I encountered problem regarding to compile the DFrobot EC sensor with my Arduino R4 wifi. the result stated that error compiling. can someone help me? Thanks
Welcome to the forum!
Can we see the error and the wiring diagram?
For wiring diagram, i have the same one with the websites wheres
Arduino uno R4 EC sensor
A1 A
5V VCC
GND GND
this one for coding;
#include "DFRobot_EC.h"
#include <EEPROM.h>
#define EC_PIN A1
float voltage,ecValue;
DFRobot_EC ec;
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into digital pin 2 on the Arduino
#define ONE_WIRE_BUS 4
// Setup a oneWire instance to communicate with any OneWire device
OneWire oneWire(ONE_WIRE_BUS);
// Pass oneWire reference to DallasTemperature library
DallasTemperature sensors(&oneWire);
float tempValue;
float salinity;
ec.begin();
static unsigned long timepoint = millis();
if(millis()-timepoint>1000U) //time interval: 1s
voltage = analogRead(EC_PIN)/1024.0*5000; // read the voltage
//temperature = readTemperature(); // read your temperature sensor to execute temperature
sensors.requestTemperatures();
float tempValue = 1.0161 * (sensors.getTempCByIndex(0)) + 0.8916;
ecValue = ec.readEC(voltage,tempValue); // convert voltage to EC with temperature compensation
float salinity = ecValue*0.50;
Serial.print("temperature:");
Serial.print(tempValue,1);
Serial.print("^C EC:");
Serial.print(ecValue,2);
Serial.println("ms/cm");
Serial.print("salinity: ");
Serial.print(salinity);
Serial.println(" ppt");
ec.calibration(voltage,tempValue); // calibration process by Serail CMD
float readTemperature()
Serial.print("Temperature: ");
Serial.print(tempValue);
Serial.print("C / ");
but it stated that error compiling in aduino board r4 wifi
And now the full error, please. Use code tags as well for that.
I was able to recreate the error in my IDE for Arduino, and it appears that libraries, #include <DallasTemperature.h> and #include "DFRobot_EC.h" have to be installed through zip file on github. But in OneWire.h from #include <DallasTemperature.h>, there is a missing header file I could not find anywhere that is called "main.h." this is as far as I was able to trace the error in the code when I recreated the code in my IDE.
If you want to see the error I recreated in the IDE here it is after I installed the two libraries.
FQBN: arduino:renesas_uno:unor4wifi
Using board 'unor4wifi' from platform in folder: C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2
Using core 'arduino' from platform in folder: C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2
Detecting libraries used...
C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED/Experimental_Sketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/tinyusb -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4 -iprefixC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2 @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/includes.txt C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED\sketch\Experimental_Sketch.ino.cpp -o nul
Alternatives for DFRobot_EC.h: [DFRobot_EC-master]
ResolveLibrary(DFRobot_EC.h)
-> candidates: [DFRobot_EC-master]
C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED/Experimental_Sketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/tinyusb -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4 -Ic:\Users\dcsie\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master -iprefixC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2 @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/includes.txt C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED\sketch\Experimental_Sketch.ino.cpp -o nul
Alternatives for EEPROM.h: [EEPROM@1.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@1.0]
C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED/Experimental_Sketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/tinyusb -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4 -Ic:\Users\dcsie\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\libraries\EEPROM\src -iprefixC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2 @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/includes.txt C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED\sketch\Experimental_Sketch.ino.cpp -o nul
Alternatives for virtualEEPROM.h: [BlockDevices]
ResolveLibrary(virtualEEPROM.h)
-> candidates: [BlockDevices]
C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED/Experimental_Sketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/tinyusb -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4 -Ic:\Users\dcsie\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\libraries\EEPROM\src -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\libraries\BlockDevices -iprefixC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2 @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/includes.txt C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED\sketch\Experimental_Sketch.ino.cpp -o nul
Alternatives for OneWire.h: [STM32_OneWire_DallasTemperature_HAL_UART_DMA-master]
ResolveLibrary(OneWire.h)
-> candidates: [STM32_OneWire_DallasTemperature_HAL_UART_DMA-master]
C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10607 -DPROJECT_NAME="C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED/Experimental_Sketch.ino" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/defines.txt -DCFG_TUSB_MCU=OPT_MCU_RAXXX -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/tinyusb -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino/api/deprecated-avr-comp -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\cores\arduino -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4 -Ic:\Users\dcsie\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\libraries\EEPROM\src -IC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\libraries\BlockDevices -Ic:\Users\dcsie\OneDrive\Documents\Arduino\libraries\STM32_OneWire_DallasTemperature_HAL_UART_DMA-master -iprefixC:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2 @C:\Users\dcsie\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.2.2\variants\UNOWIFIR4/includes.txt C:\Users\dcsie\AppData\Local\arduino\sketches\5BA9A9E80AEDD90BF992B3F8EC6426ED\sketch\Experimental_Sketch.ino.cpp -o nul
In file included from C:\Users\dcsie\AppData\Local\Arduino15\RemoteSketchbook\ArduinoCloud\44d01621-cf9d-4794-8749-76dd4dde2c73\Experimental_Sketch\Experimental_Sketch.ino:8:0:
c:\Users\dcsie\OneDrive\Documents\Arduino\libraries\STM32_OneWire_DallasTemperature_HAL_UART_DMA-master/OneWire.h:11:10: fatal error: main.h: No such file or directory
#include "main.h"
compilation terminated.
Alternatives for main.h: []
ResolveLibrary(main.h)
-> candidates: []
exit status 1
Compilation error: exit status 1
And like I said, I could not find anything further than this.
I suggest to remove this library as it does not seem relevant to your R4 WiFi project. The STM32 is a type of microprocessor not used in the R4. You may need to find a more relevant library.
Please describe your setup more completely. Posting suggestions are in the "How to get the best out of this forum" post.
this is the full error
`Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino UNO R4 WiFi"
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp: In member function 'void DFRobot_EC::calibration(float, float, char*)':
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp:85:5: error: 'strupr' was not declared in this scope
strupr(cmd);
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp:85:5: note: suggested alternative: 'strdup'
strupr(cmd);
strdup
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp: In member function 'boolean DFRobot_EC::cmdSerialDataAvailable()':
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp:114:13: error: 'strupr' was not declared in this scope
strupr(this->_cmdReceivedBuffer);
C:\Users\User\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp:114:13: note: suggested alternative: 'strdup'
strdup
exit status 1
Error compiling for board Arduino UNO R4 WiFi.
Invalid library found in C:\Users\User\Documents\Arduino\libraries\Adafruit_ADS1015-1.0.0-02832056.tar: Missing 'maintainer' from library
option enabled in File -> Preferences.
Your code does compile here
I've installed the following libraries:
- GitHub - DFRobot/DFRobot_EC: Arduino library for Gravity: Analog Electrical Conductivity Sensor / Meter Kit V2 (K=1.0), SKU: DFR0300
- DallasTemperature using library manager
- OneWire using library manager.
Excerpt from the compiler output to show the libraries used:
Using library DFRobot_EC-master in folder: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master (legacy)
Using library EEPROM at version 1.0 in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\EEPROM
Using library BlockDevices in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices (legacy)
Using library OneWire at version 2.3.8 in folder: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\OneWire
Using library DallasTemperature at version 3.9.0 in folder: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\DallasTemperature
Using library Storage in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage (legacy)
IDE 1.8.19
To ignore warnings in libraries, this is the result of the second compile. You will need to fix the warnings to prevent undefined behaviour of your sketch.
C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\hardware -hardware C:\Users\bugge\AppData\Local\Arduino15\packages -hardware C:\Users\bugge\OneDrive\Documents\Arduino\hardware -tools C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\tools-builder -tools C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\hardware\tools\avr -tools C:\Users\bugge\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\libraries -libraries C:\Users\bugge\OneDrive\Documents\Arduino\libraries -fqbn=arduino:renesas_uno:unor4wifi -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\bugge\AppData\Local\Temp\arduino_build_163942 -warnings=all -build-cache C:\Users\bugge\AppData\Local\Temp\arduino_cache_814116 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.bossac.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino5 -prefs=runtime.tools.bossac-1.9.1-arduino5.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino5 -verbose C:\Users\bugge\AppData\Local\Temp\arduino_modified_sketch_692955\sketch_dec18a.ino
C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\arduino-builder -compile -logger=machine -hardware C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\hardware -hardware C:\Users\bugge\AppData\Local\Arduino15\packages -hardware C:\Users\bugge\OneDrive\Documents\Arduino\hardware -tools C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\tools-builder -tools C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\hardware\tools\avr -tools C:\Users\bugge\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\bugge\OneDrive\Documents\ArduinoIDE\0_arduino-1.8.19.nonPortable\libraries -libraries C:\Users\bugge\OneDrive\Documents\Arduino\libraries -fqbn=arduino:renesas_uno:unor4wifi -vid-pid=2341_0042 -ide-version=10819 -build-path C:\Users\bugge\AppData\Local\Temp\arduino_build_163942 -warnings=all -build-cache C:\Users\bugge\AppData\Local\Temp\arduino_cache_814116 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.dfu-util.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.arm-none-eabi-gcc.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\7-2017q4 -prefs=runtime.tools.openocd.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.openocd-0.11.0-arduino2.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\openocd\0.11.0-arduino2 -prefs=runtime.tools.bossac.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino5 -prefs=runtime.tools.bossac-1.9.1-arduino5.path=C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.9.1-arduino5 -verbose C:\Users\bugge\AppData\Local\Temp\arduino_modified_sketch_692955\sketch_dec18a.ino
Using board 'unor4wifi' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1
Using core 'arduino' from platform in folder: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\BlockDevices" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
Alternatives for OneWire.h: [OneWire@2.3.8]
-> candidates: [OneWire@2.3.8]
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\BlockDevices" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\OneWire" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
Alternatives for DallasTemperature.h: [DallasTemperature@3.9.0]
ResolveLibrary(DallasTemperature.h)
-> candidates: [DallasTemperature@3.9.0]
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\BlockDevices" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DallasTemperature" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\DFRobot_EC-master\DFRobot_EC.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\BlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\BufferedBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\ChainingBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\CodeFlashBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\DataFlashBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\ExhaustibleBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\FlashSimBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\HeapBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\MBRBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\ObservingBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\QSPIFlashBlockDevice.cpp
Alternatives for storage_retarget.h: [Storage]
ResolveLibrary(storage_retarget.h)
-> candidates: [Storage]
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\ReadOnlyBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\SDCardBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\SlicingBlockDevice.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\BlockDevices\virtualEEPROM.cpp
Using cached library dependencies for file: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\OneWire\OneWire.cpp
Using cached library dependencies for file: C:\Users\bugge\OneDrive\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\Dir.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\File.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\FileBase.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\FileHandle.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\FilePath.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\FileSystem.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\FileSystemHandle.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\storage_common.cpp
Using cached library dependencies for file: C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\Storage\storage_retarget.cpp
Generating function prototypes...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -w -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -w -x c++ -E -CC -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\BlockDevices" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DallasTemperature" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\Storage" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\bugge\\OneDrive\\Documents\\ArduinoIDE\\0_arduino-1.8.19.nonPortable\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -c -Wall -Wextra -Os -g3 -fno-use-cxa-atexit -fno-rtti -fno-exceptions -MMD -nostdlib -DF_CPU=48000000 -DNO_USB -DBACKTRACE_SUPPORT -DARDUINO_UNOR4_WIFI -MMD -std=gnu++17 -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -fsigned-char -ffunction-sections -fdata-sections -fmessage-length=0 -fno-builtin -DARDUINO=10819 "-DPROJECT_NAME=\"C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino\"" -DARDUINO_UNOWIFIR4 -DARDUINO_ARCH_RENESAS_UNO -DARDUINO_ARCH_RENESAS -DARDUINO_FSP -D_XOPEN_SOURCE=700 -mthumb "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/defines.txt" -DCFG_TUSB_MCU=OPT_MCU_RAXXX "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/tinyusb" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino/api/deprecated-avr-comp" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\cores\\arduino" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DFRobot_EC-master" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\EEPROM\\src" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\BlockDevices" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\OneWire" "-IC:\\Users\\bugge\\OneDrive\\Documents\\Arduino\\libraries\\DallasTemperature" "-IC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\libraries\\Storage" "-iprefixC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1" "@C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/includes.txt" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp" -o "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp.o"
C:\Users\bugge\AppData\Local\Temp\arduino_modified_sketch_692955\sketch_dec18a.ino: In function 'float readTemperature()':
C:\Users\bugge\AppData\Local\Temp\arduino_modified_sketch_692955\sketch_dec18a.ino:59:1: warning: no return statement in function returning non-void [-Wreturn-type]
In file included from C:\Users\bugge\AppData\Local\Temp\arduino_modified_sketch_692955\sketch_dec18a.ino:2:0:
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\EEPROM\src/EEPROM.h: At global scope:
C:\Users\bugge\AppData\Local\Arduino15\packages\arduino\hardware\renesas_uno\1.3.1\libraries\EEPROM\src/EEPROM.h:175:20: warning: 'EEPROM' defined but not used [-Wunused-variable]
static EEPROMClass EEPROM;
Compiling libraries...
Compiling library "DFRobot_EC-master"
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\DFRobot_EC-master\DFRobot_EC.cpp.o
Compiling library "EEPROM"
Compiling library "BlockDevices"
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\BlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\ReadOnlyBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\ExhaustibleBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\ChainingBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\CodeFlashBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\BufferedBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\DataFlashBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\MBRBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\HeapBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\ObservingBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\FlashSimBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\SlicingBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\QSPIFlashBlockDevice.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\virtualEEPROM.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\BlockDevices\SDCardBlockDevice.cpp.o
Compiling library "OneWire"
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\OneWire\OneWire.cpp.o
Compiling library "DallasTemperature"
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\DallasTemperature\DallasTemperature.cpp.o
Compiling library "Storage"
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\Dir.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\storage_common.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\File.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\FileHandle.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\FileSystem.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\FileBase.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\FilePath.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\FileSystemHandle.cpp.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\libraries\Storage\storage_retarget.cpp.o
Compiling core...
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\core\tmp_gen_c_files\pin_data.c.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\core\tmp_gen_c_files\common_data.c.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\core\tmp_gen_c_files\main.c.o
Using previously compiled file: C:\Users\bugge\AppData\Local\Temp\arduino_build_163942\core\variant.cpp.o
Using precompiled core: C:\Users\bugge\AppData\Local\Temp\arduino_cache_814116\core\core_arduino_renesas_uno_unor4wifi_1312c740a60cda6c69aaea67e5365a1e.a
Linking everything together...
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-g++" -Wl,--gc-sections --specs=nosys.specs -Wall -Wextra -mcpu=cortex-m4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -o "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.elf" "-LC:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942" "-LC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4" "-TC:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/fsp.ld" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\sketch\\sketch_dec18a.ino.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\DFRobot_EC-master\\DFRobot_EC.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\BlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\BufferedBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\ChainingBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\CodeFlashBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\DataFlashBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\ExhaustibleBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\FlashSimBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\HeapBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\MBRBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\ObservingBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\QSPIFlashBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\ReadOnlyBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\SDCardBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\SlicingBlockDevice.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\BlockDevices\\virtualEEPROM.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\OneWire\\OneWire.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\DallasTemperature\\DallasTemperature.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\Dir.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\File.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\FileBase.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\FileHandle.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\FilePath.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\FileSystem.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\FileSystemHandle.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\storage_common.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\libraries\\Storage\\storage_retarget.cpp.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\core\\tmp_gen_c_files\\common_data.c.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\core\\tmp_gen_c_files\\main.c.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\core\\tmp_gen_c_files\\pin_data.c.o" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942\\core\\variant.cpp.o" -Wl,--whole-archive -Wl,--start-group "C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\renesas_uno\\1.3.1\\variants\\UNOWIFIR4/libs/libfsp.a" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/..\\arduino_cache_814116\\core\\core_arduino_renesas_uno_unor4wifi_1312c740a60cda6c69aaea67e5365a1e.a" -Wl,--no-whole-archive --specs=nano.specs -lstdc++ -lsupc++ -lm -lc -lgcc -lnosys -Wl,--end-group "-Wl,-Map,C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.map"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O binary -j .text -j .data "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.bin"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-objcopy" -O ihex -j .text -j .data "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.elf" "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.hex"
"C:\\Users\\bugge\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\arm-none-eabi-gcc\\7-2017q4/bin/arm-none-eabi-size" -A "C:\\Users\\bugge\\AppData\\Local\\Temp\\arduino_build_163942/sketch_dec18a.ino.elf"
Sketch uses 60900 bytes (23%) of program storage space. Maximum is 262144 bytes.
Global variables use 7300 bytes (22%) of dynamic memory, leaving 25468 bytes for local variables. Maximum is 32768 bytes.
By the way, tar files don't belong in the libraries directory; remove it.
orite noted thanks a lot! the sensor can connect already with Arduino R4 thank you for your help!
