Error compiling for Arduino Nano
Hi all, this is my first post here.
I'm trying to upload this sketch to an arduino nano but the compile process gives me the error below.
I didn't modify the sketch at all, just added the requested file 'PS2Mouse.h' to the same directory as the sketch file.
Not sure how to solve this.
Any help will be very appreciated.
Thanks
error code:
Arduino: 1.8.13 (Windows 10), Board: "Arduino Nano, ATmega328P"
libraries\PS2-Mouse-Arduino-master\PS2Mouse.cpp.o (symbol from plugin): In function `PS2Mouse::PS2Mouse(int, int, int)':
(.text+0x0): multiple definition of `PS2Mouse::PS2Mouse(int, int, int)'
sketch\PS2Mouse.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `PS2Mouse::clock_pin()'
(.text+0x0): multiple definition of `PS2Mouse::data_pin()'
(.text+0x0): multiple definition of `PS2Mouse::read_bit()'
(.text+0x0): multiple definition of `PS2Mouse::pull_low(int)'
(.text+0x0): multiple definition of `PS2Mouse::pull_high(int)'
(.text+0x0): multiple definition of `PS2Mouse::write(int)'
(.text+0x0): multiple definition of `PS2Mouse::read_byte()'
(.text+0x0): multiple definition of `PS2Mouse::enable_data_reporting()'
(.text+0x0): multiple definition of `PS2Mouse::disable_data_reporting()'
(.text+0x0): multiple definition of `PS2Mouse::set_mode(int)'
(.text+0x0): multiple definition of `PS2Mouse::set_remote_mode()'
(.text+0x0): multiple definition of `PS2Mouse::set_stream_mode()'
(.text+0x0): multiple definition of `PS2Mouse::set_scaling_2_1()'
(.text+0x0): multiple definition of `PS2Mouse::set_scaling_1_1()'
(.text+0x0): multiple definition of `PS2Mouse::set_sample_rate(int)'
(.text+0x0): multiple definition of `PS2Mouse::set_resolution(int)'
(.text+0x0): multiple definition of `PS2Mouse::read()'
(.text+0x0): multiple definition of `PS2Mouse::read_movement_x(int)'
(.text+0x0): multiple definition of `PS2Mouse::read_movement_y(int)'
(.text+0x0): multiple definition of `PS2Mouse::report(int*)'
(.text+0x0): multiple definition of `PS2Mouse::initialize()'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
It looks like you installed the PS2Mouse library and copied the code to the sketch's directory, so the IDE finds and compiles it twice.
pylon:
Thank you!!! I've deleted the files in the folder and it worked.
Thank you for your help.
