Error compiling for board Arduino/Genuino Uno
Hi! Can you help me with my code? I attached a copy below
#include <DS3231.h>
#include <Servo.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
  {'1','2','3',},
  {'4','5','6',},
  {'7','8','9',},
  {'*','0','#',}
byte rowPins[ROWS] = { 2, 3, 4, 5 };
byte colPins[COLS] = { 6, 7, 8, 9 };
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
I got these error messages
Arduino: 1.8.7 (Windows 10), Board: "Arduino/Genuino Uno"
C:\Users\Guess\AppData\Local\Temp\cc7HRiFI.ltrans0.ltrans.o: In function `main':
C:\Users\Guess\Desktop\arduino-1.8.7\hardware\arduino\avr\cores\arduino/main.cpp:43: undefined reference to `setup'
C:\Users\Guess\Desktop\arduino-1.8.7\hardware\arduino\avr\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
Your help will be much appreciated.
Your program does not have a function named setup() in it, nor does it have a function named loop()
Look at any of the example programs to see how these two mandatory functions are used
Can you post your complete code please.
Thanks for using code tags.. :slight_smile:
Tom.. :slight_smile:
Hi Tom, here are the codes.
#include <DS3231.h>
#include <Servo.h>
#include <Keypad.h>
  {'1','2','3',},
  {'4','5','6',},
  {'7','8','9',},
  {'*','0','#',}
DS3231 rtc(A4, A5);
Servo servo_test; //initialize a servo object for the connected servo
LiquidCrystal lcd(A0, A1, A2, 11, 12, 13); // Creates an LC object. Parameters: (rs, enable, d4, d5, d6, d7)
int t1, t2, t3, t4, t5, t6;
boolean feed = true;
 char key;
 int r[6];
  servo_test.attach(10);   // attach the signal pin of servo to pin9 of arduino
  rtc.begin();
  lcd.begin(16,2);
  servo_test.write(55);
  pinMode(A0, OUTPUT);
  pinMode(A1, OUTPUT);
  pinMode(A2, OUTPUT);
lcd.setCursor(0,0);
int buttonPress;
buttonPress = digitalRead(A3);
if (buttonPress==1)
 setFeedingTime();
 lcd.print("Time:  ");
 String t = "";
 t = rtc.getTimeStr();
 t1 = t.charAt(0)-48;
 t2 = t.charAt(1)-48;
 t3 = t.charAt(3)-48;
 t4 = t.charAt(4)-48;
 t5 = t.charAt(6)-48;
 t6 = t.charAt(7)-48;
 lcd.print(rtc.getTimeStr());
 lcd.setCursor(0,1);
 lcd.print("Date: ");
 lcd.print(rtc.getDateStr());
 if (t1==r[0] && t2==r[1] && t3==r[2] && t4==r[3]&& t5<1 && t6<3 && feed==true)
  servo_test.write(100);                   //command to rotate the servo to the specified angle
   delay(400);
  feed=false;
void setFeedingTime()
  feed = true;
   int i=0;
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Set feeding Time");
  lcd.clear();
  lcd.print("HH:MM");
  lcd.setCursor(0,1);
  while(1){
    key = kpd.getKey();
    char j;
  if(key!=NO_KEY){
    lcd.setCursor(j,1);
    lcd.print(key);
    r[i] = key-48;
    i++;
    j++;
    if (j==2)
      lcd.print(":"); j++;
  if (key == 'D')
  {key=0; break; }
Thanks for helping
DS3231 rtc(A4, A5);
What are the two pin numbers for ?
Have you looked at the examples with the library ?
Do you need to #include the Wire library ?
I am beginner so I don’t know much :confused: I attached two diagrams below.
I’m a college student, assigned for arduino project but I have no basic in programming.
Let me suggest a site to you. Have you heard of Hackster.io? You could look for answers for Arduino projects and problems there. Hope this helped.
Thank you for your suggestion!
nazdmiii:
So, you have the DS3231 connected to pins A4 and A5 but these pins have a special function when used with the Wire library
Here is the start of an example DS3231 program that comes with the library
#include <DS3231.h>
#include <Wire.h>
DS3231 Clock;
bool Century=false;
bool h12;
bool PM;
byte ADay, AHour, AMinute, ASecond, ABits;
bool ADy, A12h, Apm;
	// Start the I2C interface
	Wire.begin();
	// Start the serial interface
Note the inclusion of the Wire library, the declaration of an object named Clock with no pins as parameters and the starting of the I2C interface to the RCT
Compare that with your program
