Error compiling for baord Arduino Uno
My code was working but I needed a different distance sensor so I switched from the lidar based sensor to an ultrasonic one. Now I get this error.
In file included from C:\Users\Jay\Documents\Arduino\brotel-with-sonar\brotel-with-sonar.ino:4:0:
C:\Users\Jay\Documents\Arduino\libraries\Adafruit_MQTT_Library/Adafruit_MQTT.h:54:0: warning: "DEBUG_PRINT" redefined
 #define DEBUG_PRINT(...)                                                       \
In file included from C:\Users\Jay\Documents\Arduino\libraries\Adafruit_FONA_Library/includes/platform/FONAPlatform.h:31:0,
                 from C:\Users\Jay\Documents\Arduino\libraries\Adafruit_FONA_Library/Adafruit_FONA.h:9,
                 from C:\Users\Jay\Documents\Arduino\brotel-with-sonar\brotel-with-sonar.ino:3:
C:\Users\Jay\Documents\Arduino\libraries\Adafruit_FONA_Library/includes/platform/FONAPlatStd.h:53:0: note: this is the location of the previous definition
 #define DEBUG_PRINT(...) DebugStream.print(__VA_ARGS__)
C:\Users\Jay\Documents\Arduino\libraries\Adafruit_MQTT_Library/Adafruit_MQTT.h:56:0: warning: "DEBUG_PRINTLN" redefined
 #define DEBUG_PRINTLN(...)                                                     \
C:\Users\Jay\Documents\Arduino\libraries\Adafruit_FONA_Library/includes/platform/FONAPlatStd.h:54:0: note: this is the location of the previous definition
 #define DEBUG_PRINTLN(...) DebugStream.println(__VA_ARGS__)
C:\Users\Jay\AppData\Local\Temp\cc14jaCj.ltrans0.ltrans.o: In function `setup':
C:\Users\Jay\Documents\Arduino\brotel-with-sonar/brotel-with-sonar.ino:106: undefined reference to `FONAconnect(__FlashStringHelper const*, __FlashStringHelper const*, __FlashStringHelper const*)'
collect2.exe: error: ld returned 1 exit status
Multiple libraries were found for "Adafruit_BusIO_Register.h"
 Used: C:\Users\Jay\Documents\Arduino\libraries\Adafruit_BusIO-master
 Not used: C:\Users\Jay\Documents\Arduino\libraries\Adafruit_BusIO
exit status 1
Error compiling for board Arduino Uno.
Here is my code.
#include <Adafruit_SleepyDog.h>
#include <SoftwareSerial.h>
#include "Adafruit_FONA.h"
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_FONA.h"
#include <ComponentObject.h>
#include <Wire.h>
#include <Adafruit_AHTX0.h>
/*************************** FONA Pins ***********************************/
// Default pins for Feather 32u4 FONA
#define FONA_RX  2
#define FONA_TX  3
#define FONA_RST 4
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
Adafruit_AHTX0 aht;
/************** Sonar Pin (PWN) ***********/
#define sensorPin 7
/************************* WiFi Access Point *********************************/
#define FONA_APN       "m2mglobal"
#define FONA_USERNAME  ""
#define FONA_PASSWORD  ""
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "*.*.*.*"
#define AIO_SERVERPORT  1883
#define AIO_USERNAME    ""
#define AIO_KEY         ""
/************ Global State (you don't need to change this!) ******************/
// Setup the FONA MQTT class by passing in the FONA class and MQTT server and login details.
Adafruit_MQTT_FONA mqtt(&fona, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
// You don't need to change anything below this line!
#define halt(s) { Serial.println(F( s )); while(1);  }
// FONAconnect is a helper function that sets up the FONA and connects to
// the GPRS network. See the fonahelper.cpp tab above for the source!
boolean FONAconnect(const __FlashStringHelper *apn, const __FlashStringHelper *username, const __FlashStringHelper *password);
/****************************** Feeds ***************************************/
// Setup a feed called 'photocell' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt, "sensors/temperature");
Adafruit_MQTT_Publish humidityPub = Adafruit_MQTT_Publish(&mqtt, "sensors/humidity");
Adafruit_MQTT_Publish depthPub = Adafruit_MQTT_Publish(&mqtt, "sensors/depth");
/*************************** Sketch Code ************************************/
// How many transmission failures in a row we're willing to be ok with before reset
uint8_t txfailures = 0;
#define MAXTXFAILURES 3
float distance = 0;
float duration = 0;
float snowDepth = 0;
  pinMode(sensorPin, INPUT);
Wire.begin();
  while (!Serial);
  // Watchdog is optional!
  //Watchdog.enable(8000);
    if (! aht.begin()) {
    Serial.println("Could not find AHT? Check wiring");
    while (1) delay(10);
  Serial.println("AHT10 or AHT20 found");
  Serial.println(F("Adafruit FONA MQTT demo"));
  //mqtt.subscribe(&onoffbutton);
  Watchdog.reset();
  delay(5000);  // wait a few seconds to stabilize connection
  Watchdog.reset();
  // Initialise the FONA module
  while (! FONAconnect(F(FONA_APN), F(FONA_USERNAME), F(FONA_PASSWORD))) {
    Serial.println("Retrying FONA");
  Serial.println(F("Connected to Cellular!"));
  Watchdog.reset();
  Watchdog.reset();
//uint32_t x=0;
    delay(42000);
/******** Read Sonar Sensor *************/
duration = pulseIn(sensorPin, HIGH);
distance = duration / 58;
snowDepth = distance / 2.54;
Serial.print("distance = ");
Serial.print(snowDepth);
Serial.println(" inches");
sensors_event_t humidity, temp;
aht.getEvent(&humidity, &temp);// populate temp and humidity objects with fresh data
  float tempF = temp.temperature * (9.0/5.0) + 32.0;
  float hum = humidity.relative_humidity;
  String tempString = String(tempF, 2);
  Serial.print("Temperature: "); Serial.print(tempF); Serial.println(" degrees C");
  Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
  // Make sure to reset watchdog every loop iteration!
  Watchdog.reset();
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  Watchdog.reset();
  // Now we can publish stuff!
  Serial.print(F("\nSending photocell val "));
  Serial.print("...");
  if (! photocell.publish(tempF)) {
    Serial.println(F("Failed"));
    txfailures++;
    Serial.println(F("OK!"));
    txfailures = 0;
    Serial.print(F("\nSending humidityPub val "));
  Serial.print(hum);
  if (! humidityPub.publish(hum)) {
    txfailures++;
    txfailures = 0;
      Serial.print(F("\nSending depthPub val "));
  if (! depthPub.publish(snowDepth)) {
    txfailures++;
    txfailures = 0;
  Watchdog.reset();
void sensorReading() {
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);  // wait 5 seconds
  Serial.println("MQTT Connected!");
You'll need to post your code using code tags </> ad some kind of schematic to get proper help.
This line is causing your error. You are declaring this function but it is never defined. Where did you get it from? The comments would suggest a companion file fonahelper.cpp that needs to be available. Is it available?
@blh64 Thanks! That was my problem. I had opened a new window and cut and pasted the code from the old one and didn't bring over the helper file. Much appreciated!
