Anytime I try to verify the code to upload to the board I get an error.
Error messages is as follows:
'Arduino: 1.8.10 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
fork/exec /Users/admin/Library/Arduino15/packages/esp8266/tools/python3/3.7.2-post1/python3: no such file or directory
Error compiling for board Adafruit Feather HUZZAH ESP8266.
option enabled in File -> Preferences.'
I know the code works, Im using example code.
No sure exactly what is causing the error and how to fix it.
Im following this tutorial for the set up process.
When compiling a program on the adafruit feather huzzah esp8266, I am getting this error:
Arduino: 1.8.5 (Mac OS X), Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), 4MB (FS:2MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
In file included from /Users/reycekrause/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/sys/stdio.h:6:0,
from /Users/reycekrause/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/stdio.h:63,
from /Users/reycekrause/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/cores/esp8266/Arduino.h:32,
from sketch/RainbowWeatherStation.ino.cpp:1:
/Users/reycekrause/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/tools/sdk/libc/xtensa-lx106-elf/include/sys/pgmspace.h:25:130: error: 'const char HTTP_HEAD []' redeclared as different kind of symbol #define PROGMEM attribute((section( "".irom.text." FILE "." __STRINGIZE(LINE) "." __STRINGIZE(COUNTER) """)))
/Users/reycekrause/Google Drive/Arduino/libraries/WiFiManager-master/WiFiManager.h:32:24: note: in expansion of macro 'PROGMEM'
const char HTTP_HEAD[] PROGMEM = "<html lang="en"><meta name="viewport" content="width=device-width, initial-scale=1, user-scalable=no"/>{v}";
In file included from /Users/reycekrause/Google Drive/Arduino/libraries/WiFiManager-master/WiFiManager.h:17:0,
from /Users/reycekrause/Google Drive/GeekMOMProjects/RainbowWeatherStation/RainbowWeatherStation.ino:101:
/Users/reycekrause/Library/Arduino15/packages/esp8266/hardware/esp8266/2.6.3/libraries/ESP8266WebServer/src/ESP8266WebServer.h:33:39: error: previous declaration of 'HTTPMethod HTTP_HEAD'
enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
In file included from /Users/reycekrause/Google Drive/GeekMOMProjects/RainbowWeatherStation/RainbowWeatherStation.ino:109:0:
/Users/reycekrause/Google Drive/Arduino/libraries/FastLED/FastLED.h:14:21: note: #pragma message: FastLED version 3.003.002
pragma message "FastLED version 3.003.002"
In file included from /Users/reycekrause/Google Drive/Arduino/libraries/FastLED/FastLED.h:65:0,
/Users/reycekrause/Google Drive/Arduino/libraries/FastLED/fastspi.h:130:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
exit status 1
