I have been searching the posts and nothing has helped yet. Recently set up a new computer and getting error that I did not get before.
I am able to connect to the board, at least I can start serial monitor and see output.
The error is:
Arduino: 1.8.10 (Linux), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/sdk/libc/xtensa-lx106-elf/include/sys/stdio.h:6:0,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/sdk/libc/xtensa-lx106-elf/include/stdio.h:63,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/cores/esp8266/Arduino.h:32,
from /home/user/Arduino/libraries/Blynk/src/Blynk/BlynkDebug.h:46,
from /home/user/Arduino/libraries/Blynk/src/Blynk/BlynkApi.h:15,
from /home/user/Arduino/libraries/Blynk/src/BlynkApiArduino.h:14,
from /home/user/Arduino/libraries/Blynk/src/BlynkSimpleEsp8266.h:24,
from /home/user/Arduino/Base/OurWeatherWeatherPlus/SDL_ESP8266_WeatherPlus/SDL_ESP8266_WeatherPlus.ino:28:
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/sdk/libc/xtensa-lx106-elf/include/sys/pgmspace.h:25:130: error: 'const char HTTP_HEAD []' redeclared as different kind of symbol
#define PROGMEM attribute((section( "".irom.text." FILE "." __STRINGIZE(LINE) "." __STRINGIZE(COUNTER) """)))
sketch/WiFiManager.h:60:24: note: in expansion of macro 'PROGMEM'
const char HTTP_HEAD[] PROGMEM = "<html lang="en"><meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no"/>{v}";
In file included from /home/user/Arduino/Base/OurWeatherWeatherPlus/SDL_ESP8266_WeatherPlus/SDL_ESP8266_WeatherPlus.ino:56:0:
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266WebServer/src/ESP8266WebServer.h:33:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
In file included from /home/user/Arduino/Base/OurWeatherWeatherPlus/SDL_ESP8266_WeatherPlus/SDL_ESP8266_WeatherPlus.ino:148:0:
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h: In function 'bool readWXLink()':
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h:71:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int, int)
uint8_t requestFrom(int, int, int);
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h:65:12: note: candidate 2: size_t TwoWire::requestFrom(uint8_t, size_t, bool)
size_t requestFrom(uint8_t address, size_t size, bool sendStop);
In file included from sketch/WEMOS_SHT3X.h:12:0,
from sketch/WEMOS_SHT3X.cpp:1:
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h: In member function 'byte SHT3X::get()':
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h:70:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
uint8_t requestFrom(int, int);
/home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire/Wire.h:68:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
uint8_t requestFrom(uint8_t, uint8_t);
In file included from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/sdk/libc/xtensa-lx106-elf/include/sys/ctype.h:7:0,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/tools/sdk/libc/xtensa-lx106-elf/include/ctype.h:5,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/cores/esp8266/WString.h:28,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/cores/esp8266/IPAddress.h:24,
from /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266WiFi/src/ESP8266WiFi.h:31,
from sketch/WiFiManager.h:16,
from sketch/WiFiManager.cpp:13:
In file included from sketch/WiFiManager.h:17:0,
Multiple libraries were found for "EEPROM.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/EEPROM
Multiple libraries were found for "Wire.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/Wire
Multiple libraries were found for "BlynkSimpleEsp8266.h"
Used: /home/user/Arduino/libraries/Blynk
Multiple libraries were found for "ESP8266WiFi.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266WiFi
Multiple libraries were found for "DNSServer.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/DNSServer
Multiple libraries were found for "ESP8266WebServer.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266WebServer
Multiple libraries were found for "ESP8266HTTPClient.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266HTTPClient
Multiple libraries were found for "ESP8266httpUpdate.h"
Used: /home/user/.arduino15/packages/esp8266/hardware/esp8266/2.6.1/libraries/ESP8266httpUpdate
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
option enabled in File -> Preferences.
