"Error compiling for board Arduino Due (Programming Port)."
After successfully working with an Arduino Due for years, I now suddenly encounter an "Error compiling for board Arduino Due (Programming Port).".
  • It started after upgrading to Windows 10.0.18363 Build 18363.
  • I'm using Arduino: 1.8.13 (Windows 10), Board: "Arduino Due (Programming Port)"
It can be replicated as follows.
  • Board setting: "Arduino ARM (32-bits) -> Arduino Due (Programming Port)."
  • Starting the 'blink' sketch from scratch
  • Hit Ctrl-R to Compile/Verify: this yields successful complication.
  • Again hit Ctrl-R to Compile/Verify: this now yields "Error compiling for board Arduino Due (Programming Port)."
  • After switching to "Arduino ARM (32-bits) -> Arduino Due (Native USB Port).", the code can be compiled without error.
  • Now switching back to "Arduino ARM (32-bits) -> Arduino Due (Programming Port).", the code can be compiled without error.
  • However, trying to compile again (without changing anything) brings back the error.
Related or not: when trying to upload code, I often encounter a "No device found on COMx" error, even though the device is on that COM port.
Any suggestions would be appreciated.
Downgrade your compiler version :slight_smile: since it worked properly for years before upgrading.
Before downgrading, you could try this fix (reply #2):
https://forum.arduino.cc/index.php?topic=521815.0
And report the issue to Arduino.cc for a fix for the last DUE compiler version.
