I am using the following sketch to test my new Ethernet shield, but it does not compile, giving errors see below) :
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 4 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
//changed this section :
//byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
//IPAddress ip(192,168,1,102); // ip in lan
//IPAddress gateway(192,168,1,1); // internet access via router
//IPAddress subnet(255,255,255,0); //subnet mask
//IPAddress myserver(208,104,2,86); // zoomkat web page
//EthernetServer server(84); //server port
//changed to :
IPAddress ip(192,168,1,101); // ip in lan
IPAddress gateway(192,168,1,254); // internet access via router
IPAddress myserver(41,204,200,12);
EthernetServer server(82); //server port
EthernetClient client;
String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control
Ethernet.begin(mac, ip, subnet, gateway);
server.begin();
Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
Serial.println("Send an g in serial monitor to test client"); // what to do to test client
void loop(){
// check for serial input
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call sendGET function
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
//client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
client.println("<IFRAME name=inlineframe style=\"display:none\" >");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on") >0)//checks for on
digitalWrite(4, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(4, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
void sendGET() //client function to send/receie GET request data.
if (client.connect(myserver, 80)) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
else {
Serial.println("connection failed");
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println("disconnecting.");
Serial.println("==================");
client.stop();
However, it does not compile, giving the following errors :
In file included from C:\Program Files\arduino\libraries\Ethernet/Client.h:3,
from C:\Program Files\arduino\libraries\Ethernet/EthernetClient.h:5,
from C:\Program Files\arduino\libraries\Ethernet/Ethernet.h:7,
from EtherTest.cpp:12:
C:\Program Files\arduino\hardware\arduino\cores\arduino/WProgram.h:22: error: default argument given for parameter 3 of 'long unsigned int pulseIn(uint8_t, uint8_t, long unsigned int)'
C:\Program Files\arduino\hardware\arduino\cores\arduino/wiring.h:120: error: after previous specification in 'long unsigned int pulseIn(uint8_t, uint8_t, long unsigned int)'
C:\Program Files\arduino\hardware\arduino\cores\arduino/WProgram.h:24: error: default argument given for parameter 3 of 'void tone(uint8_t, unsigned int, long unsigned int)'
C:\Program Files\arduino\hardware\arduino\cores\arduino/Arduino.h:201: error: after previous specification in 'void tone(uint8_t, unsigned int, long unsigned int)'
In file included from C:\Program Files\arduino\libraries\Ethernet/EthernetClient.h:5,
C:\Program Files\arduino\libraries\Ethernet/Client.h:15: error: conflicting return type specified for 'virtual void Client::write(uint8_t)'
C:\Program Files\arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/Client.h:17: error: conflicting return type specified for 'virtual void Client::write(const uint8_t*, size_t)'
C:\Program Files\arduino\hardware\arduino\cores\arduino/Print.h:50: error: overriding 'virtual size_t Print::write(const uint8_t*, size_t)'
In file included from C:\Program Files\arduino\libraries\Ethernet/Ethernet.h:7,
C:\Program Files\arduino\libraries\Ethernet/EthernetClient.h:17: error: conflicting return type specified for 'virtual size_t EthernetClient::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/Client.h:15: error: overriding 'virtual void Client::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/EthernetClient.h:18: error: conflicting return type specified for 'virtual size_t EthernetClient::write(const uint8_t*, size_t)'
C:\Program Files\arduino\libraries\Ethernet/Client.h:17: error: overriding 'virtual void Client::write(const uint8_t*, size_t)'
In file included from C:\Program Files\arduino\libraries\Ethernet/EthernetServer.h:4,
from C:\Program Files\arduino\libraries\Ethernet/Ethernet.h:8,
C:\Program Files\arduino\libraries\Ethernet/Server.h:17: error: conflicting return type specified for 'virtual void Server::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/Server.h:19: error: conflicting return type specified for 'virtual void Server::write(const uint8_t*, size_t)'
In file included from C:\Program Files\arduino\libraries\Ethernet/Ethernet.h:8,
C:\Program Files\arduino\libraries\Ethernet/EthernetServer.h:17: error: conflicting return type specified for 'virtual size_t EthernetServer::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/Server.h:17: error: overriding 'virtual void Server::write(uint8_t)'
C:\Program Files\arduino\libraries\Ethernet/EthernetServer.h:18: error: conflicting return type specified for 'virtual size_t EthernetServer::write(const uint8_t*, size_t)'
C:\Program Files\arduino\libraries\Ethernet/Server.h:19: error: overriding 'virtual void Server::write(const uint8_t*, size_t)'
I have the Ethernet and SPI libraries in place as they were installed when I originally installed the Arduino IDE.
Suggestions please.
