Error Compiling Code with Several Files "Multiple Definitions"
Hey Everyone!
I'm new to Arduino and am trying to control a LED strip with an IR Remote using Object Oriented Programming. The first step is to set up the <FastLED.h> and <IRremote.h> library in my classes, but I need some help getting past an error. Here is my code and the error:
Main File:
#include "IRnLED.h"
#include "patterns.h"
#include <IRremote.h>
#include <FastLED.h>
//variables
#define NUM_LEDS 150
int irPin = 3;
//objects
CRGB leds[NUM_LEDS];
Patterns patterns(leds);
IRrecv ir(irPin);
decode_results cmd;
IRnLED irnled(ir, cmd, patterns, irPin);
patterns.init();
irnled.init();
IRnLED.h
#ifndef IRNLED_H
#define IRNLED_H
#include <Arduino.h>
class IRnLED
private:
  IRrecv ir;
  decode_results cmd;
  Patterns patterns;
  int IR_PIN;
  int started;
public:
  IRnLED(){}; //do not use //have in case object from this class is being used in another
  IRnLED (IRrecv &ir, decode_results cmd, Patterns &patterns, int IR_PIN);
  void init();
#endif
IRnLED.cpp
#include "IRnLED.h"
IRnLED::IRnLED (IRrecv &ir, decode_results cmd, Patterns &patterns, int IR_PIN) {
  this->ir = ir;
  this->cmd = cmd;
  this->patterns = patterns;
  this->IR_PIN = IR_PIN;
void IRnLED::init(){
    ir.enableIRIn();
    started = 1;
patterns.h
#ifndef PATTERNS_H
#define PATTERNS_H
class Patterns
private:
CRGB *leds;
#define LED_PIN 5
#define BRIGHT 10
public:
Patterns(){};//do not use
Patterns(CRGB leds[NUM_LEDS]);
void init();
#endif
patterns.cpp
Patterns::Patterns(CRGB leds[NUM_LEDS])
  this-> leds = leds;
void Patterns::init()
  FastLED.addLeds<WS2812B, LED_PIN, GRB>(leds, NUM_LEDS);
  FastLED.setBrightness(BRIGHT);
  FastLED.clear();
  FastLED.show();
Error Compiling for board Arduino Uno
Arduino: 1.8.17 Hourly Build 2021/09/06 02:34 (Mac OS X), Board: "Arduino Uno"
In file included from /Users/andy/Documents/Arduino/Remote_LED_Project_TestInitalizing/patterns.h:5:0,
                 from /Users/andy/Documents/Arduino/Remote_LED_Project_TestInitalizing/IRnLED.h:7,
                 from /Users/andy/Documents/Arduino/Remote_LED_Project_TestInitalizing/Remote_LED_Project_TestInitalizing.ino:13:
/Users/andy/Documents/Arduino/libraries/FastLED/src/FastLED.h:14:21: note: #pragma message: FastLED version 3.004.000
 #    pragma message "FastLED version 3.004.000"
sketch/Remote_LED_Project_TestInitalizing.ino.cpp.o (symbol from plugin): In function `irparams':
(.text+0x0): multiple definition of `irparams'
sketch/IRnLED.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `timerConfigForSend(unsigned char)'
(.text+0x0): multiple definition of `timerConfigForReceive()'
(.text+0x0): multiple definition of `setLEDFeedback(unsigned char, bool)'
(.text+0x0): multiple definition of `FeedbackLEDControl'
(.text+0x0): multiple definition of `setLEDFeedback(bool)'
(.text+0x0): multiple definition of `enableLEDFeedback()'
(.text+0x0): multiple definition of `disableLEDFeedback()'
(.text+0x0): multiple definition of `setFeedbackLED(bool)'
(.text+0x0): multiple definition of `IRrecv::blink13(bool)'
(.text+0x0): multiple definition of `setBlinkPin(unsigned char)'
(.text+0x0): multiple definition of `IRrecv::setReceivePin(unsigned char)'
(.text+0x0): multiple definition of `IRrecv::IRrecv()'
(.text+0x0): multiple definition of `IRrecv::IRrecv(unsigned char)'
(.text+0x0): multiple definition of `IrReceiver'
(.text+0x0): multiple definition of `IRrecv::IRrecv(unsigned char, unsigned char)'
(.text+0x0): multiple definition of `IRrecv::stop()'
(.text+0x0): multiple definition of `IRrecv::end()'
(.text+0x0): multiple definition of `IRrecv::disableIRIn()'
(.text+0x0): multiple definition of `IRrecv::isIdle()'
(.text+0x0): multiple definition of `IRrecv::resume()'
(.text+0x0): multiple definition of `IRrecv::enableIRIn()'
(.text+0x0): multiple definition of `IRrecv::begin(unsigned char, bool, unsigned char)'
(.text+0x0): multiple definition of `IRrecv::start()'
(.text+0x0): multiple definition of `IRrecv::start(unsigned long)'
(.text+0x0): multiple definition of `IRrecv::initDecodedIRData()'
(.text+0x0): multiple definition of `IRrecv::available()'
(.text+0x0): multiple definition of `IRrecv::initBiphaselevel(unsigned char, unsigned int)'
(.text+0x0): multiple definition of `sBiphaseDecodeRawbuffOffset'
(.text+0x0): multiple definition of `sBiphaseTimeUnit'
(.text+0x0): multiple definition of `sUsedTimingIntervals'
(.text+0x0): multiple definition of `IRrecv::compare(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `IRrecv::decodeHash()'
(.text+0x0): multiple definition of `IRrecv::decode()'
(.text+0x0): multiple definition of `IRrecv::read()'
(.text+0x0): multiple definition of `IRrecv::decodeHashOld(decode_results*)'
(.text+0x0): multiple definition of `matchTicks(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `IRrecv::getBiphaselevel()'
(.text+0x0): multiple definition of `sCurrentTimingIntervals'
(.text+0x0): multiple definition of `MATCH(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `matchMark(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `MATCH_MARK(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `matchSpace(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `IRrecv::decodePulseWidthData(unsigned char, unsigned char, unsigned int, unsigned int, unsigned int, bool)'
(.text+0x0): multiple definition of `IRrecv::decodePulseDistanceData(unsigned char, unsigned char, unsigned int, unsigned int, unsigned int, bool)'
(.text+0x0): multiple definition of `MATCH_SPACE(unsigned int, unsigned int)'
(.text+0x0): multiple definition of `getMarkExcessMicros()'
(.text+0x0): multiple definition of `CheckForRecordGapsMicros(Print*, IRData*)'
(.text+0x0): multiple definition of `IRrecv::printIRResultMinimal(Print*)'
(.text+0x0): multiple definition of `IRrecv::printIRResultRawFormatted(Print*, bool)'
(.text+0x0): multiple definition of `IRrecv::compensateAndStoreIRResultInArray(unsigned char*)'
(.text+0x0): multiple definition of `IRrecv::printIRResultAsCVariables(Print*)'
(.text+0x0): multiple definition of `getProtocolString(decode_type_t)'
(.text+0x0): multiple definition of `printIRResultShort(Print*, IRData*, unsigned int)'
(.text+0x0): multiple definition of `IRrecv::printIRResultShort(Print*)'
(.text+0x0): multiple definition of `IRrecv::compensateAndPrintIRResultAsCArray(Print*, bool)'
(.text+0x0): multiple definition of `__vector_8'
(.text+0x0): multiple definition of `IRrecv::decode(decode_results*)'
(.text+0x0): multiple definition of `IRsend::IRsend()'
(.text+0x0): multiple definition of `IRsend::IRsend(unsigned char)'
(.text+0x0): multiple definition of `IRsend::setSendPin(unsigned char)'
(.text+0x0): multiple definition of `IRsend::begin(unsigned char, bool, unsigned char)'
(.text+0x0): multiple definition of `IRsend::begin(bool, unsigned char)'
(.text+0x0): multiple definition of `IRsend::write(IRData*, unsigned char)'
(.text+0x0): multiple definition of `IRsend::mark(unsigned int)'
(.text+0x0): multiple definition of `IRsend::IRLedOff()'
(.text+0x0): multiple definition of `IRsend::customDelayMicroseconds(unsigned long)'
(.text+0x0): multiple definition of `IRsend::space(unsigned int)'
(.text+0x0): multiple definition of `IRsend::sendPulseDistanceWidthData(unsigned int, unsigned int, unsigned int, unsigned int, unsigned long, unsigned char, bool, bool)'
(.text+0x0): multiple definition of `IRsend::sendBiphaseData(unsigned int, unsigned long, unsigned char)'
(.text+0x0): multiple definition of `IRsend::enableIROut(unsigned char)'
(.text+0x0): multiple definition of `IRsend::sendRaw(unsigned int const*, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `IRsend::sendRaw(unsigned char const*, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `IRsend::sendRaw_P(unsigned int const*, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `IRsend::sendRaw_P(unsigned char const*, unsigned char, unsigned char)'
(.text+0x0): multiple definition of `IRsend::getPulseCorrectionNanos()'
(.text+0x0): multiple definition of `IrSender'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Uno.
option enabled in File -> Preferences.
Thanks for your help.
Welcome
When you do this
private:
  IRrecv ir;
You are creating an instance of the IRrecv class, and calling its constructor
But multiple instances of this class are not supported, so instead, you should use a pointer
Or, perhaps more "C++'ish" to use a reference.
You will also run into problems using FastLED and IRRemote. IRremote relies on interrupts to send/receive signals. FastLED relies on turning interrupts OFF when clocking data out to the leds so it can match the precise timing requirements. Those two requirements don't play together :frowning:
With Teensy (and perhaps other boards), you can push the LED data out via DMA and leave interrupts enabled. The Teensy Library can also hook into Fast LED. See the examples.
Alternately, you can switch to SPI-based LEDS (i.e. APA102 ). Interrupts don't need to be disabled to drive these.
Thank you for the help! I am still struggling to put your advice into action. Could you show me how exactly I should format it in the code so that it will compile?
Here is an example : ICNRM8 - Online C++ Compiler & Debugging Tool - Ideone.com
But you should consider what others said about interrupts
