Error compiling for board Arduino/Genuino Uno again
I have included all libraries needed, still got error:
CODE:
#include <Wire.h> // Library for the BNO055
#include <Adafruit_Sensor.h> // Library for the BNO055
#include <Adafruit_BNO055.h> // Library for the BNO055
#include <utility/imumaths.h> // Library for the BNO055
#include <NewPing.h>
#include <SimpleKalmanFilter.h>
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define SONAR_NUM 4      // Number of sensors.
#define MAX_DISTANCE 20 // Maximum distance (in cm) to ping.
#define PING_INTERVAL 33     //Looping the pings after 33 microseconds.
unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
unsigned int cm[SONAR_NUM];         // Where the ping distances are stored.
uint8_t currentSensor = 0;          // Keeps track of which sensor is active.
NewPing sonar[SONAR_NUM] = {     // Sensor object array.
  NewPing(2, 3, MAX_DISTANCE), // named as: cm0 Each sensor's trigger pin, echo pin, and max distance to ping.  /// named as: cm0 [ULSFL (ultrasonic sensor front left)] Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(4, 5, MAX_DISTANCE), // named as: cm1 //// NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
  NewPing(6, 7, MAX_DISTANCE), // named as: cm2 [ULSL (ultrasonic sensor right)] Each sensor's trigger pin, echo pin, and max distance to ping.
  NewPing(8, 9, MAX_DISTANCE), // named as: cm3 [ULSR (ultrasonic sensor right)]
int ult_sensorT[] = {2, 4, 6, 8 };
int ult_sensorE[] = {3, 5, 7, 9 };
const uint8_t  MOTOR_A1 = 10;
const uint8_t  MOTOR_A2 = 11;
const uint8_t  MOTOR_B1 = 12;
const uint8_t  MOTOR_B2 = 13;
const uint8_t  SWITCH = A0;
uint8_t  AVOIDANCE_DELAY = 2;
void disableMotors(void);
void enableMotors(void);
void goForward(void);
void goLeft(void);
void goRight(void);
void leftAvoid(void);
void rightAvoid(void);
void setupPins(void);
// Headings
void calculateHeadingError(void);
void correctHeading(void);
// Ultrasonic sensors
void doPingRight(void);
void doPingRightCtr(void);
void doPingLeftCtr(void);
void doPingLeft(void);
void getDistances(void);
// IR sensor
void readIRSensor(void);
// Obstacle avoidance
void avoidObstacles(void);
/*--------Module Variables--------*/
bool crossed_the_tape = false;
bool done = false;
int desired_heading;
int current_heading;
int heading_threshold = 60; // 120 degree cone until stage 2
int heading_error;
int ir_reflect_previous;
int ir_reflect_current;
int threshold = 200;
int distance_right; //// cm3
int distance_rightctr; ///// cm2
int distance_leftctr; ///// cm1
int distance_left;/////  cm0
int limit = 9; // Inches, try 5-10 depending on battery strength
bool right_or_left = false; // Switch
int sswitch;    //// state of switch
// Keep track of the time in milliseconds
unsigned long start_time;
unsigned long time_elapsed_threshold = 2000;
uint8_t oldSensorReading[3];    //Store last valid value of the sensors.
Adafruit_BNO055 bno = Adafruit_BNO055(55);
  Serial.println("SETUP");
  Serial.print("File   : "), Serial.println(__FILE__);
  Serial.print("Date   : "), Serial.println(__DATE__);
  display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS);
  enableMotors();
  ir_reflect_previous = digitalRead(SWITCH);
  ir_reflect_current = ir_reflect_previous;  //// for M1:
  pinMode(MOTOR_A1, OUTPUT);
  pinMode(MOTOR_A2, OUTPUT);
  pinMode(MOTOR_B1, OUTPUT);
  pinMode(MOTOR_B2, OUTPUT);
  for (int i = 0; i < 4; i++) // use for Buttons, limt switches, Uls sensors pin setup
    pinMode(ult_sensorT[i], OUTPUT); ////
    digitalWrite(ult_sensorT[i], LOW);
    pinMode(ult_sensorE[i], INPUT_PULLUP); ////too slow, changed : INPUT -- INPUT_PULLUP,
    digitalWrite(ult_sensorE[i], LOW);
void AOACar_loop() {
  Serial.println("switch = ");
  sswitch = digitalRead (SWITCH);
  Serial.println(SWITCH);
  ////// Ultrasonic();
  // Stage 0 - before the robot enters the
  // multi-obstacle environment
  while (!crossed_the_tape) {
    delay(50);
    // Read desired heading
    sensors_event_t event;
    bno.getEvent(&event);
    desired_heading = event.orientation.x;
    goForward();
    readIRSensor();
  // Stage 1
    // Read all four HC-SR04 sensors
    getDistances();
    // Avoid any obstacle along the way
    avoidObstacles();
  heading_threshold = 10;
  // Capture the time
  start_time = millis();
  // Stage 2
  while (!done) {
    calculateHeadingError();
    // Correct the heading if needed
    if (abs(heading_error) <= abs(heading_threshold)) {
      goForward();
    else {
      correctHeading();
      goForward();
    // Check to see if we are done
    if (((millis()) - start_time) > time_elapsed_threshold) {  //// beyonged a certain time, stop the car.
      done = true;
  while (done) {
    disableMotors();
void avoidObstacles() {
  // Avoid any objects
  if ((distance_leftctr < limit) && (distance_rightctr < limit)) {
    // Switch back and forth
    if (right_or_left) {
      rightAvoid();
    else {
      leftAvoid();
    right_or_left = !(right_or_left);
  else if ((distance_left < limit) || (distance_leftctr < limit)) {
    rightAvoid();
  else if ((distance_right < limit) || (distance_rightctr < limit)) {
    leftAvoid();
  else {
      goForward();
    else {
      correctHeading();
      goForward();
    // Check to see if we have crossed the tape
    readIRSensor();
    delay(50);
void calculateHeadingError() {
  // Read the current heading
  current_heading = event.orientation.x;
  // Calculate the heading error
  heading_error = current_heading - desired_heading;
  if (heading_error > 180) {
    heading_error -= 360;
  if (heading_error < -180) {
    heading_error += 360;
void correctHeading() {
  // Turn the vehicle until it is facing the correct
  // direction
  if (heading_error < -heading_threshold) {
    while (heading_error < -heading_threshold) {
      goRight();
      delay(4);
  else {
    while (heading_error > heading_threshold) {
      goLeft();
      delay(4);
void getDistances() {
  // Take distance readings on the HC-SR04
  doPingRight();
  doPingLeftCtr();
  doPingRightCtr();
  doPingLeft();
void goForward() {
  digitalWrite(MOTOR_A1, LOW);
  digitalWrite(MOTOR_A2, HIGH);
  digitalWrite(MOTOR_B1, LOW);
  digitalWrite (MOTOR_B2, HIGH);
void goLeft() {
  digitalWrite(MOTOR_B1, HIGH);
  digitalWrite (MOTOR_B2, LOW);
void goRight() {
  digitalWrite(MOTOR_A1, HIGH);
  digitalWrite(MOTOR_A2, LOW);
void leftAvoid() {
  // Go to the left when an object is detected
  // on the right-side of the vehicle
  while ((distance_right < limit) || (distance_rightctr < limit)) {
    goLeft();
    delay(4);
    doPingRight();
    doPingRightCtr();
  goForward();
  for (int i = 0; i < AVOIDANCE_DELAY; i++) {
    // Read the reflectance sensor
    //// ir_reflect_current = analogRead(IR_SENSOR);  //// for M1:
    // Check to see if we have crossed over the reflective tape
    //// if ((ir_reflect_previous - ir_reflect_current) >= threshold) {
    if (digitalRead(SWITCH) == HIGH)  {
      //// ir_reflect_previous = digitalRead(SWITCH);
      // Update if we crossed the tape
      crossed_the_tape = true;   //// first
    // Update the previous reading
    ir_reflect_previous = ir_reflect_current;
    delay(50);
void readIRSensor() {
  ir_reflect_current = digitalRead(SWITCH);
  if (digitalRead(SWITCH) == 1) {
    crossed_the_tape = true;     //// second
void rightAvoid() {
  // Go to the right when an object is detected
  // on the left-side of the vehicle
  while ((distance_left < limit) || (distance_leftctr < limit)) {
    goRight();
    delay(4);
    doPingLeft();
    doPingLeftCtr();
  goForward();
    if (digitalRead(SWITCH) == 1 ) {
      crossed_the_tape = true;   //// third
    delay(50);
void Ultrasonic() {
  for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
    if (millis() >= pingTimer[i]) {         // Is it this sensor's time to ping?
      pingTimer[i] += PING_INTERVAL * SONAR_NUM;  // Set next time this sensor will be pinged.
      if (i == 0 && currentSensor == SONAR_NUM - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
      sonar[currentSensor].timer_stop();          // Make sure previous timer is canceled before starting a new ping (insurance).
      currentSensor = i;                          // Sensor being accessed.
      cm[currentSensor] = 0;                      // Make distance zero in case there's no ping echo for this sensor.
      sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
  // The rest of your code would go here.
void echoCheck() { // If ping received, set the sensor distance to array.
  if (sonar[currentSensor].check_timer())
    cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
void setupPins() {
  ///// pinMode(ENABLE_B, OUTPUT);
void oneSensorCycle() {
  distance_left   = returnLastValidRead(0, cm[0]); ///// WAS: leftSensor   = returnLastValidRead(0, cm[0]);
  distance_leftctr = returnLastValidRead(1, cm[1]);  ///// WAS:  centerSensor = returnLastValidRead(1, cm[1]);
  distance_rightctr = returnLastValidRead(2, cm[2]);  ///// WAS:  centerSensor = returnLastValidRead(1, cm[1]);
  distance_right  = returnLastValidRead(3, cm[3]);  ///// WAS:  rightSensor  = returnLastValidRead(2, cm[2]);
//If sensor value is 0, then return the last stored value different than 0.
int returnLastValidRead(uint8_t sensorArray, uint8_t cm) {
  if (cm != 0) {
    return oldSensorReading[sensorArray] = cm;
    return oldSensorReading[sensorArray];
ERROR:
Arduino: 1.8.3 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Users\HUA~1.DEL\AppData\Local\Temp\cc8V1mHq.ltrans1.ltrans.o: In function `setup':
C:\Users\HUA.DELLV-PC\Documents\Arduino\AOACar_M1_post/AOACar_M1_post.ino:119: undefined reference to `enableMotors()'
C:\Users\HUA~1.DEL\AppData\Local\Temp\cc8V1mHq.ltrans1.ltrans.o: In function `main':
E:\ENGINEERING\DIY\Electronic\ARDUINO\arduino-1.8.3-windows\arduino-1.8.3\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Start by fixing that.
Then that.
Great!
Thank you!
