I fixed it by using the tool section in arduino and searching for U8glib and installing it. Now an even bigger issue came out.
Arduino: 1.8.15 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\marlinui_DOGM.h:31:0,
from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\marlinui.cpp:130:
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_64128N_2X_HAL::init(pin_t, pin_t, pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:37:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7565_64128n_HAL_2x_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_64128N_2X_HAL::init(pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:40:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7565_64128n_HAL_2x_hw_spi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_4X_HAL::init(pin_t, pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:53:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_HAL_4x_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_4X_HAL::init(pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:56:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_HAL_4x_hw_spi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_RRD::init(pin_t, pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:71:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_rrd_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_SH1106_128X64_2X_I2C_2_WIRE::init(uint8_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:81:59: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t options = U8G_I2C_OPT_NONE) { U8GLIB::init(&u8g_dev_sh1106_128x64_2x_i2c_2_wire, options); }
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1306_128X64_2X_I2C_2_WIRE::init(uint8_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:90:59: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t options = U8G_I2C_OPT_NONE) { U8GLIB::init(&u8g_dev_ssd1306_128x64_2x_i2c_2_wire, options); }
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_TFT_320X240_UPSCALE_FROM_128X64::init(uint8_t, uint8_t, uint8_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:103:77: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t cs, uint8_t rs, uint8_t reset = U8G_PIN_NONE) { U8GLIB::init(&u8g_dev_tft_320x240_upscale_from_128x64, cs, rs, reset); }
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_MINI12864_2X_HAL::init(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:115:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_uc1701_mini12864_HAL_2x_sw_spi, sck, mosi, cs, a0, reset);
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_MINI12864_2X_HAL::init(uint8_t, uint8_t, uint8_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:118:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_uc1701_mini12864_HAL_2x_hw_spi, cs, a0, reset);
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1309_128X64_HAL::init(pin_t, pin_t, pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:131:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_ssd1309_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1309_128X64_HAL::init(pin_t, pin_t, pin_t)':
C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\HAL_LCD_class_defines.h:134:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_ssd1309_hw_spi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\lcdprint_u8g.cpp:14:
from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\marlinui_DOGM.cpp:42:
from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\dogm_Statusscreen.h:32,
from C:\Users\rafae\AppData\Local\Temp\Temp1_Marlin-2.0.x (1).zip\Marlin-2.0.x\Marlin\src\lcd\dogm\status_screen_DOGM.cpp:32:
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
option enabled in File -> Preferences.
