Error compiling for board Arduino Ethernet
Good morning forum,
I am having some problems getting this code to work correctly. I have copied and pasted the error report below the code. To start with I wasn't sure if the board was working correctly so I carried out some tests , the board is in working order and the USB cable is fine. I need some ideas on how to resolve this please.
class DaysOfWeek {
    enum Days { Sun, Mon, tue, Wed, thu, Fri, Sat };
    Days Day;
          //     Serial.begin(115200);
          Day = Days::Mon;
          String Weekday = (String)DaysOfWeek::Mon;
          String WeekEnd = (String)DaysOfWeek::Sat;
    /*:Arduino: 1.8.15 (Windows 10), Board: "Arduino Ethernet"
      C:\Users\David\AppData\Local\Temp\ccZoFLRL.ltrans0.ltrans.o: In function `main':
      C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `setup'
      C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
      collect2.exe: error: ld returned 1 exit status
      exit status 1
      Error compiling for board Arduino Ethernet.
      option enabled in File -> Preferences.
 /*     setup();
  for (;;) {
    loop();
    if (serialEventRun) serialEventRun();
  return 0;
You should count whether the curly parenthesis are matching.
It seems that your Class has one parenthesis more than usuals
The formatting should give you a clue. Your setup() and loop() functions should start in column 1 (aka global level) and since yours do not, they must be part of a previous structure, aka your class definition.
I found a solution.
byte Name, Days, Job;
class  DaysOfWeek {
  public:
class  JobType {
  public:
    enum Job { Polish, Drill, Mill, Lathe, Assembly, Package,  };
class  Employee {
  public:
    enum Name { Fred, Bob, Mick, Li, Arron, Peter, Greg, Tony  };
  Job  = JobType::Polish;
  Days = DaysOfWeek::Sun;
  Name = Employee::Bob;
  Serial.print(Days);
  delay(100);
  Serial.print(Job);
  Serial.print(Name);
You defined setup() and loop() functions inside your object but you also need the global setup() and local() functions for your sketch:
class DaysOfWeek
    Days Day;
public:
      Day = Days::Mon;
} myDaysOfWeek;
  myDaysOfWeek.setup();
  myDaysOfWeek.loop();
Note:
This will set Weekday to "1" and WeekEnd to "6". Casting an enumeration value to String dos not get you the name. Typically you would use an array:
   const char * DaysNames{ "Sun", "Mon", "tue", "Wed", "thu", "Fri", "Sat" };
      String Weekday = Daynames[DaysOfWeek::Mon];
      String WeekEnd = DayNames[DaysOfWeek::Sat];
Thank you Johnwasser.
