Error compiling for board Arduino/Genuino Uno.
I've gotten an ELEGOO starter kit for the holidays, and I've been playing with my Arduino for about three days now. I've run into a problem where after I try to upload or compile, I get an error message stating: "Error compiling for board Arduino/Genuino Uno." I've restarted my computer, Arduino, switched USB ports, tried different programs, looked online. I saw many people had the same problem as me but none of the solutions worked. Running this program:
(Or any other, for that matter)
I get this error log:
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\0dps1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047 -warnings=all -build-cache C:\Users\0dps1\AppData\Local\Temp\arduino_cache_955722 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\0dps1\AppData\Local\Temp\untitled608736300.tmp\sketch_dec27b\sketch_dec27b.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\0dps1\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10805 -build-path C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047 -warnings=all -build-cache C:\Users\0dps1\AppData\Local\Temp\arduino_cache_955722 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\0dps1\AppData\Local\Temp\untitled608736300.tmp\sketch_dec27b\sketch_dec27b.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\sketch\sketch_dec27b.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\sketch\sketch_dec27b.ino.cpp" -o "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\sketch\sketch_dec27b.ino.cpp" -o "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\sketch\sketch_dec27b.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047/sketch_dec27b.ino.elf" "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047\sketch\sketch_dec27b.ino.cpp.o" "C:\Users\0dps1\AppData\Local\Temp\arduino_build_638047/..\arduino_cache_955722\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\0dps1\AppData\Local\Temp\arduino_build_638047" -lm
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/lib/avr5/crtatmega328p.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
exit status 1
Can anybody help? Thanks!
The actual error message is:
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
exit status 1
I think what that error message is trying to tell you that the init code is trying to call main(). But it can't find where main() is defined. For the Arduino/Genuino Uno, that should be in hardware/arduino/avr/cores/arduino/main.cpp.
Other than that, all I know is that your system is messed up. When that happens to me, I just clear out my Arduino system (except all the code I have archived) and re-install it. It's the perfect time to update to the newest version.
