Error compiling for board Arduino Mega or Mega
I have a DIY reprap Mendel based on the Prusa i3. I built the machine some years ago and had very little problem with initial Marlin configuration and the machine wiorked well. I have recently started using it again with a BL touch added and have tried using Marlin 2.0.3 as advised on the GitHub forum.
However I am having a problem with the configuration. I managed to complete the configuration and verified it on my home PC (Win 10) but when I took it to the printer PC I got a n error when compiling. When I went back to the home PC I had exactly the same error which I list below:-
Archiving built core (caching) in: C:\Users\Terry\AppData\Local\Temp\arduino_cache_487220\core\core_arduino_avr_mega_cpu_atmega2560_e96223c13c81911d89dfbd2c8674a8de.a
Linking everything together...
"C:\Users\Terry\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino5/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections,--relax -mmcu=atmega2560 -o
"C:\Users\Terry\AppData\Local\Temp\arduino_build_828547/Marlin.ino.elf"
"C:\Users\Terry\AppData\Local\Temp\arduino_build_828547\sketch\Marlin.ino.cpp.o"
"C:\Users\Terry\AppData\Local\Temp\arduino_build_828547/core\core.a"
"-LC:\Users\Terry\AppData\Local\Temp\arduino_build_828547" -lm
C:\Users\Terry\AppData\Local\Temp\ccgDt77s.ltrans0.ltrans.o: In function `main':
C:\Users\Terry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/main.cpp:43: undefined reference to `setup'
C:\Users\Terry\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.2\cores\arduino/main.cpp:46: undefined reference to `loop'
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
I have attached Configuration.h as a zipped file for possible testing. As a non programmer I don't really understand what is going on here Am I missing a file somewhere? or is there a bug in the software. I hope that there is some clever person out there who has solved this or understands what is happening. Please help if you can I would most appreciate it.
Terry Dixon
Configuration.zip (26.9 KB)
This error indicates you're missing part of Marlin. You need the src subfolder in addition to the files in the Marlin folder.
Do this:
