I try to make a project esp8266 with P10 display. I found an example from
After I compile found error:
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
Compile error if these two libraries are combined. Although these libraries can be compiled separately. I tried to separate the program into two programs
Here are two program that can compiled. Program1
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
char MESSAGE[255]; //Store the message
const char MAIN_page[] PROGMEM = R"=====(
<!DOCTYPE html>
<html>
<body>
<center>
<h1>Matrix Display Controller<h1>
<form action="/action_page">
Enter Text :<br><br>
<input type="text" name="msg" value="Enter your text here">
<br><br>
<input type="submit" value="Submit">
</form>
</center>
</body>
</html>
//SSID and Password of your WiFi router
const char* ssid = "ssid_name";
const char* password = "password";
ESP8266WebServer server(80); //Server on port 80
void handleRoot() {
String s = MAIN_page; //Read HTML contents
server.send(200, "text/html", s); //Send web page
void handleForm() {
String msg = server.arg("msg");
int msg_len = msg.length() + 1;
MESSAGE[msg_len];
msg.toCharArray(MESSAGE, msg_len);
//Scroll();
void setup(void){
WiFi.begin(ssid, password); //Connect to your WiFi router
Serial.println("");
// Wait for connection
Serial.print(".");
//If connection successful show IP address in serial monitor
Serial.println("");
Serial.print("Connected to ");
Serial.println("WiFi");
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
server.on("/", handleRoot); //Which routine to handle at root location
server.on("/action_page", handleForm); //form action is handled here
server.begin(); //Start server
Serial.println("HTTP server started");
//dmd.setBrightness(255);
//dmd.selectFont(FONT);
//dmd.begin();
void loop(void){
server.handleClient(); //Handle client requests
Program2
#include <SPI.h>
#include <DMD2.h>
#include <fonts/Arial14.h>
// Set Width and Hight to the number of displays you have
const int WIDTH = 1;
const int HIGHT = 1;
const uint8_t *FONT = Arial14;
SPIDMD dmd(WIDTH , HIGHT, 5, 16, 2, 12); // DMD controls the entire display
DMD_TextBox box(dmd); // "box" provides a text box to automatically write to/scroll the display
void Scroll(){
const char *next = MESSAGE;
while(*next) {
Serial.print(*next);
box.print(*next);
delay(200);
next++;
void setup(void){
dmd.begin();
void loop(void){
Scroll();
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
When you encounter an error, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
Open a forum reply here by clicking the Reply button.
Click the </> icon on the post composer toolbar. This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press Ctrl+V. This will paste the compilation output into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Thank you for response.
here is the error for the original program from the website.
Arduino: 1.8.0 (Windows 10), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:3MB OTA:~512KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Build options changed, rebuilding all
In file included from c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\memory:81:0,
from C:\tmp18\arduino1-8-2\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/ESP8266WiFiGeneric.h:28,
from C:\tmp18\arduino1-8-2\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/ESP8266WiFiSTA.h:28,
from C:\tmp18\arduino1-8-2\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/ESP8266WiFi.h:34,
from C:\tmp18\arduino1-8-2\project\P10_web\P10_web.ino:1:
c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\unique_ptr.h: In instantiation of 'void std::unique_ptr<_Tp, _Dp>::reset(std::unique_ptr<_Tp, _Dp>::pointer) [with _Tp = HTTPUpload; _Dp = std::default_delete<HTTPUpload>; std::unique_ptr<_Tp, _Dp>::pointer = HTTPUpload*]':
C:\tmp18\arduino1-8-2\portable\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WebServer\src/ESP8266WebServer-impl.h:365:26: required from 'void esp8266webserver::ESP8266WebServerTemplate<ServerType>::handleClient() [with ServerType = WiFiServer]'
C:\tmp18\arduino1-8-2\project\P10_web\P10_web.ino:108:23: required from here
c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\unique_ptr.h:260:29: error: call of overloaded 'swap(HTTPUpload*&, HTTPUpload*&)' is ambiguous
swap(std::get<0>(_M_t), __p);
c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\unique_ptr.h:260:29: note: candidates are:
In file included from c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_pair.h:59:0,
from c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\utility:70,
from c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\algorithm:60,
from C:\tmp18\arduino1-8-2\portable\packages\esp8266\hardware\esp8266\2.7.4\cores\esp8266/Arduino.h:238,
from sketch\P10_web.ino.cpp:1:
c:\tmp18\arduino1-8-2\portable\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-4-b40a506\xtensa-lx106-elf\include\c++\4.8.2\bits\move.h:166:5: note: void std::swap(_Tp&, _Tp&) [with _Tp = HTTPUpload*]
swap(_Tp& __a, _Tp& __b)
In file included from C:\tmp18\arduino1-8-2\project\P10_web\P10_web.ino:6:0:
C:\tmp18\arduino1-8-2\portable\sketchbook\libraries\DMD2-0.0.3/DMD2.h:45:41: note: void swap(T&, T&) [with T = HTTPUpload*]
template<typename T> static inline void swap(T &a, T &b)
exit status 1
option enabled in File -> Preferences.
