554477768.tmp -lm
core.a(main.cpp.o): In function main': C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to setup’
C:\Users\pcfr33k\Downloads\arduino-1.0.1\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop’
You appear to be compiling with main() for sketches, bootloader shouldn't pull that in, has its own main I think.
That must be why. I still have a problem though. I get an error if I do not hold down the manual reset switch until its done?
I have it on a breadboard with a Manual Reset switch with Resister and capacitor. If I hold switch down switch the entire time I get a successful burn and verification.
If I hold it down 3/4 of the time and let it go before its done burning and verifying, I get a verification error at the end!!
For example Verification Error, first mismatch at byte 0x0000 0xff != 0x04 Content mismatch
